Question about Brother MFC-8440 All-In-One Laser Printer
BROKEN COVER HINGE
COVER HINGE IS BROKEN COVER STAYS PARTIALLY AJAR AND PAPER GETS JAM I NEED REPAIR CENTERS IN CHICAGO MET AREA
  • Brother Master
  • 1,113 Answers
Http://www.precisionroller.com/find/brother_dcp8025.htm
Replace hinge yourself, purchase link above
Posted on Dec 16, 2007
The door to the area where you open for a paper jam has broken away from the springs.
Unless this is a high end printer the best thing to do is just replace it and good riddance. As far as locations go check the Yellow pages for computer repair centers, staples is one, they can give you an estimate for any computer related device like printers and such.
May 25, 2016 | Office Equipment & Supplies
How do I get rid of paper jam that stays on even if nothing jammed
My guess is that there is a piece of paper somewhere blocking a light beam or in a contact switch.
Try a little air if you can't manually feed a sheet of paper. Use the heaviest bond you have.
Jan 06, 2015 | Canon Office Equipment & Supplies
2004 montie carlo: light on dash saying door ajar, dome light stays on, power locks go nuts, the ding ding noise all coming on. Any ideas?
This could be a loose earth for the door harness, broken/chaffed wiring in the door jam (hinge area). Or as simple as a defective locking solenoid (Door Catch Assembly). Some investigation in these areas will be needed. Hope this helps...
Mar 17, 2011 | 2004 Chevrolet Monte Carlo
Mess. saying cover open i cant seem to close the top down. the top cover seem to be off track or broken
I have a Lexmark X6570 All In One Wi-Fi model. Just had the problem where I went to print and received an error message saying that the cover was open (when it wasn't). I noticed that the back right hand corner had slightly popped out of place for no apparent reason. Tried to pus it back into place with no luck.
Here's what happened and how to fix it:
There are two plastic hinges at the back of the 6500 series printers that allow the top cover to open for access to the ink cartridge carriage. The lower ends of the hinges are cylindrical shaped and each contains a very stiff steel spring inside. They are designed to prop the cover of the printer up and hold it open when opened. As the plastic material ages, it may weaken and the tension of the internal spring may break the round end of the hinge off. This causes the printer cover to not fully close (even though it may appear so). There is a switch in the main printer body that detects when the top cover it open (even partially), and the printer won't work in this condition.
To fix this, open the top cover and carefully disconnect the 3 wire harnesses and the ribbon cable that run from the top cover to the base of the printer. Then remove the 'paper jam' hatch cover from the back of the printer. There are two phillips screws on the back panel of the pinter (one is located behind the paper jam hatch cover). Remove these screws (they secure the plastic hinges in place). You should now be able to lift the complete top cover/ scanner table assembly off the rest of the printer. Look for a steel spring about 3 inches long...remove this along with the round base of the hinge which may have broken off and remained down inside the printer. Glue this piece back onto the end of the hinge, but leave the spring out. Now reassemble the printer in the reverse order of disassembly and you should be good to go. Note that the top cover or the printer will not stay propped open on it's own with the spring removed, but this is not really an issue.
I am not sure if new replacement hinges are readily available from Lexmark or other sources.
Feb 05, 2011 | Lexmark X6570 InkJet Printer
Paper gets stuck, comes out only partially and crumbled
It is a hardware problem. So you can check it from service center.
Nov 04, 2009 | HP LaserJet 4 plus Printer
Brother 8820d MFC auto doc feeder does not work...
You need a new hinge so the cover will sit down properly, or paper will jam anyway, but it sounds like there is still a scrap of paper on one of the sensors inside the ADF, you need to look with a flashlight down thru where the paper goes and also look up thru the slot with the ADF lifted.
Sep 11, 2009 | Brother MFC 8820D All-In-One Laser Printer
Paper sticks half way when I try to FAx
Probably the left hinge is broken not letting the adf cover go all the way down and causing jams. A new hinge is #LP2403001, around $15 to$18.00
Aug 20, 2009 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc8220 jam problem
We looked everywhere for a piece of paper stuck in the machine and couldn't find it. We finally fixed the problem by moving the paper size adjuster in the paper try until it was right up against the paper. If the paper is free to move around in the tray, apparently the machine sees that as a paper jam.
Feb 03, 2009 | Brother MFC-8220 Fax
Automatic paper feed
The narrow glass section at the left of the flat bed scanner glass is shaped concave to route the paper back up to the tray if you are using the document feeder. Right above this is a spring loaded paper guide that puts slight pressure on the paper as it is fed through. If the cover of the scanner is not closing completely it will miss guide the paper. I would check that there is nothing on the flatbed or in the hinge section that is keeping the cover lifted slightly. The hinges do extend for copying books, so it may have jammed in the up position causing your problem. Good luck!
Sep 08, 2008 | Brother MFC-8840D All-In-One Laser Printer
CANON PC920
POSSIBLE BAD EXPOSURE LAMP, SOUNDS FUNNY BUT THIS MODEL WILL SEND JAM CODE WITH BAD EXPOSURE LAMP. CHECK TO SEE IF LIGHT IS IN PREHEAT MODE. ALSO THE EXIT PAPER SWITCH GETS BROKEN OFF ON THIS MODEL...
Nov 29, 2007 | Office Equipment & Supplies
Brother MFC-8440 All-In-One Laser Printer Logo
243 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
