Explorer.exe When I start windows[xp pro sp2] I get an error message Explorer.exe  cannot be started browseui.dll is missing.Reinstalling the application can fix the problem
  • 1 more comment
  • jawla Dec 23, 2007
    desktop icons like my computer and other icon and start menu not shown after login and message shown that explorer.exe is corrupted
  • bosik Aug 02, 2008
    When I click on local drive to open it in MY COMPUTER, there appears a menu ''what programm to use?''
    - instead to open it. I set ''explorer.exe'' in WINDOWS folder. It opens by explorer, with dirrectory tree instead of left-side menus. After deliting infected files (damaged by Win 32 virus), one of local drives now I can open normally.
  • ziruma1962 Jan 15, 2009
    TENGO PROBLEMAS CON EL WINDOWS UPDATE Y EL INTERNET EXPLORER, NO SE QUE ESTA PASANDO CON MICROSOFT, MI EQUIPO NO LO RECONOCE APESAR DE TENER UN WINDOWS XP ORIIGINAL.
    SI ALGUIEN PUEDE AYUDARME, LE AGRADEZCO, TENGO MUCHOS PROGRMAS QUE NO PUEDO INSTALAR POR ESTA FALLA.
    RECIBIRE RESPUESTA EN MI MSN: ziruma1962@hotmail.com.
    MI NOMBRE ES YANETH DE JESUS RODRIGUEZ MUñOZ
  • 31 Answers
Insert Windows XP cd on drive, and use upgrade option.
Posted on Dec 14, 2007
Disconnectivity within 1 minute I install a fresh
ftp://ftp.hp.com/pub/softpaq/sp47501-48000/sp47845.exe
A lot of Windows Update Issues are linked to this Intel Storage Technology Driver being out of date. Hope this helps!
Aug 16, 2013 | Computers & Internet
Tip
How to Restore Disabled Folder Pane in Windows Explorer
Problem:
When you open Windows Explorer, the left hand Folders pane is disabled or gray or blank and the folder tree on left is not available.
Cause:
There may be an error in the registry. A required system file is missing or an incorrect version.
Solutions:
Close Windows Explorer.
Start the Registry Editor (click Start, Run, type regedit and click OK).
Expand HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main.
In the right-hand pane, locate the value named ExplorerBar. If present, delete it.
Restart Windows Explorer. If this does not resolve the issue,
The correct solution depends on the version of Internet Explorer that is installed on the computer.Internet Explorer 5.5 or lower
The preferred solution for computers with Internet Explorer 5.5 or lower is to upgrade to the latest version of Internet Explorer.
If this is not possible:
Open the folder C:\Windows\System. Check that the file browseui.dll is present. If it is not present, restore this file.
Internet Explorer 6
Open the folder C:\Windows\System. Check that the file shdocvw.dll is present. If it is not present, restore this file.
Open a command prompt.
Enter the command cd \Windows\System
Verify that the command prompt shows C:\Windows\System.
Enter the command regsvr32 /i shdocvw.dll.
Enter the command regsvr32 /i browseui.dll.
A message will appear confirming the successful registration of the files.
Now restart the sytem and confirm the problem is solved.
on Jan 17, 2010 | Computers & Internet
My computer will only go as far as the password, then (explorer.exe - unable to locate... ) this application has failed to start because BROWSEUI.dll was not found, Re-installing the application may...
try hitting control>shift>escape at the same time to bring up task manager. then, go to the task manager "file" tab, and select "run" type in "explorer" and hit enter. if windows does not open, then you will have to reinstall explorer.exe in your windows folder.
find a computer with the same version of windows as your own, and hook up your hard drive as an external or secondary drive in that machine. copy the file "explorer.exe" from the windows folder on that computer to the windows folder of your laptop drive.
if that doesnt wortk, you will have to find some sort of registry repair utility that can be booted, i.e. ran without windows. or, perhqaps, you have blocked yourself out of the windows folder with permissions or group policy...
youll prolly have to reinstall windows in the end, cause explorer.exe doesnt usually disapear unless there are other problems
browser.dll can also be reinstalled, it basically is just needed for internet explorer.
Oct 12, 2010 | Dell XPS M1330 Notebook
I cant seem to open up my internet explorer
To resolve this problem in Internet Explorer, follow these steps:
  1. Quit all programs that are running.
  2. Click Start, and then click Run.
  3. Type regsvr32 urlmon.dll, and then click OK.
  4. When you receive the "DllRegisterServer in urlmon.dll succeeded" message, click OK.
If this does not resolve the problem, repeat steps 2 through 4 for each of the following files (in step 3, replace Urlmon.dll with each of the file names below):
  • Shdocvw.dll
  • Actxprxy.dll
  • Oleaut32.dll
  • Mshtml.dll
  • Browseui.dll
  • Shell32.dll
Windows XP and Windows 2000 only loadTOCNode(3, 'resolution'); Restart the computer to enable the changes to take effect.
