Question about MSI K8N Neo4-F Motherboard
Setup my pc doesnt work past the first boot screen it stalls and wont go further....i upgraded from 40gb hdd to 160gb hdd now when i put the pc on it just hangs after the boot screen....i have tried it on my other pc and it works just fine,BUT ON THIS PC NOT EVEN THE LITTLE RED LIGHT FLICKERS TO SHOW ITS WORKING.ITS THE ONLY HDD IN THE PC.....SHOULD I MAKE MY DVD ROM MASTER AND THE HDD SECONDARY MASTER,OR WHAT?.... I AM OUT OF IDEAS..............
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
Ok, try to get the memory up above 1.5 gig and up the cpu to a min of 1.8 ghz. it sounds like to small of hardware and to much O.S. for the set up. if the cpu runs @ 100% on start for over 12 sec. it recoils on the info and dams it self to a stall. lala linda
Posted on Jun 02, 2008
HDD TO SECONDARY & DVD ROM TO MASTER
Posted on Jan 21, 2008
Acer aspire one nav50 how to install windows on new hard drive
To install windows on a hard drive you have to boot from a CD with windows XP on, after which it will ask you to press a button.
After which you can follow the setup instructions in windows XP.
Mar 01, 2012 | Acer Aspire One PC Notebook
I am connecting my 40gb PATA HDD, but my PC doesn't start. There is no problem when i connect my 80gb PATA HDD in same PC. My 40gb HDD had detected once but it gave symbol S@ in the BIOS setup. Can U...
You did not indicate that the 40 Gb hard drive had Windows installed on it and whether it was the original hard disk for this computer.
There is a possibility the 40Gb hard drive is faulty.
Try installing the 40Gb hard drive as a slave drive with the 80Gb drive as the master drive (don't forget to set the jumper on the 40Gb hard drive as Slave. Check the BIOS to see if it detects the 40Gb hard drive, and when the computer boots up, if it can see the 40Gb hard drive and opens the various folders and files, then the hard drive is OK.
Sep 19, 2010 | Computers & Internet
I want to change the HD from 40Gb to one with more capacity but I tried to make a ghost image in a 120GB and 160GB HD but the bios don't recognize it and only can see in the screen a simbol _ flashing.
Not sure which software you are using for making the ghost image. Lets say its "Acronis".
First, you will need an USB hard disk drive to store the image on.
Next, run the boot cd and choose backup.
Send it to the hdd.
If it was successful, remove / replace your hdd.
Run the boot cd again but now choose "Restore". Locate your image and then wait.
Hope this helps you. Norton Ghost is a bit different.
Oct 20, 2009 | HP Compaq nx5000 Notebook
Longer Boot time after upgrading the Hard drive
first let's determine if the upgrade cause the boot speed.
Disconnect your NEW HDD and/or memory, one by one and see if you get back your fast boot. Then try with your NEW components only !
If you find it works better with new components only, then first connect your OLD HDD only and try.
If you connect both HDDs on one cable, check Jumper settings for both HDDs (Master/Slave).
Also HDD capacity and type is automatically detected by the BIOS and there is no need to put/change those settings manually.
I believe you new RAM is DDR type, too!
As written in the manual for the board, your motherboard has two pairs of memory slots, and you can use one or two modules of DDR memory, OR one or two modules of SDRAM memory, but you can NOT put BOTH DDR and SDRAM memory modules.
regards.
Apr 22, 2009 | Computers & Internet
Gateway w350a when turned on wont get past the black screen
gateway w350a T-series HDMI power on but screen stays blank...Its just a black screen. Is there a fix for this?
Mar 31, 2009 | Gateway M305CRV Notebook
Upgrading HDD From 40GB To 160 GB
  1. Use the Windows XP Setup disks to restart the computer, or use the Windows XP CD-ROM to restart the computer.
  2. At the Welcome to Setup screen, press R to repair the Windows XP installation.
  3. Press C to repair the Windows XP installation by using the Recovery Console.
  4. Type the number that corresponds to the Windows installation that you want to repair, and then press ENTER. For example, type 1, and then press ENTER.
  5. Type the Administrator password, and then press ENTER.
  6. Type map, and then press ENTER. Note the drive letter that is assigned to the CD-ROM drive that contains the Windows XP CD-ROM.
  7. Type the following commands, pressing ENTER after you type each one, where drive is the drive letter that you typed in step 4 of "Method 2: Use the Recovery Console," of this article: copy drive:\i386\ntldr c:\
    copy drive:\i386\ntdetect.com c:\If you are prompted to overwrite the file, type y, and then press ENTER.
Feb 19, 2009 | Western Digital 160GB Caviar ATA-100...
Boot pc problem
You can solve this by going into the bios setup & changing the boot order. Make the dvd/cd drive 1st in boot line then hdd. This should allow you to boot up from the windows xp disc. Hope this helps & please rate this solution fixya. Thanks.
Feb 04, 2009 | HP Compaq EVO D510 Intel Desktop PC -...
Dell Lattude D800 HDD change - doesn't boot
I suppose it can support upto 100GB , just get the BIOS updated to the latest release and check in the setup if the disk is accepted .
Dec 16, 2008 | Dell Latitude D800 Notebook
Hdd upgrade problem
Try reversing the connections so the new drive is detected as the primary master.
Oct 07, 2007 | Gigabyte GA-7VTX Motherboard
MSI K8N Neo4-F Motherboard Logo
76 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
David
David
Robert Monigold
Robert Monigold
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
