Question about Toshiba 36A43 36" TV
Toshiba TV I have a toshiba tv, and all the sudden when I turn it on, it is like someone is hitting every button on the remote, it is not changing the channels, but it is going through the menu options and changing them, it was fine for a day, but now it is back, also if I change the channels, I have to hold the button on the tv and hit the remote button also, weird, I thought it was the batteries in the remote I changed them, and it stayed fine for a while actually a whole day. Now back to going crazy, any ideas?
  • bamaman421 Dec 13, 2007
    Thank you I tried that the other day, still no fix. Any other suggestion?
    Thanks
    Scholar:
  • 152 Answers
Try to open the control and clean it... when you clean it you have to remove the battery, then with some cotton, moist it a bit with alcohol and try to clean all the contacts... after that, let it dry for about 10 mins or more..depends on how wet it is, so dont soak the cotton too much in alcohol.
then put everything back together and i hope it gets fixed..
Posted on Dec 13, 2007
  • Asdrubal Perez Dec 13, 2007
    how old is the tv? is the control a universal one that can control any tv just with a code?
    when you opened the control, did you notice any kind of white dust? or some rust in some parts?
    it must be some loose contact and it may require soldering..
    there could be some condensers that could be busted.
    here is a pict of a condenserhttp://www.pcpaudio.com/pcpfiles/doc_amp... .. when they get busted they look fat and sometimes leak...
No remote and need to change input on a toshiba 27a45
If you do not have an input button on the TV then you need to get a remote. I have owned a lot of toshibas. Use the channel down button on the tv and keep hitting it untill you get down to the last channel. after that it should start cycling thru you inputs. Good luck to you.
Mar 21, 2013 | Toshiba 27A45 27" TV
Tv stops responding to remote after 10 minutes
I have same issue and not just remote even controls on tv do not work. Eventually hitting power button will turn it off then I can turn on and have functions for 3-10 minutes. Wish someone had a solution
Nov 23, 2012 | Toshiba 46SL417U LCD TV
Toshiba tv 40rv525u has started to change channels
My TV 40RV525U changing channels, menus itself for few months ( I use antenna).
my son tried to stop the channel scrolling by enter weird number into the channel to stop it scrolling such as 555, 777..
later, it turn on off by itself and unable to hold on a channel
I call Toshiba customer service and they ask money $25 for troubleshooting but I denied since I do not want to waste money and time.
Now, I found how to fix it myself.
In my case, something was wrong with the signal comes from the button control on the left side of the TV.
What I did
unplug the power cord.
Remove back cover.
Look into the motherboard ( biggest green at the center).
First, I disconnect a connector on the motherboard come from the IR board that receive the wireless signal control ( meaning the remote is disable).
I turn on the TV, press on Menu button on the TV side. Menu is still scrolling.
I turn off TV, disconnect power cord and connect the IR connector back to the motherboard.
I then disconnect the nearby connector that comes from the side control buttons.
Turn on the TV by remote, press menu button on the remote to check. The menu stays.
DONE.
I use electric tape to seal off the connector and let it hanging there.
Close the TV back panel
I have been watching TV for 3 nights without menus/channels scrolling.
NO AVAILABLE red message when watching DVD is no longer existed.
Hope this help someone else.
Jan 20, 2012 | Toshiba 40RV525U 40 in. LCD TV
I have an old remote that works for a VCR and I did have it working for the TV but one day someone was playing with buttons and it stopped working. I was wondering how to program my Toshiba vc 260 remote...
Try the following procedure:
1. Make sure there are working batteries in the Toshiba remote control.
2. Turn on your television set, DVD player or other device that you want to control with the Toshiba remote.
3. Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit.
4. Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device.
5. Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed.
Feb 28, 2011 | Toshiba Vc-260 Remote Control
Getting toshiba ct-852 to program
This remote is programed by holding the CODE button and pressing the electronic button that you want to be programed. (For example press and hold CODE and hit DVD.) After you do this you have 10 seconds to input the 2 digit program code for the electronic you want programed. If your manual doesn't have these codes you can This One on page 13.
Hope this helps
Jan 26, 2009 | Universal Remote Control DIRECTV Universal...
Comcast remote won't work with TV
i can tell you how to make it work, hit the tv button, then hold down the setup button untill it blinks, then try thease codes one at a time 0154, 0156, 0060, after trying the first one, if it turns off, hit the setup button again, that will lock it in
Jan 10, 2009 | Toshiba REGZA 46RV530U LCD TV
Toshiba 62hx94 cant shut off closed caption have comcast cable How do I turn off closed caption on my TV. It suddenly turned on.
if the tv is not hd then the control is on your tv.
However if the comcast box is an hd box do the following;
Press cable, then power and then with 2 seconds press the red menu button to get the hidden hd user setup menu. You may have to hit the menu button multiple times to get the menu to stay up on the tv.
Next go down to closed captions which is probably enabled, and hit the left or right arrow key to change it to disabled.
Then press the power button twice to turn the box off and back on.
Dale
Dec 26, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
NEED CODE FOR TOSHIBA TV
Codes for Toshiba TV.... 159,178,109,120,181,105,049,095,170,260,358,394,902,012,095,117 and 141
Nov 29, 2007 | GE JASRM24912 Remote Control
V-chip code forgotten
I found this to work on my Toshiba TV/VHS combo MV19M4 after trying others suggestions that had worked on similar models but nothing worked on mine. Maybe it will work for yours. Follow these steps:
1: Unplug the TV for 1 minute then plug it back in.
2: In the menu select "TV Set Up".
3: Move the blinking block to beside "V-CHIP Set" BUT DO NOT SELECT IT.
4: Hold in the number 1 button on the remote.
5: Hold in the volume down button on the TV.
Your TV will turn off. Give it a few seconds to reset itself and then turn it back on and you will have to completely reprogram your settings. When you go to the V-CHIP settings it will ask for your new code.
- Jenny
Nov 01, 2007 | Toshiba MW20FP1 20 in. TV/VCR/DVD Combo
Accessing sevice menu
i tell people all the time if you get into the service menu and hit the wrong buttons i wont know what you did to it again if you post here to ask how to get into the service mode you dont have the desire to find the codes on the internet which are readily available as are service manuals turn on the tv push mute on the remote till mute goes out hold down mute button and push menu on front of tv hit menu again when the s comes up hit 7 on remote and watch out you just figured how to reconverge your tv maybe not
Dec 06, 2006 | Toshiba 55H70 55" Rear Projection...
Toshiba 36A43 36" TV Logo
125 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