If the problem is still not resolved, verify that the following registry values are present and correct: HKLM\SOFTWARE\Classes\Interface\{00020400-0000-0000-C000-000000000046}
Value: IDispatch
HKLM\SOFTWARE\Classes\Interface\{00020400-0000-0000-C000-000000000046}\ProxyStubClsid
Value: {00020420-0000-0000-C000-000000000046}
HKLM\SOFTWARE\Classes\Interface\{00020400-0000-0000-C000-000000000046}\ProxyStubClsid32
If the problem is still not resolved, reinstall Internet Explorer. If you are using the version of Internet Explorer that is included with your operating system, reinstall or repair your operating system.
Jan 24, 2010 | Computers & Internet
Explorer.exe Application error in Windows XP Professional SP2
hello ! what you should do put another HD then install XP the reason for this messages could be due to registry .
if you are getting the same messeges get another cd of XP
GOOD DAY
May 27, 2009 | Microsoft Windows XP Professional
My computer Desktop is not running.
Hi hichris_4u
You should be able to replace the Explorer.exe. Type in the command prompt expand C:\I386\explorer.ex_ %systemroot%\explorer.exe This will expand a new copy to the windows directory.
You should also download a new version of SP2 and reinstall it. You also could download a clean copy of SP2 Click the Download button. The file is 266MB. Create a folder on the C:\ root called SP2 and download it there. Create another folder called SP2 files now at a command prompt type C:\SP2\WindowsXP-KB835935-SP2-ENU.exe /x it’ll ask you to specify an directory so point it to the SP2 Files folder and let it extract there. Now type in the command prompt expand C:\SP2 Files\I386\explorer.ex_ %systemroot%\explorer.exe to expand a new copy to the windows directory.
If you get an error on destination, try expand C:\SP2 Files\I386\explorer.ex_ c:\windows\explorer.exe
If you expanding fron the I386 from the C:\ root try expand C:\I386\explorer.ex_ c:\windows\explorer.exe
If all fails, try and download SP2 onto another machine and then burn it to a CD for install.
Good Luck,
Mark
Mar 26, 2009 | Microsoft Windows XP Professional SP2
Trojan - antivirus-xp-pro-2009
Take my notes as a guide and hopefully this will work for you.
1. Start > Run > msconfig > “Start Up” tab > Disable All
2. “Services” tab > Check box “Hide Microsoft Services” > Disable All
2.5 Exit out, but don't reboot yet
3. Start > Right-click “My Computer” > “Properties” > “System Restore” > Check box “Turn off restore on Hard disks”
4. Start > Run > type %temp% > Edit Select All > Shift-Delete
Reboot machine
1. Combofix.exe. This program will run on its own. Also, it will likely wish to reboot the machine. Let it complete.
http://download.bleepingcomputer.com/sUBs/ComboFix.exe
2. WinSockFix.exe. This will fix any issues with the network connection.
3. SuperAntispyware.exe. This will remove all remaining spyware, tracking cookies, and browser hijackers.
Check to see that your favorite internet browser is working. Install or re-enable your favorite antivirus that failed to catch this in the first place.
Stop WinAntiVirus2008 Processes:
mav_startupmon.exe
uwa7pcw.exe
rtasks.exe
WinAv.exe
wa7pinst.exe
Remove WinAntiVirus2008 Registry Values:
2178F3FB-2560-458f-BDEE-631E2FE0DFE4
6F520BE0-9B54-4558-816F-224E67997DF3
459F4226-1AAB-43B6-9DC1-B6313EF83749
1AC5C88A-DEA7-462b-A232-04AF5CA42E7E
723D54C7-7483-4EB8-8EED-CE5B2AEA534D
Find and Delete these WinAntiVirus2008 Files:
WinAntiVirus Pro
WinAv.exe
uwa7pcw.exe
mav_startupmon
mav_startupmon.exe
rtasks
rtasks.exe
wa7pinst.exe
IH.exe
WinAntiVirus Pro.lnk
Reinstall or Uninstall WinAntiVirus Pro.lnk
WinAntiVirus Pro Manual.lnk
WapCHK.dll
rpt.dll
awvtr.dll
yayyvsp.dll
fcyxx.dll
gebxyax.dll
asmngr.dll
fopnl.dll
IEFWBHO.dll
Scnkrnl.dll
settings.dll
sqlite3.dll
WAV6COM.dll
winpgi.dll
BORLNDMM.dll
SCANADWR.dll
SCANBCDR.dll
SCANLDR.DLL
SCANDOS1.dll
SCANEMUL.dll
SCANFUNC.dll
SCANMCRL.dll
SCANOTHR.dll
SCANSCR.dll
SCANTOOL.dll
SCANTROJ.dll
SCANWIN1.dll
UNACPU.dll
UNADBX.dll
unamscan.dll
UNMIME.dll
UNPACK.dll
UNPACKS.dll
UNPACKS2.dll
UNPEPACK.dll
Vista
Stop WinAntivirus2008 Processes:
(Learn how to do this)
WinAntivirus2008.exe
mav_startupmon.exe
