Dell Precision T3400 375W 32bit Computer Workstation  PC Desktop Logo
Posted on Sep 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I add a second HD
I have a Dell Precision T3400 desktop and I want to add a second HD. The primary HD is a Seagate and the second is a Western Digital
  • Anonymous Mar 19, 2014
    I have a dell precision t3400 what do I need to hook it up to my tv
Anonymous
Level 2:
Scholar:
  • Expert 49 Answers
  • Posted on Sep 19, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
49
Questions
0
Helped
12742
Points
111
Connect second harddisk as slave as you mentioned using the jumper setting from the manual or on the harddisk. Make sure the master harddisk jumper setting for "Master with Slave present " . Connect the power supply cable. Most of the computer operating system's would detect the new harddisk once pluged in. If the new harddisk needs formatting before use format it before you can use it. To format the new harddisk right click the new drive letter form "My computer " window and click format. Select appropriate type for the formatting new harddisk. You can access the new drive now to store you files.
Eric Spencer
Level 2:
Scholar:
  • Expert 142 Answers
Eric Spencer
Expert
Level 2:
Scholar:
Answers
142
Questions
0
Helped
76137
Points
386
Turn the machine off
Open the case
Look to see if there are IDE connector (Wide Flat cable with a connector usually grey)
If this is not present look for a SATA connector usually a small red or blue wire similar to a cat5e network cable
Scew your HDD in place in the rack connect the cable either IDE or SATA
If you have an IDE drive look for a 4 pin female connector from the power supply
If you have a SATA drive look for the connector from the power supply
Once all is connected then reboot you computer typically your bios should auto detect it.
Let me know what happens from here
Reset bios password of DELL T3400
YOu can remove the battery of your bios it will reset your bios password.
1helpful
Tool prepair Bios Dell precision T3400
If this desktop can boot to BIOS properly, then you can download the BIOS file from Dell's website, make a bootable media (using other computer) and use this media to update your T3400 BIOS.
No puedo intalar xp t3400 pantallaso azul
Seguramente hay un problema con la tarjeta de Video, reemplazala y trata otra vez.
Have maxtor 40gb hd want to add 2nd WD hd in DEll dim8200
(if both drives on the same cable):
Your boot drive goes at the end of the primary data cable.
Your second drive goes on the middle connection of the same cable.
The red stripe on the data cable needs to be closest to the power connection (red stripe to pin 1).
The jumper on the boot drive set to master.
The jumper on the second drive set to slave.
Look in the BIOS to make sure it sees both harddrives.
Boot the system.. it will need to be partitioned and formatted if not already..
Regards..
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
