Sharp AR-M237 Grayscale Copier
Problem for Sharp AR-M237 Grayscale Copier
Error code F6-10
By Diamondgeo on Dec 13, 2007
error code F6-10 comes up on screen occaisionally during the day. We turn the copier off and on and the code goes away.
What does this code mean?
Same Problem
Aug 05, 2008
-   I went to print and error code F6-10 showed up on the sharp screen.  I can no longer print, copy or fax anything from my Sharp AR-M237.  I have tried turning the machine on and off without success.   -   meagunn
Feb 28, 2008
-   Error code F6-10 comes up when I turn off and on the code goes away. Model # ARM-237. Do I have to get a new facsimile expansion kit?-   Tevman1
Best Solution
posted on Mar 23, 2008
Very Helpful)
thesharpman
Rank: Guru  Sharp Expert
Rating: 92%, 38 votes
THe battery on your fax board is below 2.90 volts you can replace the battery.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Dec 13, 2007
Very Helpful)
trickieone
Rank: Guru
Rating: 89%, 287 votes
The problem comes from a defective fax board.
Contact sharp for the resolution please.
Was this helpful?
Yes
No
Solution #3
posted on Feb 06, 2009
Very Helpful)
mickspaceNET
Rating: 88%, 114 votes
This is not "from a defective fax board"
98% of the time it is the Battery on the Fax Board..
Usually turning off your machine will make this go away,
Sometimes preventing your machine from going into Sleep Mode also helps.
The Fax Battery is much like the CMOS battery in a computer.
A large round thin battery, (much like a watch battery)
To replace this, the fax board has to be removed, The battery is Soldered to the Board, you have to unsolder the battery, then solder the new battery to the fax board, then reinstall fax board, then set jumpers on fax board. Turn machine on, do some settings, turn machine off, remove jumper from fax board. Then restart, hopefully you will not have to reset the county code.
Unless your experienced with this, do yourself a favor and call a tech..
Was this helpful?
Yes
No
Popular Solutions for Sharp AR-M237 Grayscale Copier
Questions and Unsolved Problems for Sharp AR-M237 Grayscale Copier
Do you recommend Sharp AR-M237 Grayscale Copier?
Answer
Answer
how to change catridge in printer
Answer
I have a copier that needs servicing. It is an old Xerox XC1040 model and it needs a new drum or... (More)
Answer
printer runs off of a network and anytime anyone hits print you get nothing but black pages but you... (More)
Answer
I can't find the "Star" Key on my AR 336
Answer
our Sharp ARM-237 prints out PDF files in gibberish: symbols, not words. What can we do?
Describe your Copiers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Copier Experts
Top Copier & Fax Repairmen
in Sedona, AZ
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
