Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super Capacity Plus Electric Dryer - White-on-White
Problem for Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super Capacity Plus...
Roper dryer won't start
By lilred5228 on Sep 19, 2009
Press the start button and it will not start but the inside light will come on It is an electric dryer.
Solution #1
posted on Oct 31, 2009
Not Rated)
LeeStoa
Rank: Guide
Rating: 100%, 1 votes
I would check the door switch first. That is the easiest and cheapest part to break and foul your dryer.
Was this helpful?
Yes
No
Solution #2
posted on Sep 19, 2009
Not Rated)
jsrock516
Rank: Guru  Whirlpool Washers & Dryers  Expert
Rating: 96%, 7533 votes
Since you did not post a model number it is difficult to determine what features your dryer has. However, here are some of the most common causes of a dryer that will not start:
1. Blown Thermal Fuse. Located on the blower fan assembly and is a white plastic looking component with two wires on it. A measurement across the fuse should read a short (0 ohms) if good. Make sure all measurements are taken with the dryer unplugged and the wires disconnected from the fuse.
2. Broken dryer belt. Some dryers are equipped with a broken belt switch that will shut the dryer off in the event of a broken belt. This prevents the belt from wrapping around the drive motor shaft. You will need to open the dryer and do a visual check to determine if the belt is still in one piece around the drum.
3. Broken door latch. You can usually tell if the latch is working properly by leaving the door open and toggling it with your hand. If the drum light shuts off when depressed, more than likely you don't have a door latch problem.
4. Bad centrifugal switch on the drive motor. The drive motor has a centrifugal switch that engages when the motor begins to spin. Some dryer motors have a separate centrifugal switch that can be replaced, while others have an internal switch which requires the entire replacement of the drive motor.
5. Bad drive motor. Commonly caused by failure of the internal centrifugal switch or bad motor windings. I have found the main connector plug on the motor loose at times causing the dryer to fail too.
6. Bad start switch on the control panel.
7. Bad control board on the control panel (if equipped). Not all dryers have a control board. Some only use a simple start switch.
I hope I've given you enough items to think about. If you have questions, or require additional assistance, please post back with your model number so that I may be able to provide you with better assistance. I hope this helps.
Was this helpful?
Yes
No
Popular Solutions for Whirlpool Duet 7.0 Cu. Ft.
Questions and Unsolved Problems for Whirlpool Duet 7.0 Cu. Ft.
Do you recommend Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super Capacity Plus Electric Dryer - White-on-White?
Answer
Answer
my whirlpool 9500 series steam dryer is only two months old, and a know under the light is leaking... (More)
Answer
whirlpool duet electronic electric dryer GEW9200L will not heat--all obvious things changed: the... (More)
Answer
Answer
new whirlpool duet steam dryer door will not stay latched and causes dryer to stop
Describe your Dryers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryer Experts
Top Washer & Dryer Repairmen
in Tulsa, OK
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Your name:
Your email:
Your friends email addresses: (e.g. Julie@email.com)
(Separate email adresses with commas)
Message:
Cancel
