Question about Polaroid FLM-2632 Television
Polariod FML-2632 LCD TV
The picture looked animated while watching real live tv. I corrected it on the menu by resetting factory settings on two separate occasions. The third time I could not fix it. Polariod would not help because I was 3 months out of the one year warranty. The repair shop diagnosed that the control card was not working and needed replaced, $350-400. Where can I get the part and hopefully for less money?
Chris Mc
3 Suggested Answers
  • 2336 Answers
SOURCE: polariod 3200
I service these power supplies.
If you need to have it service you can let me know.
Posted on May 01, 2008
Raider2845
  • 11 Answers
SOURCE: Polariod LCD FLM3732 does not show picture but has power
Its possible that you have some bad Electrolitic Capacitors. They are a very easy fix and very easy to see if they are bad. I have some vids posted on youtube on the fix for this. It only costs a few dollars to do. Just search on youtube for flm3732 repair or go right to my channel youtube.com/raider2845 and watch the 5 short vids I had posted.
Posted on Dec 25, 2009
Picture dimmed. can see the picture and in menu increased the backlight to max but did not go back to normal. checked eco settings and did factory reset. still very dim but can see the picture.
Yah kindly follow this tip. After loosing the back cover when the tv power cord is removed from power socket, check for bulged or defect power capacitors in both the primary & secondary side of the power pack if found any kindly replace it with the actual or equivalent value as this electrolytic capacitor defects is much common for Samsung power packs
Apr 04, 2016 | Samsung UN46EH5300 - 46" LED-backlit LCD...
There is a Video problem with my Samsung LCD. The sound is clear but Colour Balance Setting is disturb. The Colour is mixing with each other. Can You tell me the procedure for My TV Setting?
Before you set up try a reset
Resetting The Picture And Sound To The Factory Settings
as far as advanced settings are concerned, set the contrast backlight and brightness so you can see the best blacks without it looking too milky, the best whites so you can discern the whites and they aren't clipped, then look at colour balance if it looks wrong when you turn the colour off.
it shouldn't be very far out in factory settings. Operation How To Change The Picture Settings On Your LCD TV LCD TV...
May 12, 2014 | Samsung LN-S2651D 26 in. LCD Television
How can i improve my tv LG LH20 42" in terms of
There are a couple of things that you can try to see if the image clears up, or is to your liking. You can adjust the resolution of the picture via the menu in the tv. You can also try resetting the tv to the factory settings, via the menu. You can also try auto configuration, which is also a menu item. If you are using a dvd/blu-ray player, use the HDMI cable for optimum picture quality.
Mar 08, 2011 | LG 42LC2D 42 in. LCD HDTV
What are the menu settings supposed to be at for the color, picture, what do I do if the color is not right, pickish and green
Go to tv menu go to screen setting turn screen contrast to the max and screen brightness half midway point like 55.Tv real old like around ten years?Watches alots daily like 6 or 7 hrs a day?The tv CRT-(tv tube) might be to old,the radiation colors guns R,G,B insisde might not work as well as before.Have a reset setting in the colors setting?Go down to that press that,to restting for the factory colors setting.Or tries add more blue,a bit less green and red,see how that turn out?
Feb 05, 2011 | Panasonic CT-32G23 32" TV
I change the color setting in my tv by accident and now i dont get green or red to show it shows brown how do i correct the setting
hello there,
Your TV has three automatic picture settings ("Dynamic", "Standard", "Movie") that are
preset at the factory.
You can activate a Picture Setting by making a selection from the menu.
1 Press the MENU button to display the menu.
Press the ENTER button to select Picture.
2 Press the ENTER button to select Mode.
Press the ? or ? button to select the Dynamic, Standard, or Movie picture setting, then
press the ENTER button.
? Choose Dynamic for viewing the TV during the day or when there is bright light in the
room.
? Choose Standard for general TV watching mode.
? Choose Movie when watching movies.
Press the P.MODE button on the remote control to select one of the standard picture
settings.
3 Press the ? or ? button to select Contrast, Brightness, Sharpness, Color, or Tint,
then press the ENTER button.
4 Press the ? or ? button to decrease or increase the value of a particular item.
? You cannot adjust the Tint in DTV, Component or HDMI mode.
5 Press the ENTER button to return to Mode.
6 Press the ? or ? button to select Color Tone, then press the ENTER button.
7 Press the ? or ? button to select Cool2, Cool1, Normal, Warm1, or Warm2, then press
the ENTER button.
? When the picture mode is set to Dynamic or Standard, Warm1 and Warm2 cannot be
selected.
Resetting the Picture Settings to the Factory Defaults
8 Press the ? or ? button to select Reset, then press the ENTER button.
? Each picture mode can be reset.
Press the EXIT button to exit.
there ya go if you need anymore help let me know and don't forget to Rate
Jan 26, 2011 | Samsung TX-T3093WH TV
I have new Philips LCD 47"tv and on the bottom
HI:
You may of turned on the Philips Easylink which is for connecting Easylink-compliant devices that are connected through HDMI connectors can be controlled by a single remote.
You can restore the default picture and sound settings of your TV.
1. Press MENU
2. Select SETUP> Installation>Then Factory settings.
3. Select Reset to start resetting
5. Press OK.
6. Press MENU to exit.
Jan 24, 2011 | Philips 42PFL5332D 42 in. LCD Television
Polaroid FLU-2632 LCD TV full HD 2 HDMI problem
You could try pressing the source button on the remote to see if that brings it up.
Also the TV may have got itself in a muddle. There will be a way to reset it to factory setting. If you can get into the TV's setup menu there ought to be an option buried somewhere to do that.
Apr 28, 2017 | Polaroid FLM-2632 Television
Samsung Le40a556 factory reset
with tv in standby press INFO / MENU / MUTE / STANDBY on remote the tv will come on in factory menu settings look for reset use DOWN NAV KEY until highlighted and press RIGHT NAV KEY
to exit settings press standby the tv will come on and follow on screen instructions
DO NOT CHANGE ANY OTHER SETTINGS TV WILL NOT WORK IF CHANGED
Dec 13, 2009 | Televison & Video
On my lcd tv the color went wild , the people
Reset the color settings back to factory defaults...
Sep 24, 2009 | Televison & Video
No sound dell 32in tv
These are the answers straight from the dell manual. Ensure that the audio cables are firmly connected to both the audio input connectors on your LCD TV and audio output connectors on your PC or Video player. If on certain TV channels you receive a picture but no sound, this means that you do not have the correct TV system. Modify the SYSTEM setting. Check if TV volume is turn off of muted Connect the audio cable securely Audio cable is connected incorrectly Verify that the audio source is selected correctly in the OSD
Jul 31, 2007 | Dell W1700 17 in. HD-Ready LCD Television
Polaroid FLM-2632 Television Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
