Question about HP Photosmart 3210 Printer
Ink System Failure
Error: 0xc18a0501
Tried power cycling, but no luck. Outisde of warranty. Does anyone know what this means?
Thanks
  • 5 more comments
  • Masters Dec 13, 2007
    INK SYSTEM FAILURE
    Ink system has failed.
    Unable to copy, receive
    faxes or print. Refer to
    printer documentation.
    error: 0xc19a0013
    Press OK
    This is the error in which I am receiving and I need to know if there is anything I can do to solve this error. The printer scans (in color just fine) and prints (only in green and blue) One second it will say I need to replace pink and another second it will say I need to replace powder blue and dark blue. Does anyone have any suggestions?
  • lakebums Dec 14, 2007
    sounds like same error ---->ink system has failed. unable to copy, receive faxes,or print. refer to printer documentation..Error:ox18a0106<---- (anyone?) also just over warranty!!!!!
  • Anonymous Dec 30, 2007
    I also have an 0xc18a0106 error on my HP 3210xi printer. Out of warranty. HP says ink is no longer being sensed by the printer and it cannot be fixed. Apparently the ink dried up in the area hwere the sensor is. They suggest an upgrade.
    Any other suggestions?
  • Anonymous Jan 01, 2008
    I have the same problem with my HP 3310
  • neznarf Jan 20, 2008
    It worked, thanks
  • Anonymous Apr 26, 2008
    black ink is not getting into printer. New ink cartridge did not help. FR
  • bbaca10 Jan 09, 2017
    Working so far thanks
Push OK, CANCEL, BLACK, & COLOR all at once while turning the printer off, turn it back on. I had to do this 2 times to get it to work and then it went through a long period of maintanence before I could print
Posted on Jan 14, 2008
  • 1 more comment
  • Kathleen Hall Oct 22, 2011
    THANK YOU!!!!! This worked. I had tried several other solutions and was ready to replace my printer when I found your suggestion. Most grateful. :)
  • Janet Gajewski
    Janet Gajewski Dec 02, 2013
    Thank you!! Thank you!! I also tried other solutions, but this one worked.
    Thanks seams to go to maintenance mode
  • 3 Answers
I have an HP c5150 and I was getting the error: 0xc18a0501, I tried the reset listed here, unfortunately that did not work for my printer. I searched the web and came across this tidbit of information from a conversation. The Error in the conversation is a different number, but the steps basically worked for me and I am happily printing again.
  • OK I had the hp error code 0xc18a0001 problem and here is the conversation I had with the tech.....
    james cowan: hp error code 0xc18a0001
    Earnest: I will assist you in this regard
    james cowan: great
    Earnest: I understand that a error code with 0xc18a0001 with "Ink System failure" is displayed on the front panel of the All-In-One printer. Am I correct?
    james cowan: correct
    Earnest: Thank you for confirmation
    Earnest: May I have the model number of All-In-One you are using?
    james cowan: c6250
    Earnest: Thank you for information.
    Earnest: James, please let me know the room temperature in which printer is replaced
    james cowan: 67 degrees f
    Earnest: Okay
    Earnest: Please perform the below steps on the front panel of the printer to resolve the issue
    james cowan: ok
    Earnest: Press and hold the "left arrow" key.
    Press the "Setup" key and release both keys, Display should say "Enter Special Key Combo"
    Press and release the "OK" button.
    Earnest: Please ignore the above steps, James
    james cowan: ok yes nothing seemed to do anything
    Earnest: Press and Hold the "Print Photos" &"Red Eye Removal" buttons. Release both buttons. Display should say"Enter Special Key Combo"
    Press and release in sequence"Red Eye Removal","Print Photos","Red Eye Removal"
    Earnest: Display should say “Support” and display the FW rev (something like R0616R)
    james cowan: COxxFN0723BR j
    Earnest: Okay
    Earnest: 2. Press and release the right arrow button until the display says “System Configuration Menu
    james cowan: ok
    Earnest: 3. Press and release the "OK" button.
    james cowan: ok and it says hardware failure status
    Earnest: Display should say "Hardware failure status: Clear. Press OK to clear".
    Earnest: Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
    Earnest: Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
    james cowan: ok
    Earnest: Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
    Earnest: Let me know once you are done with the above steps
    james cowan: ok its unplugged
    Earnest: Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
    Earnest: Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE".
    james cowan: ok
    Earnest: Let me know the message displaying on the front panel of the printer
    james cowan: printer preparation occuring - do not interrupt
    Earnest: Okay
    james cowan: ok its done
    Earnest: Let us print a self test page from the printer now
    james cowan: ok deal
    Earnest: 1) Load letter, A4, or legal unused plain, white paper into the input tray.
    2) Make sure that the printer is on and loaded with unused plain, white paper.
    3) Press Setup . The Setup menu appears.
    4) Press the down arrow button to select Tools , and then press OK .
