Question about Sony NSP-1 (2724265768)
Video problem The videos I am sending to my playlists are not appearing on the screen, except for the 5 minutes after it refreshes daily...does anyone know why this might be?
Unless you repeat them as many times as you need them to appear during the total playlist duration each video will play only once. Thus if your playlist is 30 minutes long and you have 5 minutes worth of videos you ought to set up your videos 6 consecutive times, when the playlist goes back to the beginning the whole cycle starts again.
Posted on Feb 24, 2009
Why does my gateway fpd2185w monitor screen go black after showing my desktop for about 1 minute
David
That problem is calle,refresh, thats happend when the monitor try to refresh the page or "clean" the page, you can set that in your video driver options. but if you don't have a video driver for your particular video card already installed, you don't have a right refresh rate and this delay, may happend.
Carl
Mar 22, 2016 | Gateway Computers & Internet
From chennai to tirunelveli, i want to listen songs through my nokia model 2626 mobile? But to chengalpet only it works?? After that it s not working and i am not able to listen song??Then what i want to...
there must be any problem in your songs playlist. you just refresh your playlist or otherwise make a new playlist. If this don't work then i cannot say anything
Apr 12, 2011 | Audio Players & Recorders
PROBLEM 4 BLACKBERRY 8520 hello guys! my problem is when i add / del videos it doesnot refresh in the video playlist. it shows old video file names.... also in PICTURES it doesnot show all...
This problem has something to do with the program or firmware of the phone.
For temporary solution:
- After deleting / adding videos, try to remove the battery from the phone while it's ON. Then after 5 minutes, put the battery back and turn the phone back ON. The list should be refreshed.
For permanent solution:
- Contact the manufacturer and ask for the latest version of firmware that you could load into your phone.
Good luck and have a great day!
Jan 02, 2010 | RIM BlackBerry Curve 8520 Smartphone
On the intro screen it freezez and eventually goes to the next screen and says refreshing database but it dosent refresh
This seems to happen when the database gets corrupted.
1. Turn off the player.
2. Plug the usb cable to the computer, don't plug it to the player.
3. Slide the lock switch to the right, you will see an orange strip.
4. Hold the menu button to start the player. Don't release it yet. Wait until a shutdown message appears and the player goes off again.
5. Plug the usb cable to the player end. The player should go on again. The player should mount as a disk on your computer. Find this disk and back up its contents.
6. Format the player, as explained elsewhere.
7. Disconnect the usb cable. This time the database should refresh properly. Once this is done, slide the the lock switch to the left and turn off the player.
8. Turn the player back on. It should work, but you will have to load your stuff again.
9. Redo steps 1 to 5, except that now should copy your music, videos, etc, back into the player.
10. Repeat step 7.
11. Turn the player back on. It should work again.
Dec 10, 2009 | SanDisk Sansa e250 MP3 Player
How can i get videos on my mp4
There's an online manual for COBY mp-c7095 in pdf format:
http://www.cobyusa.com/files/manuals/MPC7095_MN.pdf
1. Use the video conversion software from the CD for adjusting
video to correct size before transferring to the player.
2. Check the system requirements for video conversion on page 34.
The conversion software in zip format can be downloaded with this link:
http://www.cobyusa.com/files/software/MTVVideoConverter_Ver1.12.11.zip
Once video is converted u could use Windows Media Player 11 for
transfers. A short guide on WMP11 for putting files onto the device:
1. Have WMP11 always on top for "drag and drop" usage
Right click in the head of the WMP11 page:
in Tools > Options... > Player : select "Keep the player on top ..."
Restore Down the size of the WMP11 screen and adjust the size on the
edge(s) as you require for your screen.
2. in [Library] mode: under Playlists "Create Playlist" e.g. "My Playlist"
and Enter: "My Playlist" is added on the right screen side.
3. Open your data maps and ad files by drag and drop method
onto the right saying "Drag items here"
4. when ready adding files in [Library] mode: "Save Playlist"
5. in [Sync] mode drag e.g. "My Playlist" under the connected device
and "Start Sync": wait until al files have synchronized: a message
will show up when you can disconnect the player.
Sep 12, 2009 | Audio Players & Recorders
PS3 wont display anything
it sounds like your graphics card is fried. since it is integrated into the motherboard, there's not much you can do except send it to the factory or buy a new one.
Aug 17, 2009 | Sony Playstation 3 (PS3) Console
TH1602 took too much time on searching songs in memory card
This happened to me as well. You just have to wait it out. If it doesn't workin about 4 or 5 minutes, then it's frozen for some reason. Hope this helps :)
May 31, 2009 | RCA TH1602 MP3 Player
CTX P772 17" LCD Monitor Problem
This is caused by sending a video signal to the screen at a refresh rate higher than 60hz. A LCD Doesn't refresh the image by scanning from top to bottom like a traditional CRT or picture tube. They are hard set to 60hz and can not understand anything else. Setting it to anything else will cause it to not display a video signal, picture tearing (little blocks with horizontal movement), Offset video or convergents issues (colors appear offset giving it the 3d movie look with out glasses on)
To fix it you need to go into your operating systems display settings and pick out a LCD monitor with a refresh rate of 60hz
Hope that helps
May 12, 2008 | CTX P772 17" LCD Monitor
ThinkPad T21 and S-Video Output
the lcd display screen has to be set to 1024x768 60hz refresh rate 1st to be able to send the signal to a tv.
then try the function/monitor on keyboard or boot with it connected.
Apr 13, 2008 | Lenovo ThinkPad T21 2647 Notebook
Sony NSP-1 (2724265768) Logo
104 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
