Look at the back of your television and see if you have colored holes label "Input". If you are unable to find a set of yellow, red, and white AV inputs on the back of your TV, try looking on the sides, top, and bottom of the TV. Look for any hidden panels or doors as well. If you can't find it but can find something with "component" colours (which consist of green, blue, and red for video, white and red for audio) you can use the Green, White and Red (using the yellow in the green) holes to connect your AV wire. Then just plug your Wii in, turn it on and switch the TV to AV1 or Video.
Make sure the plugs EXACTLY match the jacks on the TV. If you plug just the green cord into the TVs yellow jack, you will get black and white. If your tv has a combo jack (uses the green of a component input, make sure that the tv is on the right input (COMPONENT and not VIDEO).
I am assuming that you are talking about a Nintendo Wii. When you buy a Wii it comes with standard RCA composite cables that are three colors, Red, White and Yellow. Yellow is the cable that carries the video signal and the red/white carry the stereo audio signal. You would need to connect these cables into the corresponding color inputs on your tv. Plug the yellow ended cable into the yellow jack on your TV and do the same for the red and white cables. After this is done, you will need to switch your tv's input to the input that corresponds to the one you plugged those cables into. Some newer flat panel TVs do not come with RCA composite inputs. If this is your problem, you will need to get some component cables for your Wii. These cables look identical to RCA (composite) cables but come in colors red, green, blue, red and white. In this case the red, green and blue cables carry the video signal and the red and white carry the audio. You can purchase these from just about any store that carries the Wii or online from places such as Amazon.com.
With the yellow, white, and red AV cables that came with your system:
Did you have to use the red/green/blue inputs on your TV because it doesn't have the standard (yellow) AV inputs? If so,click here for complete information on doing this type of hook up.
If this is your first time hooking up the Wii console or have you moved it to another TV, please click here to review our step-by-step connection guide. Our experience shows that many times this issue can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
With the blue, green, white, and red component cables (sold separately):
Review our step-by-step Wii Component Cable connection guide to make sure the cables are properly inserted and that your TV is set to the proper input.
If you have verified the connection is correct, and are still receiving a blank or black and white screen when powering on your Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700
What to do will depend on how you're connecting your Wii console to your TV.
Did you have to use the red/green/blue inputs on your TV because it doesn't have the standard (yellow) AV inputs.
If this is your first time hooking up the Wii console or have you moved it to another TV, Our experience shows that many times this issue can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
Review our step-by-step Wii Component Cable to make sure the cables are properly inserted and that your TV is set to the proper input.
Did you have to use the red/green/blue inputs on your TV because it doesn't have the standard (yellow) AV inputs... if this is your first time hooking up the Wii console or have you moved it to another TV, . Our experience shows that many times this issue can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
The cables that come with the Wii are composite video cables with the standard red, yellow and white cables. You might be trying to plug them into the component video input, which has red, blue, and green.
Check your TV to see if you have any red, yellow, white inputs. Use that input if you are using the cables that same with the console.
Alternatively, you can buy component video cables for the Wii. This will be for the red, blue and green input. This will provide you with higher definition (480p vs. 480i) and a slightly sharper picture.
Your LCD TV should have one of the following types of inputs:
Composite. This is usually a yellow jack, along with red and white jacks for audio. If your TV has these, which it should, then the cable that comes with the Wii will plug directly into these jacks. Plug the yellow to the yellow jack, the red to the red jack, and the white to the white jack.
S-Video. This is a flat black jack. There are four little holes, and one "flat" rectagular hole. There should also be a red and white jack that go along with this for audio. In order to connect to this input, you will need to purchase an S-Video output cable for the Wii. Most stores that sell Wiis will sell a third-party cable for this. This connection will give you a significantly better picture than Composite. S-Video does not carry audio, so you still need to plug the red plug into the red jack and the white plug into the white jack or you'll get only video and no audio!
Component video. This is a triplet of Red, Green and Blue jacks. There is usually a set of red and white jacks along with them for audio again. This connection will give you the best picture, and you can set your Wii to EDTV (Progressive) mode. To connect to this input, you will need to get the Wii Component Video cable. Most stores that sell Wiis will either sell the official Nintendo one, or a third-party cable. Connect the red plug to the red jack, the green plug to the green jack, and the blue plug to the blue jack. Also connect the red audio plug to the red audio jack and the white audio plug to the white audio jack. Be careful not to get the red audio plug confused with the red video plug! If you see a picture, but the colors are wrong, then you either swapped the red and blue, or you connected the red audio plug instead of the red video plug.
