Question about Linksys Wireless-G WRT54G Router (DSLSWRT54G)
ADDING A LAPTOP
I work wireless on my laptop using the router. I am trying to use another laptop through to pick up the connection as well. It says I'm connected with excellent signal, but when I try to access the internet it says I'm working offline and won't connect. I've checked to make sure I'm not set to work offline. My computer allows access from the other computer, I don't know what the heck is wrong? Help!
  • 589 Answers
You didn't specify if you're using DSL or cable.
I've run into this dozens of times. With DSL, keep in mind the software on the PC is what "dials out" to the ISP with your name / password, and you MUST set the name and password in the router. Otherwise, ONLY the computer that has the software installed (verizon, etc) will be able to connect.
If you're using a cable connection, you don't have to do this, however, most newer Linksys routers come with a 'setup' disk, which MUST be used regardless of connection type.
Posted on Jan 07, 2008
Does your wireless router supply DNS addresses via DHCP or are they configured into the wireless adapter on the other computer? If the DNS addresses are configured into the working laptop's wireless adapter and not the router -- they may need to be configured into the wireless adapter of the new laptop. Is there a proxy server configured into the browser of the new machine that should not be there or does not match the working machine? Is the new laptop statically configured to an inappropriate IP address or gateway or DNS servers for the network you are attempting to use it on.
Posted on Dec 13, 2007
Laptop cannot pick up wireless from modem
Is your Wireless router integrated in the modem? If it is not, try to unplug the router for a few minutes then restore the power and see if it fixes the problem. If it is integrateddo the same for the modem. Try to connect using the laptop. If it does not work use the laptop to scan for new wireless locations and make sure you see the home location. If you do not your wireless router is not working, If so select the home location and enter any Web Encryption Protection and try to connect. If your wireless router is not working, make sure the preference for the router has the wireless function turned on. To do this use ether the software which you received with the router/modem or internet explorer to access the IP address of the router. If your router is configured for wireless use it may be a bad wireless router.
Feb 05, 2010 | NetGear CG814M (pn-3201155) Modem
Get my laptop to pick up the zoom router
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here
for step by step instructions on how to connect to the wireless network and troubleshooting steps
Jan 16, 2010 | Zoom (5590-00-03) Wireless Router (G66115)
I cannot make a wireless connection my new laptop to the linksys router. My homenetwork works and my first laptop is connected to a wireless linksys connection. when adding another laptop I cannot make a...
then it's the second computer's problem, try repairing the connection, turning the wireless switch on and off, rebooting, and if your using vista use windows system file checker
or if xp, put this in either command prompt or run
chkdsk /r
Sep 30, 2009 | Linksys Wireless-G WRT54GS Router...
Laptop not connectiong to wireless network
Connect the Laptop to the router with ethernet cable
Verify the wireless LAN
  • Open a browser and type http://gateway.2wire.net; the Home page opens.
  • Click the Home Network tab.
  • Verify the wireless status located on the right panel (Status at a Glance) is Disabled.
  • When the status is disabled, then enable the wireless LAN .
May 27, 2009 | 2wire 2700HG-B Router (2700HGB)
Wireless and Wired Router
I have dlink DI-524 which is hooked to my desktop but wireless option is not working. I would like to use wireless option for my laptop.
Jul 25, 2008 | Computers & Internet
Laptop not seeing my wireless router
Try to manually "Add device to network" by using the wireless setup wizard. Check to see if the Wireless Zero Configuration service is "Running" before trying to add device. Yuo may also want to disable IPv6 in vista tcp/ip properties page.
Jul 17, 2008 | Linksys Wireless-G Broadband Router
Laptop won't recognize the network, No installation CD, other solutions?
This sounds like you have either WEP or WPA enable on the network you are trying to connect too. Are you connecting through a wireless network? If not try adding a passphrase using WPA-TKIP and see if that helps.
May 06, 2008 | NetGear WGR614 Wireless Router
ask a neighbor if they pick up our router signal if not start from scrach if it still dont work hope our router on warranty. cheers
Jan 13, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
is there a switch on the laptop either in the power management software or an actual switch on the laptop case (or a button) that turns the wireless on and off? That's probably the problem, not your router.
Aug 18, 2007 | 2wire 2700HG-B Router (2700HGB)
Linksys Wireless-G WRT54G Router (DSLSWRT54G) Logo
62 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
