Question about iLO (2 GB) MP3 Player
"Searching Files 20%"
Last night I tryed to do a voice recording. I got done, went into the menu, and clicked voice recordings to hear it. When I got there, it said . I clicked that, my iLo shut off, then turned on and was stuck on "Searching Files 20%". I then took the battery out and put it back in, but it kept "Searching". So I left it alone without a battery all night, and then I tryed again this morning, and same problem.
P.s. I have 108 songs on my iLo. It is a 1GB iLo.
Please help?
  • Washburn12 Dec 14, 2007
    I reformatted it and it works now. Thanks :)
  • 8,596 Answers
Reformat the player
Posted on Jul 05, 2008
I am on MAC platform and would like to convert VM1 file to any audio format read by the MAC.
The only way to convert VM1 files to anything else is to use the Panasonic voice editing software. I have tried several other methods that claim to work but none of them have. The only way I was to do this was:
1.install a Windows XP operating system onto an old computer or get access to a Windows XP, Vista, or 2000.
2. I found an old Panasonic voice recorder off eBay that still had the software and purchased it (Panasonic RR-US470)
3. Installed the software
4. This is where it got tricky. The voice editing software doesn't recognize .vm1 files from other sources. The recorder and its software create its own file structure but if you put your own .vm1 files inside them, even with the same name, it still won't read it. Unless you do this.
A. Let's say you have 20 .vm1 files you want to convert you must first record 20 different voice recordings onto your voice recorder. These recordings can be like a second long.
B. Attach the voice recorder and move the new recordings to the folder using the software. The software will name the files MB001.vm1...MB002, etc. They will be hidden also.
C. Name your old files (the ones you want to convert to the same name as the 20 new recordings.)
D. Delete the new recordings from your computer and replace them with the files you want to convert. (the must have the same name).
E. Your software will now see the old files you want to convert. (On the software if you click outside the folder they are located and click back into it, you will now see the same files. It will still have the same duration as your new recordings but the file size will be bigger and you can listen to it and it will now be your old files.
F. Convert these to wave.
Once you get your .vm1 file converted smash your recorder and never use Panasonic ever again. There may be an easier way to do this, but I've tried many ways and nothing worked except this.
Aug 06, 2010 | Panasonic RR-XR320 Handheld Digital Voice...
Olympus Voice Recorder says only 6 hours time when it's empty
Hello
The recorder should be formatted only by using the internal FORMAT function found in the Menu. Formatting using the computer may corrupt system files needed to run the recorder and may delete the Voice Guide Data and Audible system files, so computer formatting is not recommended. When the recorder is connected to a computer, individual files can be deleted using My Computer without negative effects.after you format the unit this is how needs t
be depends on your selection for Audio quality
STEREO XQ mode: 17 hours 30 minutes
STEREO HQ mode: 35 hours 10 minutes
HQ mode: 70 hours 20 minutes
SP mode: 138 hours 30 minutes
LP mode: 275 hours 20 minutes
if this don't solved your problem you can get one really cheap athttp://www.tvps.com/Products/Olympus-DS-50-1-GB-Digital-Portable-Voice-Recorder---Demo-DS50__OL-D-DS-50.aspx just like a back up
Feb 10, 2010 | Olympus DS-50 Digital Voice Recorder
Need driver: Windows for Olympus digital voice recorder VN-120PC
igital Wave Player (2.0):
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
After unzipping the file, click on the SETUP.EXE file to begin installation.
Download update: http://olympusamerica.com/files/DWPUP2EN.zip
Download update 2.1.3: http://olympusamerica.com/files/DWPUP4EN.zip
Do not have recorder connected until all software installed and then reboot computer. Once computer rebooted then connect the recorder.
Mar 22, 2009 | Olympus VN-120 Digital Voice Recorder
DM-10 reverted to japanese
To reset the settings back to English:
1. Set the DM-10 to Voice mode using the blue switch on the back voice recorder.
2. Remove the DM-10 from Hold using the gray switch on the back of the voice recorder.
3. Press and hold the DISPLAY/MENU button on the front of the DM-10 for at least 3 seconds. The menu list is displayed.
4. Click the REWIND button six times to highlight the Format menu item.
5. Click the PLAY button to select the Format menu item. A message will be displayed with Cancel and Start options.
6. Click the REWIND button once to highlight Start.
7. Click the PLAY to select Start. A message stating that the data will be cleared will display briefly. Then a message asking if you are sure will be displayed.
8. Click the REWIND button once to highlight the Start menu item to continue with the format.
9. Click the PLAY select the Start menu item and begin the format. The format progress bar will appear. When it is complete the menu items will be in the English language.
Jan 09, 2009 | Olympus DM-10 Handheld Digital Voice...
Dm-20 displays Chinese
1. Set the DM-20 to Voice mode using the blue switch on the back voice recorder.
2. Remove the DM-20 from Hold using the gray switch on the back of the voice recorder.
3. Press and hold the DISPLAY/MENU button on the front of the DM-20 for at least 3 seconds. The menu list is displayed.
Jan 08, 2009 | Olympus DM-20 Digital Voice Recorder
WS-110 memory full but no files
well, i resolved this myself by going to the sub-menu, and formatting the recorder to its original state. thankfully, i backed up the files on my computer first, so i didn't lose any data, although i did have to go in and re-set all my preferences on the recorder.
lesson: don't MOVE files from recorder to computer. copy them instead, and do the actual erasing from the physical recorder itself.
i don't know if this was the most elegant solution, but at least it did get my recorder up and running again. i'd love to hear if there is a better resolution out there.
Nov 28, 2008 | Olympus WS-110 Digital Voice Recorder
Olympus DM-20 erase lock is on, how to undo it?
The voice recorder is in read only status - you will need to format the device to remove the lock (read only). Go to menu - to submenu and then run the format option. make sure all files have been downloaded as once device is formatted all files will be permanently deleted
Oct 16, 2008 | Olympus DM-20 Digital Voice Recorder
DS-400 DIGITAL VOICE RECORDER
went on the "menu" option and formated the disk. I first downloaded the files I needed to my computer. Took off the "lock" option.
Jun 25, 2008 | Olympus DM-20 Digital Voice Recorder
How do I Change from default language back to English?
Apr 07, 2007 | Olympus DM-20 Digital Voice Recorder
iLO (2 GB) MP3 Player Logo
78 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Jon Piercy
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
