Gateway 507GR PC Desktop
Problem for Gateway 507GR PC Desktop
Gateway 507gr power issues...
By jh_tanigawa on Sep 19, 2009
I've just replaced the power supply in my gateway 507gr, however my computer will still not power up. Light on power supply is on; light on the motherboard is on. any ideas?
Comments:
Sep 19, 2009
- Removed the 12v ATX cable; cooling fans still not spinning...
Sep 19, 2009
- 12v processor input is plugged into the power supply. I simply removed the old PS, and installed a new one. No dice.
Best Solution
posted on Sep 19, 2009
Very Helpful)
MaverickIT
Rank: Wiz
Rating: 83%, 26 votes
Unplug the four-pin 12V ATX cable from the motherboard, and see if that makes it power up any better - it probably still won't work entirely, but see if it gets your cooling fans spinning. If so, you probably have a bad motherboard, with something shorting out the 12V power.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Very Helpful)
eric_tarbox
Rank: Guru
Rating: 93%, 22 votes
Is the 12V processor input plugged into the power supply¿ I will assume that you only removed the PS and it's connections and reinstalled it without removing any other connections. There may be more connections than I may have anticipated.
Was this helpful?
Yes
No
Solution #3
Somewhat Helpful)
byteguy
Rank: Guru  Gateway Computer Hardware  Expert
Rating: 87%, 367 votes
I assume you are using a new power supply.
Now unfasten everything from the motherboard (except video) and try to power it up. That is, disconnect the hard drive, CD, and any add-in cards. If it still doesn't power up, I would try to swap out memory. If you still have no luck, you will probably need to replace the motherboard.
Was this helpful?
Yes
No
Solution #4
posted on Nov 11, 2009
Not Rated)
pvtidy
Rank: Guide  Computer Hardware  Expert
Rating: 0%, 0 votes
Just a post to verify the popular claims that bad capacitors in the power supply cause it to fail and also kill the motherboard. I found "NEW" motherboard and power supply for $30 each; and what else is there to say. Listen up: Intel augsburg motherboard, and the Athena 400watt power supply, both for 70 bucks. Amen... PV.
Was this helpful?
Yes
No
Popular Solutions for Gateway 507GR PC Desktop
Questions and Unsolved Problems for Gateway 507GR PC Desktop
Do you recommend Gateway 507GR PC Desktop?
Answer
Answer
I made a ecovery disk and it loads and then works, at the botom it says examining 19092 and I'm... (More)
Answer
connect to gnutella network
Answer
gnutella network
Answer
half of the screen has the start up and the other half is the desktop icons
Answer
problem connecting to Gnutella network Bearshare 5.2.5
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Gateway 507GR PC Desktop:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
