Question about SanDisk Sansa e250 MP3 Player
No power no nothing
I just bought my e200. 2 days after initial use, i was charging and deleting some music downloaded while connected to my laptop. Suddenly while connected, the laptop was shut down automatically coz it was low battery. When i started the laptop again, the e200 player doesnt have anything.. no power, no connection and cant even be detected by the pc... please help me what to do..
  • derbyhead Dec 19, 2007
    after I connected my mp3 player to my computer. a tab appeared saying the computer cannot recognize the device, then all of a sudden my player just went off and I cannot turn it back on again. NO POWER at all. even if I use my own recharger for the mp3, same result. I cant tun it back on.
    Sergeant:
    Champion:
  • 317 Answers
When the e200 is taken out of the package ensure the "Hold" switch is not in the lock position.
When looking at the front of the player, the "Hold" button on the top should be pushed all the way to the left.
After pushing the "Hold" button to the left, then press the "menu" button to power on the device.
Also, plug it in for a few hours to charge the battery.
Posted on Dec 16, 2007
Toshiba a 350 will not charge while open
Do one thing, if possible of course. Download any Linux distro and create a bootable USB or DVD/CD with the distro, Once that is all set, have your laptop to boot from the USB port, reboot the laptop with the USB already connected. Once booted, click on Live disk or Try before installing, this won't change anything the HDD so there is nothing to worry about. While testing the live disk, connect the charger or power supply to the laptop with the lid open to see if it charges. If it does, then it's a problem with Windows it self. Right now is kind of hard to explain since I'm not on a Windows machines now. But do try it.
May 16, 2017 | Toshiba Satellite P15-S420 Notebook
Recently bought an acer one notebook all it does is turn off & on
As the on off led blinks there is apossibility of loose contact with battery contacts terminals. First remove the battery then reinsert it in the laptop and connect it properly to the power adapter check whether its charging indicator turns on then switch on the computer
Aug 22, 2009 | Acer Aspire One PC Notebook
Freezing up on initializing; wont charge; computer not reconizing it
Hi There
You Can Download Free MP3 From Youtube By This Site : video2mp3.net
If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
May 20, 2009 | RCA opal MP3 Player
HD6330 GoGear seems to have a virus
Chris, The reason the gogear shuts down is the battery needs charging. The lead that was supplied when new, was fitted with three plugs on it, one went into a power outlet (AC) one plugged into the base of the player, the last one (USB) into your P.C.
You should also have a CD with Philips device manager on, this needs downloading to your laptop, Windows media player version 10. is the only version Philips recomend for up / downloading music to the player.
Dec 01, 2008 | Philips GoGear HDD6330 MP3 Player
I cant put music onto my yp-k5j
may be ur pc windows has problem....i have also same problem for so many days when i connect it with my pc it doesnt show anything then i changed my windows then i connect it it shows samsung portable device in "my computer"...then enjoy with ur uploading
Aug 05, 2008 | Samsung YP-K5JAB MP3 Player
Sandisk 240 1.0 gb
I had this same problem. What I ended up doing was going into My Computer into the device itself and seeing what showed up. It appears a few new songs I popped on there the day after were appearing but nothing else. I deleted all the files, unplugged it from the computer and let the library update, old songs were still playing. Plugged it back into the machine and voila they showed up.
Aug 05, 2008 | SanDisk Sansa m240 MP3 Player
No power,not charging
It is most likely that there was nothing wrong with the original adapter/charger. What I suspect is there could very well be a loose connection more aptly a cold solder among the pins of the power jack that is soldered to the motherboard. Normally, this jack would have two (2) pins and your description "...unless the cord was in a certain position..." indicates that one or both pins are not connecting right to the motherboard solder points.
It is relatively easy to resolder the said pins. What would be more challenging would be opening the laptop and exposing the motherboard's to be able to do solder work underneath.
Should you venture a DIY, then you would be needing a set of jeweler's screwdrivers and a soldering iron and a little lead. Should you be uncomfortable and unfamiliar with electronic works, perhaps your best bet would be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 11, 2008 | Acer Aspire 3680 Laptop
Diamond mp3 model dsm941
i tell you connect to the computer your device
and right click on your device and format it i have the same prob now it fixed
Nov 17, 2007 | Audio Players & Recorders
Sansa won't charge or load.
Plug it into the computer (the cord you would use to charge it and transfer files), and hold down the power button for at least 15 seconds. The Sansa should then begin to turn on and start charging. :)
Aug 07, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
26 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
