Hello, my name is Jess and I have a slight problem with my camera, and I was wondering if anyone could help me out.
Well, just today, I was mucking around with my camera (Canon EOS 30D) and when I tried to take a photo, if didn't happen. It struck me as strange because the camera was still considered "ON" and there was nothing on the dials or anything.
So I pressed the shutter a few times and still nothing. Then I took the battery out and turned it Off/On again. And then it "works", but as soon as I try to take anothing photo... IT DOES THE EXACT SAME THING
Now, I'm freaking out a bit because I have a trip coming up, to Melbourne, which I plan to take heaps of photos, both just in general and open shutter.
I would really really really appreciate if anyone can help me. I would greatly appreciate this. Thank-you.
The
problem that you describe is frequently due to a corrosion buildup that
prevents the full power of the batteries from flowing to the camera.
Remove the batteries and wipe the camera contacts firmly with a dry
cloth (heavy corrosion may require cleaning with a wire brush, steel
wool, or sandpaper). Remove any residue that may have fallen into the
battery compartment during the cleaning, then wipe both ends of the
batteries and reinsert them into the camera. This cleaning clears the
problem about 90% of the time, and I hope it works for you.
When I try to view images on a tv the connection in the camera does not hold and the image does not...
(More)
When I try to view images on a tv the connection in the camera does not hold and the image does not stay. When I move the connection to a better connection and hold it the picture will stay if I put pressure on the the camera connection. Canon 30D
after cleaning the sensor (with a bulb air cleaner) the high-speed setting no longer works correctly...
(More)
after cleaning the sensor (with a bulb air cleaner) the high-speed setting no longer works correctly (running water no longer looks "frozen")...any ideas?
Same thing, all images are extremely over-exposed. When using flash, however, exposure is (more or...
(More)
Same thing, all images are extremely over-exposed. When using flash, however, exposure is (more or less) OK, so I figure the flash metering does not rely on the same mechanism. Anyone got a clue on how to get to the AE sensor? The location pepeik posted (thanks for that!) does not exactly suggest a way of getting there.
