Since either one is not working id say the clock assy is bad. we replace alot of btm oven baking elements ., but your clock is what sends power to the bake elements . so suspect clock. not a cheap repair
Possibly a tripped thermal fuse. Should be located behind the panel in between the upper and lower ovens. Might have a red reset button on it you can push down. If it clicks and then works again, look for possible cooling fan problems.
Problem is usually caused by a door switch (on most ovens either upper or lower) going bad, or not being activated. On some ovens, can be caused by a bad thermal protector - usually the one on/near the magnetron.
Hello, Their is a high limit thermostat that has tripped,on older model and on some newer models it has a red button on it that can be pushed in to reset it.Other times once it goes out it must be replaced. For the upper oven its behind the control panel,for the lower its behind the grill between upper and lower oven
I hope this helps you to understand why your oven wont heat, Gene
If the lower wont heat and the upper work fine then it is
the coil itself that is bad and should be replaced. Hope this helps...please
post back for further assistance.
Hi, If your electric oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself... Check out this tip that I wrote about the Oven not heating problem..
Oven functions Oven light. Upper and lower heating elements. (Conventional cooking). Upper and lower heating elements with fan. (Fan assisted cooking). Lower heating element with fan. Inner grill heating element. (Radiant grill). Full grill heating element with fan. (Fan grill) Rear circular heating element with fan. (Fan forced cooking). http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
Hi, If your electric oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself... Check out this tip that I wrote about the Oven not heating problem..
cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. Catriver..post back.
