Question about Seagate Momentus 4200.2 100 GB Hard Drive
My Seagate Momentus 4200.2 120GB Keeps shutting down any computer you plug in into. I´ve used diferent usb 2.0 adapters, but as soon as windows xp recognized que hard drive there is a blue screen and the pc restarst. Any Ideas Thank You
2 Suggested Answers
  • 9 Answers
SOURCE: Seagate Momentus 4200.2 120GB
Some laptop manufacturers use the 4 pins to the side of the data connection to force Master / Slave. Do you have a jumper shorting 2 of these pins? If so, remove the jumper and try it again in your external caddy. Had this problem 2 weeks ago with a Toshiba notebook having the Blue Screen of Death. Removed the jumper and then the disk worked perfectly!! Strange but True.
Posted on Dec 13, 2007
  • 728 Answers
SOURCE: have an i/o problem with Seagate Momentus 5400.3
Hi burak02,
There could be a million reasons that your getting this i/o error. First I would check the cable to make sure it's snug on the pins, and then my suggestion is to follow this link HERE and pick the question that best describes what your OS and equipment list are. This is a great spot to solve most of the problems, They also have software you can download to test the drive to see if it's dead or just loose.
Good Luck,
And don't forget to leave a rating
Posted on Oct 07, 2009
Testimonial: "thx somewhat helpful with seagate site"
0 characters
1 Points
FreeAgent Pro USB broken -- need data from Momentus drive
Momentus is a SATA drive, so you can put it in any PC that has SATA bus to access the drive.
If you can borrow a SATA to USB dock, you can put it in the dock and plug the dock to USB port on a computer to get your data out the drive.
One example for the USB dock is EZ-dock and you can search on Internet for the picture.
Apr 11, 2014 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I am interested in this drive Seagate Momentus XT 500 GB. I want to know how to install this drive into my desk top computer with a 3.0 slot for the drive as it is only 2.5 inches wide.
To install a Hard Disk Drive(HDD) into your desktop, take off the side panel of your case. Locate the SATA slots on it, they should be above the available Optical drive slots.
Put it in place, depending on your case you should either have a latch which locks it in place or you will have screws. After you've done, make sure that if you have another HDD in your PC, and you will not use this HDD for System files(C:\ drive), you will have to set the new one to Slave configuration. To do this you need to take out that jumper inside of the HDD(you can use some tweezers) and, according to what's printed on your HDD, move it up or down.
When you've done that, insert the SATA power supply cables from your Power Supply(PSU). After that use the SATA interface cables which came with your HDD and plug them into your Motherboard's SATA adapters. Locations of these vary depending on the motherboard so it's always best to refer to your Motherboard's manual to check locations.
After that start your PC and open up your BIOS/CMOS. Usually you press a key such as F2/F5/Esc on bootup. Configure your Motherboard to check for new drivers. After that save and exit and it will restart your PC. You should have installed your new HDD!
Aug 20, 2011 | Seagate Momentus 5400.6 500GB Hard Disk...
It is a Seagate GoFlex 2 terrabyte external connected through usb. I have dropped it several times and plugged it back in and it has worked. This last time it did not work when I plugged it back in. It...
I don't think so you have described properly your problem.
1. USB cable to Casing its completely a USB Device/Drive so where you plugged it?
2. "The Laptop does not see the drive or the USB adapter when its plugged in" you mean BIOS?
3. Windows 7 Pop Up Autoplay window what opens when you try to open it?
May 15, 2011 | Seagate FreeAgent 2TB GoFlex Desktop USB...
I pulled the seagate 2.5"
When you use external adapters to plug drives into USB ports the drive needs to be set for mast not slave. The internal drive is one one channel and external drive is on a different channel so neither drive is a slave, both are masters with not slave drive present. Try removing the jumper you installed and try the drive, it should be seen because all windows XP or later do not need drivers for USB drives.
I hope this helps, if so please rate my solution.
May 06, 2011 | Seagate Momentus 4200.2 100 GB Hard Drive
My seagate momentus 5400.2 external hard disk can't be detected by any computer. doesnt show up in the device manager, or anything. the light is on, for some reason, sometimes it blinks red/green,...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: for a "no data - no charge" guarantee.
Dec 12, 2010 | Seagate MOMENTUS 5400.2 - HARD DRIVE -...
I was given a seagate momentus 5400.3 hard drive and i want to use it as a external usb drive i bought an external case for it and plugged it into my laptop, it see it but in device manager i am getting a...
Try connecting it to a different computer.
EXACTLY what error-message do you get?
When you double-click that entry in Device Manager, and click "reinstall drivers", allow Windows to connect to the Internet to look for a device-driver for the USB-to-disk-drive adapter (no device-driver is needed for the disk-drive itself).
Dec 11, 2010 | Seagate Momentus 5400.3 Hard Drive
Does it really shut down the computer by itself? Do you have an Operating System installed on it? The only thing I could think of is that the drive has something faulty on the PCB of the drive that is shorted or causing it to sink too much current and that shuts off your power supply. I've never heard of this though or come across it in real life.
Describe your problem in more detail
Dec 13, 2007 | Seagate Momentus 4200.2 100 GB Hard Drive
Seagate 80 GB laptop hard drive not appearing in My Computer
i suggest u to re instal u r
remember- dont keep 2 operating system on u r hardisk man
dont forget to tell me u r problem solved or not
best regards & best of luck..
Oct 26, 2007 | Seagate Momentus 5400.3 Hard Drive
Seagate Momentus 4200.2 100 GB Hard Drive Logo
81 people viewed this question
Top Seagate Hard Drives Experts
Brian Sullivan
Brian Sullivan
Michael Thomas
Michael Thomas
Are you a Seagate Hard Drive Expert? Answer questions, earn points and help others