uwa7pcw.exe
rtasks.exe
WinAv.exe
wa7pinst.exe
Find and Delete these WinAntivirus2008 Files:
%UserProfile%\Desktop\Viruses.bdt
%UserProfile%\Desktop\WinAntivirus2008.lnk
c:\Program Files\WinAntivirus2008
c:\Program Files\WinAntivirus2008\Viruses.bdt
c:\Program Files\WinAntivirus2008\VRM2008.exe
c:\Documents and Settings\All Users\Start Menu\Programs\WinAntivirus2008
c:\Documents and Settings\All Users\Start Menu\Programs\WinAntivirus2008\WinAntivirus2008.lnk
%UserProfile%\Application Data\Microsoft\Internet Explorer\Quick Launch\WinAntivirus2008.lnk
%UserProfile%\Application Data\Mozilla\Firefox\Profiles\s1jqw0bz.default\cookies.sqlite
WinAv.exe
uwa7pcw.exe
mav_startupmon
mav_startupmon.exe
rtasks
rtasks.exe
wa7pinst.exe
IH.exe
WapCHK.dll
rpt.dll
awvtr.dll
yayyvsp.dll
fcyxx.dll
gebxyax.dll
asmngr.dll
fopnl.dll
IEFWBHO.dll
Scnkrnl.dll
settings.dll
sqlite3.dll
WAV6COM.dll
winpgi.dll
BORLNDMM.dll
SCANADWR.dll
SCANBCDR.dll
SCANLDR.DLL
SCANDOS1.dll
SCANEMUL.dll
SCANFUNC.dll
SCANMCRL.dll
SCANOTHR.dll
SCANSCR.dll
SCANTOOL.dll
SCANTROJ.dll
SCANWIN1.dll
UNACPU.dll
UNADBX.dll
unamscan.dll
UNMIME.dll
UNPACK.dll
UNPACKS.dll
UNPACKS2.dll
UNPEPACK.dll
Remove WinAntivirus2008 Registry Values:
5222008A-DD62-49c7-A735-7BD18ECC7350
HKEY_CURRENT_USER\Software\WinAntivirus2008
WinAntivirus 2009
# 1. Find and Remove the following Antivirus 2009 Processes:
* av2009.exe
# 2. Find and Remove the following Antivirus 2009 files and folders:
* C:\Program Files\Antivirus 2009
* C:\Program Files\Antivirus 2009\av2009.exe
* c:\WINDOWS\system32\scui.cpl
* c:\WINDOWS\system32\winsrc.dll
# 3. Find and Remove the following Antivirus 2009 files and folders:
* HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\ CurrentVersion\Run\15358943642955870504508370025739
Mar 06, 2009 | Microsoft Windows XP Home Edition Service...
Invalid syntx error
The cause of this issue
CAUSE loadTOCNode(1, 'cause'); This behavior may occur for one or more of the following reasons: • The (Default) value setting in one or more of the following registry keys points to an incorrect location for the Urlmon.dll file: [HKEY_CLASSES_ROOT\CLSID\{79eac9e0-baf9-11ce-8c82-00aa004ba90b}\InprocServer32] [HKEY_CLASSES_ROOT\CLSID\{79eac9f1-baf9-11ce-8c82-00aa004ba90b}\InprocServer32] [HKEY_CLASSES_ROOT\CLSID\{79eac9f2-baf9-11ce-8c82-00aa004ba90b}\InprocServer32]This Behavior May Occur if you install a customized version of Internet Explorer that was created with the Internet Explorer Administration Kit (IEAK) version 5.01 Service Pack 1 (SP1), 5.5 SP1, or 6.0. • The following registry key is missing or damaged: HKLM\SOFTWARE\Classes\Interface\{00020400-0000-0000-C000-000000000046} • One or more of the following files is missing, damaged, or improperly registered: • Urlmon.dll • Mshtml.dll • Actxprxy.dll • Oleaut32.dll • Shell32.dll • Shdocvw.dll
RESOLUTION loadTOCNode(1, 'resolution'); To resolve this problem in Internet Explorer, follow these steps: 1. Quit all programs that are running. 2. Click Start, and then click Run. 3. Type regsvr32 urlmon.dll, and then click OK. 4. When you receive the "DllRegisterServer in urlmon.dll succeeded" message, click OK.If this does not resolve the problem, repeat steps 2 through 4 for each of the following files (in step 3, replace Urlmon.dll with each of the file names below): • Shdocvw.dll • Actxprxy.dll • Oleaut32.dll • Mshtml.dll • Browseui.dll • Shell32.dll Windows XP and Windows 2000 only loadTOCNode(3, 'resolution'); Restart the computer to enable the changes to take effect.
Value: IDispatch
Thanks
Riz
Mar 21, 2008 | Microsoft Windows XP Home Edition
BROWSEUI.dll
Got to Add/Remove Programs in the Control Lanel. Go to Windows components and remove Internet Explorer and then add it back. That 'should' restore that file.
if the above doesn't work see if you can access this folder,
c:\windows\servicepackfile\I386 or
Windows\System32\dllcache, there should be a copy of Browseui.dll in there to copy back to the System32 folder.You will have to reboot your machine after copying it back
Dec 22, 2007 | Biostar M7VKL Motherboard
Computers & Internet Logo
218 people viewed this question
Alun Cox
David Payne
David Payne
