Question about Jenn-Air JGR8850 Gas Kitchen Range
Oven door will not unlock.
I have a Jenn-Air model SEG196 (no manuel) that I tried to start the self-clean cycle. It would not start and now I cannot unlock the oven. Help!
  • Anonymous Mar 02, 2008
    I also have a Jenn Air SEG196 that will not unlock after self-cleaning. We just bought the house and have no manual for the range/oven. I ran the cycle and waited for the oven to cool completely before turning the temperature knob to OFF and the oven selector knob to OFF. At this point the LOCK light went off, but I could not open the oven door. I have even ran the Self-clean cycle again, hoping to be able to open then, but with no luck. My oven is still locked. Please help!
You will not be able to open the door if you turn off temp gage. Return the temp gage only to clean and door should open.
Posted on Feb 20, 2009
Self cleaning ovens
Perhaps it hasn't cooled down enough; or you may have to run the self-cleaning cycle again. The oven has to reach a certain temperature before it starts to turn the residue to ash.You may have interrupted its cycle.
It then has to cool off sufficiently to safely open the door.
Dec 22, 2012 | Jenn-Air Kitchen Ranges
Can not get oven door to open after cleaning cycle.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Dec 12, 2010 | Jenn-Air Ovens
Ignitor not working
Check the ignitor, Make sure that the connection are good and tight. If they are then look at your control board which is located behind your clock. Then check your relay also.
Feb 20, 2009 | Jenn-Air JGW8130A Electric Single Oven
I need direction on how to start the clean cycle on my jenn air
CLEAN PAD
Use to set a self-clean cycle or a delayed
self-clean cycle. One press of the Clean
pad sets up an immediate clean cycle. A
second press of the Clean pad sets up a
delayed clean cycle.
• Clean oven
frame, door
frame (area
outside of gasket)
and
around the
opening in the door gasket with a nonabrasive
cleaner such as Bon Ami*. These
areas are not exposed to cleaning temperatures.
• Remove air grille.
• Remove oven racks. If racks are left in
during a clean cycle, it may impair function
and they will discolor. Turn off the
oven light and close door.
* Brand names for cleaning products are
registered trademarks of the respective
manufacturers.
TO SET FOR IMMEDIATE START:
1. Press Clean pad once.
2. Press the Auto Set pad for 3 hours of
cleaning time, press again for 4 hours
and again if 2 hours of clean time are
desired.
3. CLEANING and LOC plus the clean
time will appear in the display.
4. When the clean cycle is complete,
CLEANED will be displayed. LOC will
remain on until the oven has cooled
(approx. 1 hour).
5. When the oven is cool, LOC will no
longer be displayed and the door may be
opened.
6. Wipe out the oven interior with a damp
cloth. If soil remains it indicates the
cycle was not long enough.
TO CANCEL SELF-CLEAN:
1. Press Cancel pad.
2. If LOC is NOT displayed, open oven
door. If LOC is displayed, allow oven to
cool.
Thanks for using Fix Ya, Please take the time to rate this solution.
clarkco
Feb 08, 2009 | Jenn-Air JDS9860A Dual Fuel (Electric and...
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
Jenn Air oven door won't open after clean cycle
You need the repair man; not a diy project. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
Nov 30, 2008 | Jenn-Air JGR8775QD Gas Kitchen Range
Had this EXACT same problem the day before a party where I needed the oven for lots of baking.... Tried all sorts of things, was about to call a repair man- I FINALLY got it to open by following the first two directions for putting it into self clean mode (turned both knobs to CLEAN), then when it said to lock door I tried to move the lock lever and bam it worked! Give it a shot! Good luck! (:
Nov 26, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air S160
I did it by mistake. I tried to move the lever over and of course, it didn't open but went to restart. I hit the cancel button and then tried the door again and it opened. Yup, we all here feel likes dorks!
Thank you!
Sep 06, 2008 | Kitchen Ranges
Jenn-air gas electric grill range
any power to unit at all?? clear, start, clean ,button?? what happens when you push them??? clock on?what happens when you try to set to clean again??? it should activate hte door lock latch at which point cancel and it should reset itself. with any luck! what happened thankgiving how was it fixed
Mar 14, 2008 | Kitchen Ranges
Door won't unlock after self clean
Try turning the breaker off for a few minutes, If that doesn't work try restarting the self clean mode and canceling after it starts. If that fails list a brand and model number with the problem.
Mar 02, 2008 | Ovens
Jenn-Air JGR8850 Gas Kitchen Range Logo
654 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
