Question about Max-Fridge STC55926 / STC55927 / STC55928 / STC55929 Beverage Cooler
Max-Fridge power adapter needs replacement
I have a Max-Fridge for which my power supply fried, but don't know where I can get a replacement or if I can buy a generic one somewhere. Any help would be greatly appreciated.
  • 4 more comments
  • Anonymous May 30, 2008
    same problem
  • pamelalemast Jun 23, 2008
    Same problem - 12 volts. Tried plugging in another outlet. Made sure outlet worked by plugging in other power-related objects. When the plug to the Max-Fridge initially stopped working, I tried another plug on the power strip. The Max-Fridge display flickered as if it wanted to turn on and then went completely dead.
  • majsharps Sep 07, 2008
    I have the same problem right after buying it.It seems to be very common with this cheap off-shore Max Fridge product. Has anyone found a replacement yet?
  • Kensmith Sep 10, 2008
    I loaned my Max-Fridge to our son and I got the unit back without either of the power cords. Do you have them for sale?
  • Adam072 Nov 08, 2008
    My adapter burned out and I need help finding a replacement
  • josseline Pierre Sep 03, 2013
    max fridge rf 1023 12 vlts power cord
  • 106 Answers
How many volts is it?
Posted on Dec 13, 2007
    I ha a max fidge 12 volts but i lost the power cord please help me to found an other one. thanks
What is Proscan 15LA12Q power supply output voltage and amps?
UpBright NEW AC Adapter For Proscan 19LA25Q 20LA11Q 15LA12Q LCD HD TV DC...
Price:$18.54 + $5.89 shipping
First check it or have the power supply check out with a meter. If you have 0 volts or it is dead then replace it. The main thing is the polarity of the tip, positive tip or negative tip IT MUST BE THE SAME or you will FRY YOUR TV. Good Luck.
Jun 04, 2015 | Proscan Televison & Video
On the 15-12-2014 i bought a lloytron 5 in 1 wireless headphone, the manual says i need a 4.5V DC adapter for mains but nowhere does it say the amount of (amps) needed before i buy one,since there are so...
I would think anything over 300 mA would be ok. But I would go for something around 1 to 2 amps.
As long as the voltage is 4.5 it doesn't matter if the current is 10 Amps or a 100 Amps. They will only draw as much current as they need. The maximum working current is only 30MA.
Max consumption current 30MA
Power Supply 2 x AAA batteries
Frequency 85
Transmitting Distance 10M
Complete Voltage 3V
Max working current 7.5mA
System mode RF
Power Supply 2 x AAA batteries or 4.5 DC not included
Dec 18, 2014 | Audio Players & Recorders
I bought my wii in singapore. the wii says 120V, but here in sri lanka the voltage is 220. without reading this i plugged in the wii. the red light came but before i activated it, i heard a BOOM from the...
It is possible that your power supply fried but everything else is still ok. Something like this could happen during a lightning storm. If you know someone with a wii, try to use their ac adapter (with a 120V adapter). If this works, then you just need a new power supply which is much cheaper.
Sep 01, 2011 | Nintendo Wii Console
I bought an Epson scanner from America with a power supply for 100v-120v can I still use this in Australia which has 240v. Regards ****
see the power rating on the power pack adapter. Unless otherwise stated,
most come with an international standard of 220v. I bet you can find an adapter with the right capacity that fits your scanner if that doesn't work.
Hope this helps
pls rate or vote this
Jul 05, 2011 | Epson Perfection V200 Flatbed Scanner
I recently got this laptop from someone who did not have the power supply with it. Can anyone tell me what the required power supply must output? I really don't want to fry this computer, so I want to make...
You need a charger with this features: 90W Laptop AC Adapter / Charger for HP Pavilion DV5-1125NR / DV5-1127CL Replacement
Diameter : 5.0 mm x 7.4 mm
Input Volt Type : AC
Input Volt: 110-220V (Worldwide Use)
Output Ampere : 4.74A
Output Power : 90 Watt
Output Volt : 19V
You can buy one at:
for $19.89 including shipping.
If this was helpful, please rate me.
Thank you
Jan 13, 2011 | HP Pavilion dv5-1125nr Notebook
No picture.
Your set may be fried, or at least the power supply or fuse(s). If you feel like you could work on it, open up the power supply (if it's outside of the TV) or open the set itself (if it's an internal power supply). Look for the fuse(s) (the little glass tubes) and pull them out and check them one at a time (in case they're different values and you forget which one went where). If any of them have a broken filament (the little wire inside of them), especially if they have any black soot or brown-ish stuff in them, then the fuse is blown and needs to be replaced with an identical value fuse.
DO NOT REPLACE FUSES WITH DIFFERENT VALUE ONES. I can never stress that enough. On the metal band, it says the current it allows. Match it up with another fuse (it'll be the same size and everything) and bam, that could fix your problem.
If it's not a fuse, then perhaps the filter capacitors in the power supply are shot. If you don't know what they look like; they're cylinders that are usually placed right by where the cord comes into the supply. If any of them have a hole or any black or brown residue around the bottoms, then they're blown and need to be replaced with identical ones (or at least the same capacitance and max voltage). Be careful with capacitors. If they're put in the wrong way, are shorting out against anything else, or have a max voltage that's too low, they can blow immediately and sometimes violently. I've seen them blow out and have electricity arcing across them, frying everything around it.
Jun 05, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Tottom direct power supply
No, it will fry the unit!!!
You need the cigarette lighter adapter to bring the voltage down to 5V. More than 5V will fry the One.
Apr 02, 2009 | Tomtom ONE 3rd Edition GPS
Water supply
Hi Don,
Cold water supply at Fridge location. Run 1/4" tubing and connectors to match the supply valve and solenoid valve on the Fridge. Should be just one tubing connection.
If you do not have a supply at your Fridge, you can shut off your main supply and tap into the cold water line and run you a supply over to the fridge. use 1/2" PVC pipe and fittings to route over to the fridge. Get a Threaded adapter to connect a shutoff Valve. This way you have a way to keep the main supply on and hook up the Tubing from the fridge to the supply.
Nov 28, 2007 | Admiral 26 cu. ft. Side-By-Side...
Did he fry it?
It just had a bad current that went through it the player shouldn't fry, check the battery voltage see if its still got the original voltage if not it will be under its capacity. Rejuvenate the battery and use the right power supply this time. If its still under warranty take the player and its original charger back to where you got the player from and they might swap it out.
Jun 06, 2006 | Toshiba Gigabeat F41 (40 GB) MP3 Player
Max-Fridge STC55926 / STC55927 / STC55928 / STC55929 Beverage Cooler Logo
293 people viewed this question
Top Max-Fridge Refrigerators Experts
Dan Stewart
Dan Stewart
Level 1 Expert
Tom Chichester
mike simpson
Are you a Max-Fridge Refrigerator Expert? Answer questions, earn points and help others
