Question about Baby Lock Esante
Thread breaka When I use embroidery, after a minute or so of sewing, the thread breaks. And when I put the thread back and start to sewing, it breaks again and again, but each time it breaks fastter. I appreciate if you could help me to fix this problem.
  • 3 Answers
Your thread might be old. Thread loses moisture over time and becomes more and more brittle. Metallic thread is probably the worst for breaking that I have encountered because it is so twisty. It twists up on itself making a little knot (like rope twists on itself when you turn it in one direction) and that knot won't pass through the thread linkage and then it breaks. One of the best things I have found to do is not put my thread on the thread holder. Instead, I put it on the table beside my maching on the side that the wheel is on, pull the thread between the buttonhole post and it's guide, and then thread as usual. This gives the thread a little more room to unkink before it gets threaded into the machine. It's sort of the same principle as those thread stands that you see.
Posted on Mar 15, 2008
    Problem Solver:
  • 4 Answers
First, make sure that you are threading the machine properly check your manual for right thread path.
Secondly, make sure you are using an embroidery needle.
Posted on Jan 12, 2008
Embroidery not working correctly
Well, before I did all that (which may be necessary), I would take a piece of UNWAXED dental floss or hand embroidery floss and floss between the tension disks. You mentioned that you were suddenly breaking threads; there may be lint or loose threads or both seated between the disks, preventing the thread from seating properly. Then,
I would take the embroidery unit off and try to do some sewing with it, to see what results I got. If you can catch and bring the bobbin thread to the top with the top thread, I am doubtful that your timing is off. Sew a line of both straight stitch and zigzag stitches, and see if the stitches are balanced. If not, you may have a bobbin tension issue, and if so, most bobbin cases can be adjusted.
I think you'll find, though, that things will improve considerably when you have cleaned out the upper thread path and tension disks. Make sure when you do that, that your foot is raised, so that the disks are spread. Oh, a drop of sewing machine oil wouldn't hurt either--generally you should put a drop of oil for every 5 hours of embroidery.
Please get back to us to let us know!
Mar 14, 2014 | Singer Quantum XL-6000 Computerized Sewing...
How do you start embroidering a design where the thread breaks on a Bernina Artista 180 sewing/embroidery machine?
Most machines have a stitch counter, stitch forward and step back features. Check your manual and embroidery machine's screens for this.
IN case you have misplaced your manual I found this one for you. It's big so allow time to download.
http://www.itsastitchonline.com/mastery_on_the_web/Mastery_170_180_1-10-02.pdf
Sep 10, 2012 | Bernina Artista 180
Singer CE-200
since it is a embroidery machine I would suggest the technican
to be on the safe side
Jun 03, 2012 | Singer CE-200 Quantum Futura Computerized...
Skipping stitches and sometime the thread breaks.
Sounds like a tension problem maybe. Too tight tension will bend, and break the needle, especially if sewing fast in free machine embroidery, in this mode, the tensions have to be looser anyway. I can't explain why the wheel flagged and stopped, but experiment with tensions first.
Mar 27, 2017 | PfaFF Sewing Machines
Brother Embroidery machine thread keeps breaking
the needle thread tension is wrong
bunching up under the material indicates that it is too loose
Nov 17, 2017 | Sewing Machines
Tension on upper thread?
It sounds like the machine needs to be timed, seek out a sewing machine repair shop for this service.
Jun 07, 2017 | Baby Lock Ellure
Needle breaking-CE 250
I had that same problem and it was due to the thread being too tight. Put the thread net on your thread and it should be ok.
Dec 22, 2007 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
227 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Jon Piercy
Jim Goldsmith
Jim Goldsmith
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
