It sounds like your door hinges are worn, usually on older ovens due to weight of door. Most oven doors can be removed by simply raising the tabs/ fitting small screwdriver on both hinges(refer to user manual) etc. Once door is removed you can place a medium size screwdriver or similar in the hinge slot, pushing the hinge plate on the bottom in an outward direction, thereby bending this plate(very slightly) forward. This will make the door close fully, activating the door switch, and turning off the oven light. This is only a short term solution, as this hot air escaping can lead to further problems. Hinge pair will need replacing. Door hinges are spring loaded ALWAYS KEEP FINGERS AND HANDS CLEAR OF LOADED HINGES.
Installed in April 2009. Tuesday I baked all day in both ovens. This evening, Wednesday, the bottom...
(More)
Installed in April 2009. Tuesday I baked all day in both ovens. This evening, Wednesday, the bottom oven will not turn on. The light comes on but when I push Bake, there is only a beep. Nothing else.. I am currently baking something in the top oven but the bottom oven won't start.
The beep is regularly irregular, that is, it beeps at regular intervals, and then stops for a while...
(More)
The beep is regularly irregular, that is, it beeps at regular intervals, and then stops for a while and then starts up again, whether the oven is on or off. Please advise. Thank you
Hello, I have a Jenn-Air electric double oven. The top one is self-cleaning. I turned on the...
(More)
Hello, I have a Jenn-Air electric double oven. The top one is self-cleaning. I turned on the cleaning mechanism and after completion, I cannot unlock the door to open it. The unit is approximately 10-15 years old. Pleasse help. Thanks - Jo
