Hitachi 42V710 42 in. Rear Projection HDTV Television
Problem for Hitachi 42V710 42 in. Rear Projection HDTV Television
New lamp but still no picture
By barbara_m232 on Sep 18, 2009
Recently my television stopped coming on. After reading the insert sheet about the lamp indicator, I realized the lamp indicator was on and that I needed to replace it. After removing it, it was obviously bad, there was now a big hole at the front of the lamp and little ***** pieces of glass were stacked inside.
I ordered two replacement lamps from an after market vendor. After putting the first lamp in, putting back the lamp cover back on, plugged the TV back in and powered on the TV. However, no picture was displayed. Both the Power light and the Lamp indicator were flashing. Unplugged tv, removed the lamp cover, took out the lamp and reset it in the plug and replaced the cover. Plugged it back in and powered on the tv. No pic. This time, did the same steps as before, but used the second lamp. The picture came up immediately as expected. I then returned the first lamp to the vendor stating that it was defective and asked for a refund. They ran their own test: "Lamp held light for the duration of the test. Lamp will be tested again after proper cool down period." After the third pass, the lamp was declared not defective. The manager stated that they used a lamp ballast from the manufacture that test the lamp for defects. Therefore, they charged a 25% restocking fee. My question is, what determines if the lamp is defective?
Comments:
Sep 18, 2009
- This is a Hitachi 50V710 Rear Projection TV.
Solution #1
posted on Sep 19, 2009
Not Rated)
gjahn
Rank: Wiz
Rating: 83%, 23 votes
Unless a lamp is shattered it is very hard to tell if a lamp is defective. Sometimes they may have a small crack and may not be noticeable or the igniter on your unit may not be strong enough to make it start. when you put the first lamp in maybe the lamp cover was not on correctly. it has a tab on it that closes a safety switch so you cannot turn it on with the cover off. You say the second lamp is working o.k.. try to reinstall the returned lamp and take notice of the lamp door to be sure it is on correctly. It may indeed be defective but it will be pretty hard if the mfg. says it is not bad because they found no fault with it.
Was this helpful?
Yes
No
Popular Solutions for Hitachi 42V710 42 in. Rear
Questions and Unsolved Problems for Hitachi 42V710 42 in. Rear
Do you recommend Hitachi 42V710 42 in. Rear Projection HDTV Television?
Answer
Answer
everything has a green tint , not able to adjust it away , I replaced a bulb last yr at this time... (More)
Answer
the tv had yellow spots and now there is no more images, we only get the sounds, I wanted to know... (More)
Answer
I replace the lamp which was shattered now the color is horrible.
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in Windham, ME
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
