Question about Sony Ericsson K610i Cellular Phone
Sony ericsson how do i get into the speaker because i have glue in the speaker and have sound problems
Take of the bettery cover and just to the left of the phone there is a play button on the side . get a fine pointed screwdriver and insert it in between it and the back of the cover and pop it off . there is a little cover over the speaker with a tiny slot at the bottom right. use the screw driver to lift this up . then do the same with the speaker grate . now u can get at the speaker or unclog the grate
Posted on Jan 10, 2008
Fix a torn speaker cone?
If it is a woofer, you would probably fix it quite easy. If the speaker driver is used for both bass and midrange, you have a problem.
Fixing a speaker cone is depending on the material. If it is paper cone, it is very easy by using paper that you glue with wood glue (White water based glue) on to the cones rear side (for estetic reasons).
A midrange or bass/midrange driver is operating in frequencies where the cone starts to break up. Not torn apart, but the break up frequency is the frequency where the inner and outer part of the cone not longer follow each other in the same direction. These properties of a cone determine the sound of the speaker which is that type of speaker drivers "identity". Messing that identity up, you end up with a speaker that does not sound as the original one.
Remember that cross over network used to split up frequency ranges, not only are lowpass, bandpass, and highpass filter, but they also filter irregularities where the speaker driver is not longer providing a linear frequency response (Its characteristic sound).
If the cone is polypropylene, there isn't much glue that bite on that material.
May 02, 2016 | Audio Players & Recorders
HOW DO I BREAK APART THE SOUND STICKS TO REAPPLY THE BACK CASINGS OF THE 1" DRIVERS. IS THERE A WAY?
If the backs of your 1" drivers are off, they're broken, and you need to replace the drivers.
Nov 02, 2014 | Harman Kardon SoundSticks II Computer...
HOW TO GLUE SPEAKER BACK TO BASKET
It sounds like your speaker surround blew away and separated from the speaker cone and/or housing. I'm in the process of fixing one my speakers by replacing the surround.
Generally, when this happens, you'll want to completely replace the speaker surround (the outer ring that allows the speaker coil and cone to travel in and out, usually made of rubber or foam rubber). This isn't necessarily super difficult, it just takes some time, skill and patience, if you want to avoid messing up the speaker and sound from it.
Inspect and repair your existing speaker:
1) Measure:
a) the diameter of your speaker cone (outer edge of the angled piece that goes inward toward the center coil) and the
b) diameter of the speaker housing (the metal "frame" part the speaker surround glues to, which is usually where the speaker mounting holes are located).
Note
whether the area on the speaker cone where the surround connects to is flat or angled.
2) Ordering: You'll want to purchase the new speaker surround to match the similar material you've already got, as close as possible to the exact dimensions you measured in either flat or angled for mounting to the speaker cone.
SpeakerWorks.com tends to be a bit more expensive than others than can be found online, and they will normally have what you need. Their speaker surround repair kits normally come with instructions, surround, glue and a little brush. I found hunting around can save 50% or more.
3) Gluing: Get yourself some Aleene's Tacky Glue (online or in craft stores), and make sure you don't use too much or too little, applying in a uniform coat on one surface, then applying gentle pressure to get the surfaces to stick, and allow it to dry completely for 24 hours.
IMPORTANT: This can be tricky, so be patient, or you're buying a new speaker. If you don't feel comfortable, take it to be repaired properly.
Typically, you'll want to start gluing the new speaker surround to the outer portion of the speaker cone, either on the underside or inside, as it was with the prior surround. Make sure it's centered, applying just enough glue with a brush to insure it holds and you can still slide everything around slightly into proper position. Gently move the speaker in and out to make sure nothing is rubbing. Allow this to dry for a full 24 hours, and do NOT attempt to glue the surround to the housing until after the cone glue is completely dry.
Now, it's at least 24 hours later, you can do the same thing by applying an even layer of glue to the surround (or onto the frame) to complete the new surround replacement. Apply light pressure to make sure it's centered, again gently moving the speaker in and out to make sure nothing is rubbing. Allow this to dry for 24 hours, just like before.
