Home | HP | OfficeJet G85 All-In-One InkJet Printer | The "On" but...
HP OfficeJet G85 All-In-One InkJet Printer
Problem for HP OfficeJet G85 All-In-One InkJet Printer
The "On" button doesn't turn the printer on suddenly....
By snpentz on Sep 19, 2009
and yes, I have a green light on the cord on the back of the printer.
The printer was showing a display, but not responding to the print jobs
in the que. (sp?) After deleting them and then even turning off the printer,
now it won't turn back on.
Ideas appreciated! I'd rather not buy a new printer because I have a lot of
"spare" cartridges for this one.
Best Solution
posted on Sep 19, 2009
Very Helpful)
vinzen
Rank: Guru
Rating: 90%, 71 votes
I had a similar problem with an HP OfficeJet All in one that drove me nuts.It would loose power,then come on, then loose power again.What I figured out and you can investigate is that although the power adapter (mini ups) is on green light the connection is not making contact.If you play with the power plug on the printer, jiggle it, pull it out,push it it and you find the printer starts,trys to go into setup thats your problem.I tried using tape to hold it in (worked for a while),tied the cord wire up relieving stress on the connection,(worked for a while till cat thought it was a toy).My best solution was to add tiny tinfoil arround pins or holes,(lasted months).I since upgraded to an all in one wireless.I don't like the adapters that HP uses on its printers.They should by now make a better connection detail.Sorry for the long response I still get angry as I'm sure you are but if this is your issue you can fix it.Good Luck.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
Very Helpful)
Rdy2rumble
Rank: Master
Rating: 87%, 14 votes
If the printer is plugged into a surge protector, you may want to unplug it from that surge protector and plug it straight into the wall.
See here. Click
The other thing that comes to mind is that some printers have an internal battery that looks like a flat disc about the size of a nickel. If this battery goes bad, the printer may not turn on. I could not find any material online that suggests a battery exists in this model, but it's worth a look inside the printer anyway. It probably will be in an "out of the way" area under the hood with the cartridges and it shouldn't be too inaccessible.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for HP OfficeJet G85 All-In-One
Questions and Unsolved Problems for HP OfficeJet G85 All-In-One
Do you recommend HP OfficeJet G85 All-In-One InkJet Printer?
Answer
Answer
I have inserted a new ink cartridge and it will not dispense the ink. I have removed all tape from... (More)
Answer
cartidge alignment failure on HP officeJet G85xi -- how do you fix it?
Answer
I am using the unit in a "stand alone" config. It will not send or receive a fax. Phone... (More)
Answer
Half empty black cart stopped printing, error message to replace. New cart also didn't print. ... (More)
Answer
Just installed a new color cartridge. It keeps saying that alignment failed and won't print in... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP OfficeJet G85 All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