    5) Press the down arrow button to select Self-test Report , and press OK .
    james cowan: ok printing
    Earnest: Okay, please check whether all the colors pritned perfectly on the test page
    james cowan: perfect
    Earnest: Great..Cheers!!!
    james cowan: thank you very much
    Earnest: James, now you can continue using the printer
    Earnest: I appreciate your efforts and patience in trying to resolve the issue."
Posted on May 02, 2009
  • 14 Answers
I have a mode 3210 All-In-One.
In *MY* case there was a problem with the gear that drives the peristaltic pump that delivers the ink to the print heads. As this involves SUBSTANTIAL disassembly to do the repair, I suggest you make certain that this is *YOUR* problem before you decide to take the thing apart.
Open the hood and from the right of the printer look down into the left end of the printer to the area immediately behind the BLACK ink cartridge. There is a white peristaltic pump here with the words "Micropump" on it. This pump has six tubes which are used to pump the six ink colors (Black, Cyan, photo Cyan, Magenta, photo Magenta, and Yellow). There is also a small connector with about a dozen blue wires above the pump.
Toward the left outside of the printer is a WHITE gear (hidden from view) that drives the pump. The gear itself is driven by another gear driven by a dark belt that is driven by a small motor.
You can see this gear and belt inside the printer above the pump and the connector with blue wires.
In *MY* case the WHITE gear that drive the pump had come off the axle and was laying around the area nearer to the rear of the printer by the clear plastic optical encoder (this is about 2 inches from the pump toward the rear of the printer).
Using a small mirror you may be able to see this, or you may feel around for the loose gear. You might be able to shake the printer and confirm that this gear has come off.
If you have a gear that has slipped off, the Good News is, it can be repaired. The bad news is, that you have to take a LOT of the printer apart to get to it. This involves:
Be methodical about keeping track of screws!
1) Removing the left and right small front panels. (The right front panel is where you stick in the memory cards).
2) Remove the left and right side panels.
3) Disconnect the connectors from the top scanner unit that connect to the main circuit board where the USB and Network connectors are.
4) Disengage and remove the top scanner sub assembly by releasing the two hinge clips. Remove each hinge screw and pull straight up to remove the hinge.
5) Remove the inner plastic cover (this exposes the interior of the printer).
6) Remove the power supply by pulling on the "pull ring" and pulling out from the back of the printer.
7) Release the power supply connector from the metal chassis and unthread the wires that are hooked in the metal chassis.
8) Remove the rear plastic frame by removing two screws. The left screw anchors the left metal chassis plate.
9) Remove the left plate which now exposes the pump, gears, belt and motor.
10) Pull the belt and gear off the shaft by releasing the retention clip that holds the gear on the axle. This now allows you access to the pump.
11) Reattach the white gear to the hexagonal shaft of the pump.
12) Now reassemble the whole mess in reverse order.
Once I put everything back together, the printer spent several minutes (perhaps 5 minutes) priming the systems with the newly functional ink pump. I had also done a OOM NVM Reset (Non-Volatile Memory Reset) using the procedure outlined by "sweetie" above. I'm not sure this step was necessary.
Good luck.
NateOceanside@hotmail.com
Posted on Jan 28, 2008
  • NateOcean
    NateOcean Jan 28, 2008
    View from inside the printer.
    Top view. The wayward gear is jammed in the slot at left. The Black, Yellow and photo Cyan cartridges are at the bottom of the photo.
  • NateOcean
    After the left side cover and power supply have been removed the jammed gear can be accessed.
    Two gears and belt ready for reassembly.
    Reassembled and ready to go. Lower right is the motor with drive belt looped arount the large dark gear. The missing white gear has been replaced. The clear disk at left with black pattern is the optical encoder. The peristaltic pump is marked "micropump". The six black tubes that exit the pump supply ink to the printheads.
Go with best solution from sweetie11881 it really works! I had almost given up and called a repairman with a quote of $90 for half an hour just to see what was wrong then 120.00/hr for repairs that they may not be able to fix!
Posted on Jan 23, 2008
Push OK, CANCEL, BLACK, & COLOR all at once while turning the printer off, turn it back on. I had to do this 2 times to get it to work and then it went through a long period of maintenance before I could print
SOLUTION # 2 ROCKS!!!
Posted on Nov 18, 2008
  • 3 Answers
Thank you NateOceans!!! The gear was off just like you said. There was no rattle. It must of been wedged in pretty good. So even if it doesn't sound like anything is loose it still could be off.
Thanks a million, chuckn76
Posted on Mar 18, 2008
Solution #3 NateOcean - Thanks so much for sharing your detailed outline and photos to fix this problem. You saved me $400. The gear was off - did require a NVM reset. I've never taken apart anything before. Your instructions were easy to follow - and worked like a charm! Thanks to Sweetie11881 as well!