I know, impatience makes this difficult, but then you don't want to be doing this all over again by trying to move too quickly. Worse yet, you can end up completely destroying your speaker cone.
The nice thing about that tacky glue is is holds well and allows you to position things for a while before it sets. Just remember to allow the proper drying time, which is always way longer than the dry glue you can see.
Remember to defer to a professional repairman if you do not feel comfortable doing these repairs yourself.
I hope this helps!
Feb 16, 2012 | Kicker S15L7 Car Subwoofer
How can i open the speakers? I want to change the cable of my dell a225 speakers.
Dell A225 speakers.
What I used to disassemble / assemble mine:
Sewing needle;
Soldering iron;
Philips screwdriver;
Hot glue gun;
Have patience.
Use a sewing needle to pull the front grill of the speaker, carefully by the edges. Do not pull too hard, go pulling around the screen to prevent warping.
Loosen the two small screws at the base of the box.
Loosen the six screws you see, the top four has a glue to prevent vibrations.
The card is only snapped, just pull it.
Use the soldering iron to soften the hot glue that holds cables and presto, its sound box is open.
When mounting, use the hot glue to hold it again, to avoid vibration at the time of use.
Sorry for the lack of pics.
Hugs from Brazil and good luck!
Jun 19, 2010 | Dell A225 2 Speakers
I want to know how to open my dell model A225 computer speaker
Dell A225 speakers.
Sewing needle;
Soldering iron;
Hot glue gun;
Have patience.
Sorry for the lack of pics!
Jun 04, 2010 | Dell A225 2 Speakers
I have a 15inch kicker cvr sound comes out great but when the bass hits it rattels is there any body that can fix it
You can fix it, there is a pretty easy fix with speaker until you can buy a new one. Take some old news paper and some glue and glue the seems with the newspaper. you will want to use roughly about 6 strips per section that is broken, make sure that you are using super glue and everything is correctly glued
May 31, 2010 | Car Audio & Video
My altec lansing mx5021 speakers problem
The problem I have found is the contact glue between the back panel and circuit board inside the sub woofer. The glue becomes conductive after some time (2 years..!!) and needs to be scraped away from across tracks, you can tell the problem areas as the glue is pale yellow but goes brown and conductive over time. Good luck.
Regards
aj
Feb 18, 2010 | Altec Lansing MX5021 Computer Speakers
Busted cone (i think)
First try swapping the leads on your source, powering the left speaker with the right channel, and the right speaker with the left, if the problem follows, then the issue is with your source, and not the speaker.
If the cone is torn, then try to patch it, using some basic glue and several layers of tissue paper. White Glue, embed tissue paper in the glue, more glue,embed tissue paper in the glue, do this several times building up several layers. Guessing this is a standard paper cone...
Now if you are still having the issue, could be that the woofer is damaged. Look for a replacement.
john
Aug 19, 2008 | Alesis M1-Active MkII Main / Stereo...
Thanks
i dont think that the buzzer speaker is broke i believes its just off of alignment with the molding track inside the phone if your careful and you want to pursue opening it up i caution this cause this is very delicate inside static elect. can short your phone when opened
buzzer speakers are durable and hard its just ear wax and sweat in the ear piece can break down the glue they used to mount the buzzer speaker over time this and a dropped phone will displace the speaker
if you open look at mother boards sides together there should be 2 small solder points where speaker goes place speaker in a proximate to these points eye ballin it dont completly close phone yet once sound has come back to levels you want then use a little super glue to spot glue the speaker into place
but over all i wouldnt recommend opening it let the service provider tech handle that one
May 09, 2008 | Motorola Mobility RAZR V3
Loose jack on subwoofer -- fixable?
Hi, since you pinpointed the problem, the correct solution would be to replace it. However, if you want to try a temporary remedy, try using a glue gun to put glue around the jack's outer housing while connected to the back panel. Make sure that the glue dries in the correct position (where there is sound from the satellites). It is possible that the sound waves produced by the subwoofer loosens the connection. It might also be helpful if you lock the cable in place so that it will move so much and strain the jack. Regards.
Jan 09, 2007 | Logitech Z-3 Computer Speakers
Sony Ericsson K610i Cellular Phone Logo
63 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
