Question about HP OfficeJet 7310 All-In-One InkJet Printer
Document feeder is jammed and doesn't copy or fax
  • 8 more comments
  • 3911 Jan 02, 2008
    automatic fax document feeder is not recognizing my documents
  • GIZZARD Jan 07, 2008
    when attempting a manual fax, the paper begins to enter then stops and a zzzzzzzz is heard and a failed indication to unplug and try again. sounds like plastic gearn not meshing. in addition i get a replace or bad cartridge in the right side notice all the time. using all hp carts.
  • Anonymous Jan 15, 2008
    same problem sending fax with the top feeder ...same sound etc...
  • thurow Mar 11, 2008
    I have the same problem. The Fax and copy will not work from the top feeder tray. It will dial and start to fax but then the paper will stop about a 1/4 way in. The paper is NOT JAMMED! When the paper stops a I hear a loud ZZZZZZ . It will then tell me ERROR!/Turn off print. After turning off printer it will feed the paper through then will reset. I have tried to unplug the printer and then try again an nothing has worked. The warranty just expired.
  • elderba Mar 14, 2008
    the top document feeder rollers do not pull the paper through --- therefore, I can only fax 1 page at a time ---- any solutions?
  • himart Apr 03, 2008
    The top document feed fails to pull paper through. It pulls paper a short way then stops accompanied with a buzzing sound; like a stripped gear would sound. To removed the paper, I have to open the automatic feeder assembly. There seem no way around this problem, except putting paper on the glass one at a time.
  • utica1 Apr 07, 2008
    Paper jammed while trying to fax. Can't pull it out from top or from underside. Some of it has ripped. I can't find a way to take the feed mechanism apart. Any suggestions?
  • ritzy007
    ritzy007 Apr 21, 2008
    I have the same problem (surprise, surprise). Document feeder won't pull the paper through in order to scan. There appears to be a problem with the wheels.
  • help7734 May 30, 2008
    Paper will not feed through the automatic feed. Can't fax or copy.
  • sacc339 Oct 02, 2008
    The auto feeder begins to take in the page then about 4" into dies. and an error message comes up saying to shut down and restart. Keeps doing this.
  • 2,985 Answers
Is it jammeded or is it simply a warning saying it is?
Remove all paper and attempt a paper feed without paper.
The paper feed and delivery trays are removable so remove them and carefully reset them.
Making sure the paper is well fanned reload and retry.
Come back with the result.
Posted on Dec 17, 2007
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
Display says line error and print out says jam
• Check the connection. The cord from the TEL.LINE jack to the wall jack should be no longer than
six feet.
• Make sure there are no modem devices sharing the same telephone line.
• Check with the other party to make sure their fax machine is functioning properly.
• Have your telephone line checked for line noise.
• Try connecting the fax machine to a different telephone line.
• If the problem still occurs, your fax machine may need service.
Clearing a jammed document
If the original document doesn't feed properly during transmission or copying,
or DOCUMENT JAMMED appears in the display, first try pressing start/memory . If
the document doesn't feed out, remove it as explained below.
Do not try to remove a jammed document without releasing it as explained
below. This may damage the feeder mechanism.
Jan 17, 2011 | Sharp UX A255 Plain Paper Thermal transfer...
My fax is having a problem feeding pages through the document feeder, it doesn't always grad the page, and if it doesn't get it, it acts like it has a paper jam, what is causing this?
Open the document feeder. Inside you will find a grey feed roller. Cleaning this roller with a cloth dampened with water will help with these paper jams in the document feeder.
Sep 29, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
I have a black streak all on one side when i copy ?
If it is just when you copy and not when you print then it is a cleaning issue. Toner cartridge would cause the line to appear on copies, printouts and faxes. There is a piece of glass inside the auto document feeder that is probably dirty. Open up the document feeder as if you were clearing an original document jam. Look for a piece of glass inside the ADF, it will run the length of the document feeder. There is probably some dirt or another popular problem is white out. Clean off the glass with glass cleaner or alcohol and it should fix the problem.
Oct 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Document Jam
check the photo sensor for the paper fed at the doc feeder roller section you can blow this out with air or try to clean it off you could also check the actuatot arm to see if the spring has com off.. usually its down to the paper dust on the sensor
Jun 16, 2009 | Office Equipment & Supplies
Document Feeder Jamming.
The feed rollers may be worn out and need to be replaced, you can try cleaning the rollers with some alcohol, this may also make it feed better. but if it starts to act up again it might be time for new rollers.
Hope this is of some help.
Apr 30, 2009 | Office Equipment & Supplies
Paper jam in the automatic document feeder
I have a Laser Jet 3050..when I try to load a oaoer to copy or fax, paper does not move...just gears moving but paper is not being pick up...any solutions?
Aug 01, 2008 | HP LaserJet 3050 All-In-One Printer
Document jam
There is most likely a very small piece of paper in the document feeder.
What you can do is take a minella folder or some card stock, open the document feeder cover and shove the folder or card stock through the feeder to dislodge whatever is stuck in there.
The document sensor itself may be knocked out of position.
It can't be the copy paper path since you can print.
May 16, 2008 | Xerox WorkCentre PE120 All-In-One Laser...
Jamming of paper using the Automatic Document Feeder
You may have a really tiny paper jam. You need to open up unit to get access to feeder properly. Use a torch, jams can be so small you can miss them. cheers lilacgerry
Jan 28, 2008 | Brother MFC 6800 All-In-One Laser Printer
Fax machine jams or stops loading document for a copy or sending fax
try to open your fax machine ang check paper feed gear maybe 1teeth of gear is broken..or maybe your machine incountered feeding timing error.
Jan 30, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
HP OfficeJet 7310 All-In-One InkJet Printer Logo
280 people viewed this question
Ben Johnson