Posted on Feb 25, 2009
Solution #3 NateOcean - Thank you sooooo much. The gear was off, but no rattle - I could see it w/a flashlight lodged under the optical encoder. And thank for the steps for dismantling worked great, long but great! Solution #2 was needed as well - Thank you!
And HP said it wasn't worth repairing!
Posted on Nov 21, 2008
Just Reseting it worked for me =) - seems that this error code accounts for a lot of things - including gears and a ink problem. Lets just say HP - At least tell US what to do
Posted on Oct 08, 2008
That fix will work the first time (not always). All depends on how much air has been trapped in the system. If you keep getting error message after trying reset-THIS IS WHAT YOU NEED TO DO-get new wet of ink cartridges and during the second shut down while doing the "reset" install the new set of ink and then power on. The "full" ink helps do the full system purge -this is just like the first time you run the printer at set up and load up the ink for th first time. What it does is a full purge of the air in the ink lines. You need the full set of ink to help do this. YOu might have to do it twice to rid all the air and stop the ink system failure error. This procedure will only work while running the reset fix.
Posted on Jan 26, 2008
Thanks Guys, I solved pressing ok, cancel, black and color as well.
3310
Posted on Apr 03, 2009
I tried to initialisize my C5180 (just got it in) and got the code 0xc18a0106. Never even printed with it. paper alignment cancelled. The solution given bij sweetie 11881didn't work. I wonder what the solution will be when I call support monday.
Posted on Jan 27, 2008
3 Suggested Answers
SOURCE: Ink System Failure
I myself have not tried this, but apparently it came from HP.
HP Photosmart C5180 show ink system failure message
This was what I was told to do for my C5180. First they told me to do a power drain. This is done by pulling out the power cable and then holding the on/off button for a minute, then putting the power cable back in (this didn't work).
Then we did a master reset. Unplug the printer, then pressing the help and ok buttons simultaneously plug it back in. This sorted it. :)
Have to say it looked like this whole process used up shed loads of ink, so by the time I had finished I needed to replace 3 cartridges!
Posted on Apr 22, 2008
pineworks
  • 4041 Answers
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Posted on Jan 25, 2010
What is error 0xc19a0003 mean for the HP Officejet 4620
ink system failure - error 0xc19a0003 means ink system failure error usually occur if you have issues with your ink cartridge or printheads. Have you try replacing either of the two?
May 12, 2014 | HP Officejet 4620 e-All-in-One Printer,...
Ink System Failure
Have you tried to remove and reseat the printer ink cartg.?
Feb 11, 2008 | HP Photosmart 3210 Printer
Its giving error code 0xc18a0501 ink system failure.how can i fix this?
If systems problem, just install and reinstall the printer software to correct the setting.
Dec 07, 2010 | HP Photosmart 8250 InkJet Printer
Error:0xc18a0501 on HP Photosmart 3210
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 31, 2010 | HP Photosmart 3210 All-In-One InkJet...
Can't print on Photosmart 3110 all in one
This is a result in a print head failure or the use of non HP ink ether or there right you need to service the unit part will be needed if the maintance does fail. If your using non HP ink stop its use and purchase HP ink you be glad you did!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 17, 2009 | HP Photosmart 3310 Printer
Getting error 0xc19a0023 with HP Photosmart D5460 which is only a few weeks out of warranty. It happened suddenly in the middle of printing a colour page. I've tried resetting the hardware code (Print...
The official solution is to power off and reset the printer, as this is an ink system failure:
- power off the printer
- disconnect power cord
- wait 30 seconds
- reconnect power cord
- power on the printer.
Frankly this looks a bit like mumbo-jumbo to me, but it's worth a try.
Searching on the Internet finds out this other suggestion,
"...is being handled by the Level 2 techs at HP and all L1 agents have been instructed to transfer the call to the L2 techs. So give a call to HP Tech Support and they will take care of this one way or the other."
Oct 23, 2009 | HP Office Equipment & Supplies
HP 7280 All in one problem Ink System failure Error 0xc18a0501 I have tried shutting down even reset the system, but it still produces same error code.
1. Try to remove and reinstall the Ink Catridges. Be sure it is lock in place on the ink cartridge holder.
2. Turn off the Printer and unplug and replug the power adapter.
3. Uninstall and reinstall the printer driver.
Jun 16, 2009 | OKI C3400n Laser Printer
Ink System Failure
Reset the product:
  5. Wait 60 seconds.
Nov 09, 2008 | HP Photosmart D7160 InkJet Printer
HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Aug 24, 2008 | HP Photosmart D7160 InkJet Printer
Ink System Failure
did a master reset. Unplug the printer, then pressing the help and ok buttons simultaneously plug it back in. it will recalibrate and ask to replace almost all of the ink cartridges, however Unplugging the printer, while then pressing the help and ok buttons simultaneously plug it back in did fix it and I am able to print again. Thank you soo soo soo much.
Apr 18, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart 3210 Printer Logo
9,881 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
