Question about RCA HD50LPW175 50" HDTV
Purple Lines Two days ago I was watching TV and purple lines started appearing. They 2" wide and horrizontal. They are in columns covering the entier screen. Sound is great but you cant see a clear picture because of the puple lines. Does anyone have any suggestions on what the problem might be? Thanks for any help,
  • 1 more comment
  • crzy4help Dec 14, 2007
    This is on the HD50LPW175 50"
    Thanks for the help.
    The sound is now distorted. Will the formatter board also help with the sound?
    Do you have any idea what the cost is for a formatter board? Are we talking over $500.? We are considering just buying a new TV. What would you do?
  • 4,102 Answers
Hi i have been researching your problem and it seems this happens alot on these types of telly the problem people have been having is with the pcb formatter board and once this was replaced it solved the problem but when you get this replaced make sure to tell them to check the resistors leading to the pcb board as a blown resistor can cause the problem with the pcb board so get these checked as well.
Posted on Dec 14, 2007
  • paul proctor Dec 14, 2007
    Hi yes it will solve both problems but found out its not something you can do yourself as the faulty part needs repairing as they dont replace them it could a bad cable connection from driver ics but this is something you will need to call someone out as locating the exact fault without having experiance in fault finding and also having relevent equipment it will be difficult.
    This is a very common fault with all makes and models of this kind of telly hope this sorts you out and you can tell the person you ring the exact fault.
    Also if you take the tell their yourself it will save you money on call out charge and also charge for them to pick up and deliver the telly from and to your house.
    hi id say at a guess about 300 but depends on make and model you might be lucky though if you goto repair shop they usually strip down tellys and keep all good parts so they might have what you need might be wishfull thinkng but you never no best thing to do is ask around and see what prices you get offered but usually the repair only last about a year or so.
    So you could look into repairing and get prices then see if in the long run its worth doing or not sometimes people repair them and then never have another problem but every telly is different so you need to decide is it worth it at end of day.
    If it was me i would price up repair first you might be suprised and get it done cheap then its worth doing youll have to look into it a bit.
    Its not something the average person can do though so shop around and see what price you get
The plasma is freeing when i turn ext
You have a couple of issues. The freezing up is a defective main board. However the vertival lines and purple bar is telling you that your panel is defective. It is time to start shoppiing for a new TV.
Mar 15, 2013 | Televison & Video
How do I get rid of purple and green wiggly lines? The black screen that appears when switching between channels was green a couple of weeks ago, that problem stopped after I unplugged the set for a while....
You have a bad LCD control board,It overheats and causes colored lines,screen to darken,or the color go floresent. Also check the power supply for bad caps.
when you have it apart.They usualy go bad on these tv's. It will cause the tv to take longer to come on.Or you have to hit the power button several times to get it on.
Oct 26, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
My fujifilm s5000 has purple lines coming up on the screen and when i take a photo. what could be wrong and is it easily fixed?i need to get it fixed as i cannot afford a new 1
If the purple lines only appear when you point the lens INTO the sun or light source, that would be why they appear in the photo. If you have the sun/light source behind you and the purple lines still appear on the screen and in the photo, it's time to get a new camera.
Aug 19, 2009 | Fuji FinePix S5000 Digital Camera
Purple and green rolling lines after lightning storm
I have exact same problem...other posts have cited improper grounding from the Cable...which makes sense as the problem does not occrr with the DVD...I have not figured out how to fix it though...
Aug 12, 2009 | Panasonic TH-50PX75U Plasma HDTV
Green purple and blue bars rolling through screen
It is probably the main total assy needs to be replaced.
Jun 26, 2009 | Samsung LN32A550 32 in. LCD TV
Vertical purple lines appear when watching tv but not dvd
You unit should be under warranty. contact the manufacture for the nearest authorized servicer.
Jun 26, 2009 | LG 42LC2D 42 in. LCD HDTV
Rolling lines on screen
Sounds like the power supply has a bad capacitor. This problem can inject excessive 60 hz from the AC line into the vertical stabilizing picture system. The hum also my come from the same reason, bad or leaking filter capacitors. Cheaper just to buy a new TV or borrow another TV and connected to your system to see if the problem still occurs.
Mar 16, 2009 | RCA F36668 36" TV
Vertical lines in LCD tv screen
Need to check the two things.
1st -- need to exchange T-con Board.
2nd -- need to exchange the cables between T-con & LCD panel or
between T-con & Main(LVDS cable)
Jan 29, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Green and purple scrolling lines
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 27, 2017 | Samsung LN52A850 52 in. LCD HDTV
Purple scribbly lines it left hand corner of tv screen
if the lines on your screen looks anything like the image below, you do have a problem with the lcd, problem is you need to replace what is called the light engin. unfortunatly the price of this part is just about as much as a new replacement tv. Get a sceond opinion fron a sony service center near you, as i cannot see your picute. good luck
Dec 22, 2006 | Sony XL-2100U Projector Lamp for...
RCA HD50LPW175 50" HDTV Logo
74 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
