Question about Brother MFC 3100C All-In-One InkJet Printer
Brother mfc 2400
Got a paperjam, unjammed, all was well. but now, when trying to print, recieve the see help and technical stuff in display window.... the print head will not move from the far right. there is no obstruction, the print head can be moved by hand, but there is clicking sound when doing so. i presume that could be gears that are not turning? any help would be appreciated.
  • savageone Dec 13, 2007
    ok, i talked with the owner of the printer and found out she is getting an error code. searcing that code i come to this helpful post here:
    http://www.fixya.com/support/t211210-bro...
    does anyone have a link to the diagrams in a larger readable format?
    thanks a bunch!
I can't find a way to connect the printer to the central processing unit
Posted on Dec 14, 2010
    President:
  • 4,402 Answers
Unplug and plug back in see if it clears itself and yes the click is gears could be out of timing.
Posted on Dec 13, 2007
  • Cary Farah
    Cary Farah Dec 14, 2007
    I believe he got it from here
    http://welcome.solutions.brother.com/bsc...
How do you reset a replace toner error on brother printer
Open the front cover of the printer
Press and release the "clear" key
Press "start", then press the up arrow until you see the number 12 on the display
Press "ok", you will see "accepted" on the display
Close the front cover, your toner cartridge should now work.
Apr 07, 2014 | Brother MFC-7860DW - Laser Multifunction...
Faded printing issues with Brother MFC-9320
Try cleaning the corona wire on each toner cartridge. This may help solve your solution.
If this does not help try another thing.
Try and replace the toner cartridge. Maybe your toner cartridge needs to be replaced. Usualy when printed images are light or pale a toner cartridge replacement is recommended.
To see how to replace your toner cartridges check here
May 16, 2012 | Brother MFC-9320CW Color Laser Printer -...
I have a Brother mfc-240c - will not print yellow
The print head is clogged.If not unclogging with cleaning process may you try to clean manualy.You need to dissasembly the hole printer to remove the print head.Put it in hot water.If you don't have a technical skills, don't try anything.
If not help just buy new printer, because the new print head will cost you as much more.
Nov 06, 2009 | Brother MFC 240C All-In-One InkJet Printer
Print unable see trouble shooting and routine maintenance
sending fax is working alri.ght, only when I try to recieve fax it gives an error 30 on the display. At the same time it unable to clean. Please help me with this.
Jan 17, 2009 | Brother Multi-Function Center MFC-240C...
Print unable 50 message
what mfc do you run? if you run a mfc 56XX you had a serious paperjam the days before I guess: read this then (same issue)
http://www.fixya.com/support/t211210-brother_mfc845cw
Feb 15, 2008 | Brother MFC-5840CN All-In-One InkJet...
Printer
Paul,
did you had a paperjam the days before?
The encoder strip which gives the print head the position is out of position. It has to be fixed into the ph.
Read my post here (same issue and same procedure):
http://www.fixya.com/support/t272288-unable_print
Dec 05, 2007 | Brother MFC 420CN All-In-One InkJet...
Mfc-5460cn
Please tell us what machine do you really have:
Is it a mfc 420cn or a mfc 5460cn?
Did you have a paperjam before getting the error?
This might be due to the paperjam.
Ill try to give you some more help but need more info...
Oct 25, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 3100C All-In-One InkJet Printer Logo
351 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
