Question about Samsung SlimFit TX-S2783 TV
Issue with TV signal changing from TV to DTV on my Samsung TX-S2783
Have to manually (using remote) keep changing the signal back to TV but keeps changing back to DTV signal every few seconds or minutes. Tried to disconnect cable to TV and DVD but still does it. When through all the TV menu options and signal is good. Any idea why signal keeps changing?
Lo que ncesito es para mejorar la imagen usb upgrade
Posted on Jan 22, 2008
Samsung TX-S2783 Deflection settings
If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Nov 29, 2016 | Samsung SlimFit TX-S2783 TV
My picture keeps blinking in and out! Sound is uninterrupted. What is the problem?
Possible that this shunting is due to intermittent fault in the mother board. make sure all connectors are plugged in to fit and there are no loose joints and dry soldering joints.
If so make a quicj touch up soldering on suspected points to check up.
Sep 28, 2010 | Samsung SlimFit TX-S2783 TV
Power Shutdown automatically after using more than 30mins. Even we did not set the sleep. Why it happened?
Try resetting your TV to original specs(Use menu reset as instructed by your TV manual) If doesn't work, try using a stablilizer, if it doesn't work then try another wall socket, If not then you have a loose soldering issue with your power IC socket induced by rough handling of your power cables.
Jun 30, 2009 | Samsung SlimFit TX-S2783 TV
Samsung slimfit keeps turning off
When the TV is on, how about the back light(you can check that on your TV's back side)
If the back light on -- need to replace Main Board.
no back light -- need to replace Power Board
Feb 19, 2009 | Samsung SlimFit TX-S2783 TV
Just wanted to know if my TV is HD or not. How can I tell. Model no. is TX-S2789 Samsung Dolby Digital if your tv is similar to this model then yes I assume it is HD.
Jan 11, 2009 | Samsung SlimFit TX-S2783 TV
How to connect dvd
if you use the standard red white and yellow connections from the back of your dvd player to the back of the tv on the in portion it will work. just make sure the tv source is selected as AV1
Apr 06, 2008 | Samsung SlimFit TX-S2783 TV
first, change the speaker. second try to adjust the sound IF trnsformer, third resolder the amplifier IC.
Mar 29, 2008 | Samsung SlimFit TX-S2783 TV
How to connect ps3
All you have to do is use the correct cables then select the video source on the remote or tv to the way you connected the cables.. Like if you connected the cable into video 1 select video1 on the tv.
Feb 10, 2008 | Samsung SlimFit TX-S2783 TV
TV Blows internal fuse
You will have to find the source of a major short in your power supply.Since it's a 5A i assume i imagine that's where the short is.
Oct 23, 2007 | Samsung SlimFit TX-S2783 TV
Samsung HD 27" -- Manual Switching of Picture Size Necessary?
check your remote that should have all the features to navigate in to the tv menu.if it is not working check the remote it could be faulty or the eprom in your tv neeeds to reset or replace an eprom does a lot of function in a tv set.good luck.greetings from belize.
Nov 18, 2006 | Samsung SlimFit TX-S2783 TV
Samsung SlimFit TX-S2783 TV Logo
179 people viewed this question
Jerry Greenberg
Jerry Greenberg
