Question about IBM ThinkVision L170 17" LCD Monitor
How to reset to factory default - to solve blurred text problem
For the second time I've been placed at a workstation with an IBM Thinkvision Monitor, and the text is not clear, it looks the way fonts with "anti-alias" on look sometimes in graphics programs.
The first time I was lucky and stopped a tech guy wlaking by, and he found the "reset to faculty default" in the monitor settings, but I can't find that anywhere under the buttons.
Would be very glad to reset this so the text would be sharp and clear.
Thank you.
  • 1 more comment
  • Anonymous Jul 08, 2008
    Needs steps to get inside the factory mode settings- not the user preset defalut settings. Normally, for other vendors they have a series of key combination steps to get in the factory mode.
  • 81 Answers
Press the OSD enter button and scroll down to options. Factory reset is in the options sub-menu.
Posted on Jan 08, 2008
  • jgirard1 Feb 18, 2011
    Thanks for the most obvious of answers. We are looking for the factory button combinations to reset the internal memory and settings, not just the display itself.
Can't adjust the color, brightness or contrast so that there is a pure white color. Can this be fixed?
yes you can. Go to Menu, and follow the steps for adjust the color, brightness ,etc or restore the factory default in Menu
God bless you
Jul 31, 2013 | IBM ThinkVision L170 17" LCD Monitor
How to reset
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Oct 11, 2012 | Motorola Mobility Mb502 Blur t-mobile...
I have an Internet Connectivity problem which I believe was caused by resetting our D-Link WBR-2310 router. We have a strange, perhaps illogical network setup in our office. Although it was set up before...
It appears you are not using the wireless connections on both the routers and the reason for using Router B was that there were insufficient LAN ports on Router A to connect to the two workstations that are connected to Router B.
To simplify your network, I suggest you replace Router B with a network hub or ethernet switch and connect the two workstations to this network hub/switch, then configure these two workstation to Obtain an IP address automatically. Router A will then issue IP address to these workstations via the network hub/switch.
Jul 09, 2011 | Computers & Internet
17 lcd l170 black screen power on but no display
When powered-on, and *NOT* connected to a computer, most ThinkVision LCD monitors will flash, for a few seconds, the IBM ThinkVision "logo", before going into "power-saving" mode. If you don't see that, then it's time to spend about $120, and buy a new 19" (not 17") LCD monitor.
Apr 08, 2010 | IBM ThinkVision L170 17" LCD Monitor
IBM ThinkVision L191p after power on, remain black.
First place to chaeck will be power supply, the problem can also be caused by bad inverter circuits, bad lamps, see example of failed monitors due to bad caps, lamps, http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Feb 11, 2010 | IBM ThinkVision L191p (Black) 19" LCD...
Colours displaced
reset the settings to factory default. if it is a dlp, replace the colorwheel.
Nov 20, 2009 | Office Equipment & Supplies
Why won't my ibm thinkvision c400 wireless projector power on?
Try to check first the physical connection maybe its not plugged in properly. Use a different power cord.
Oct 22, 2009 | IBM ThinkVision C400 Multimedia Projector
IBM ThinkVision 17" Monitor displays for 1 second then black
This seems to be a common problem with these monitors. Have a look very closely and see if you can still see something there. From there, either send it to get repaired, or, if you are handy with a soldering iron, open it up and replace the 4 main capacitors (at least one of them will be "popped", but it is handy to replace them all.
In order to open the monitor, you will need to remove the stand, and make sure you get all of the screws out before attacking it with a screwdriver.
I have 5 IBM monitors at work with the same problem, and opening them up has shown the popped capacitors.
Again, only recommended if you know what you are doing. Screwing it up will leave you with nothing.
Jan 25, 2009 | IBM ThinkVision L170 17" LCD Monitor
IBM ThinkVision L170 17" LCD Monitor Logo
720 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
