At the end of a wash cycle it was making a noise I had never heard before. When we opened the door it was full of dirty water. We pulled out the filter and it doesn't appear clogged but wondering if the motor isn't working.
sounds like a drain pump ... you may have a damaged drain pump or something stuck in it..
turn off the power the the dishwasher...
.remove toe panel and you can see the drain pump on the left ..you can remove plastic hose on the left to drain the dishwasher ...be sure to catch the water will come out ... you can remove drain pump press release tab and turning drain pump ...hope it helps
not taking in water to the interior of dish washer. Intake valve ok and float switch operating...
(More)
not taking in water to the interior of dish washer. Intake valve ok and float switch operating ok.Does the full cycle but no water in.
when finished its cycle the dirty water does not drain from the dishwasher. I used pipe cleaners to...
(More)
when finished its cycle the dirty water does not drain from the dishwasher. I used pipe cleaners to see if hose is blocked but it is'nt. i have to manually soak out all the water. could somebody tell me how i get the hose free from the washer to check inside it. or is the problem inside the dishwasher. if so how do i unblock the internal drainpipe/hose. thanks.
My Seimens dishwasher was inherited at least 4 yrs old I guess, , and I love it. Last night it got...
(More)
My Seimens dishwasher was inherited at least 4 yrs old I guess, , and I love it. Last night it got stuck on a cycle and there was a loud grinding/whirring noise, as if something was turning over. But no water. When turned off and on, it started where it had left off, the time was stuck on the cycle, usually it would go to zero and allow you to chooses the programme you want. Is v expensive, wonder if it is worth fixing?
