Question about Frigidaire FRS26KF5C Side by Side Refrigerator
Ice on the floor of a side by side
My ice maker broke down a few years ago, so I cut the water supply to the side by side. Now I got ice building up at the bottom of the freezer. It is cooling ok, both, the freezer and the refrigerator, but the motor seems to kick in more frequently. I unpluged it and it seems, the water is tropping down at the rear side of the freezer. Where could that water come from and what can I do to fix this problem? .
  • 1 more comment
  • annica Dec 14, 2007
    thanks a lot, I'll Try it
    annica
  • annica Dec 15, 2007
    I let the freezer open for one day and one night.
    This morning I reconneced it to electricity. It
    seems it is working ok now, there are just some very tiny little icedrops froozen to its floor. thank you sooo much for now. If the problem goes on, I'll continue this threat
    annica
  • annica Dec 17, 2007
    now it's the third day and it seems working ok, Thank you so much, that was my best Christmas present.
  • 75 Answers
Hi there try defrosting your freezer for at least 24hrs with the door open as it sounds like your defrost drain is blocked with ice
Posted on Dec 13, 2007
Why is my GE (ZFSB23D SS) side by side refrigerator leaking at the back corner, near the rear wheel where the plastic water line goes in?
If the tubing is plastic it could have cracked when you moved the tubing to install the filter. If the tubing is OK then possinly the filter isn't all the way in or is leaking.
Jul 31, 2014 | Refrigerators
We had a water main break down the road a few days ago. Since then, my Series 600 ice machine hasn't produced ice very well. I tripped the breaker to try to reset it but no improvement. Suggestions,...
when the main broke ,sediment collected in pipes. were you asked to flush youre pipes before drinking the water? it is possible youre supply line to the ice maker is clogged with sediment. take off the supply line and make sure water is reaching the ice maker. if it is ,youre filter or inlet may be clogged. hope this is the fix.
Apr 14, 2011 | Refrigerators
MSD2356 side by side, we just hooked the water hoses up and there is no water coming through lines?
Here is a link that explains how to test the ice maker
Ice Maker Test
Here is a link that explains how to check the water in the door.
Water through door test
If you require further assistance you can always post in our forums
Forum
Feb 26, 2011 | Maytag MSD2756G Side by Side Refrigerator
I have a Jenn-Air refrigerator, Model JCD2389DE, and in the last two weeks we have noticed water puddling on the floor in front of the "freezer side" door. We thought maybe the water dispenser...
Mine did this a few years ago. I had to call service out to replace the system board. I guess it's a common problem. Something on the board fails and the defrost operation does not work properly, resulting in rapid meltdown of ice build-up and puddles on the floor.
Nov 14, 2010 | Jenn-Air Refrigerators
Once or twice per day, water on floor below freezer door
check for plugged drain at back bottom of freezer if plugged/frozen over defrost and clear with hot water and remove all ice.
Nov 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
Water icing in ice maker tubing
Replace the water inlet valve . Water is seeping thru the valve when closed . Drops of water seeping thru and freezing inside the fill tube . After replaceing valve , be sure to remove the ice from the fill tube .
Aug 12, 2009 | Amana ASD2526VES Stainless Steel Side by...
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Frigidare side by side Gallery fridge
sounds like you water is spilling out instead of going into ice maker... check the inlet spout for ice or other blockage
Oct 10, 2007 | Frigidaire GLRS237ZA Side by Side...
Frigidaire FRS26KF5C Side by Side Refrigerator Logo
64 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
