Question about D-Link AirPlus DI-524 Wireless Router
Connection to internet doesnt work
I configured the DI-524 by using the http://192.168.0.1 link. I went through all the steps and seemed like everything went well. However, when i try to connect to any website, it gives Page cannot be displayed error. When i try to connect to the network via Wireless, i am able to see the router however when i try to connect it, there's no successful connection established.
All the Indicator lights on the Router are lit the way it should be. When i connect to the PC to my modem directly, it works fine.
Any thoughts?
Regards,
KP
Your ISP has specific requirements for connecting a router to their equipment. For some the default router settings connect successfully. Some Telcos require PPPoE logins to access the network, you may either be given a static IP address or be required to accept a dynamic IP address. You need to determine from your ISP often from a help website, a chat with a technician or phone support what those requirements are. Another possibility is failure to include DNS addresses either in the router or in the network adapter's IP configuration.
Posted on Dec 13, 2007
D-link DI 524 Router (Quick Router Setup - error: 103
103 most popular error on DLink Modems and Routers.Error occurs when your computer or router is not able to find the internet connection. Reason behind settings of the modem or router.
Try to use :
  • "https" instead of "http" in the URLs.
  • Check Firewall is not blocking your internet connections.
  • Reset your modem or router.
For setting up and configure your router http://support.dlink.com/index.asp and D-Link Router Support for technical help.
Jan 27, 2014 | D-Link Computers & Internet
Using DI-524, can't find the wireless network
Have you properly configured the web based Wireless configurations of the router? Also check WLAN IP configuration of your laptop. Configure WLAN IP configuration to DHCP and try again.
Regards;
Hassan
Jul 22, 2009 | D-Link AirPlus DI-524 Wireless Router
Dlink DI524 wireless problem: cannot access the router
If the Router is new proceed to Step 1. If the Router is used power on and press and hold the Reset button for about 10 seconds. It is located next to where the power cord is plugged in. Use either a pen or paper clip to push reset button.
Step 1. Connect one end of an Ethernet cable to the Ethernet port located on the Cable / DSL modem and the other end to the WAN port on your D-Link DI524 wireless Router. The WAN LED light will illuminate to indicate proper connection.
Step 2. Connect one end of an Ethernet cable to LAN Port 1 on the back panel of the DI-524 and the other end to the network adapter in the computer you are using to
configure the DI-524. The LED light for LAN Port 1 illuminates to indicate proper
connection.
Step 3. Once all pieces ar connected. Open your Web browser and type http://192.168.0.1 into the URL address box then press ENTER. Once the log-on pop-up screen appears type admin for the user-name and leave the password blank then click ok.
Step 4. Once you have logged in, the Home screen will appear and you should see a box called RUN WIZARD in the middle of the screen. Click that box and follow the steps.
Setup Step 1 - Click Next
Setup Step 2 - Create Password and click Next
Setup Step 3 - Choose Time Zone and click Next
Setup Step 4 - Setup wizard will try to auto-detect your Internet connection type.
Setup Step 5 - Select your Internet Connection. You will be prompted to select the type of Internet connection for your router. More than likely it will be Dynamic IP Address. Click Next.
Setup Step 6 - Click the “Clone MAC Address” button to automatically copy the MAC address of the network adapter in your computer. You can also manually type in the MAC address. Click Next.
Setup Step 7 - The default wireless settings for your 802.11g wireless network are: SSID = default Channel = 6. You can change the SSID name to whatever you like. This will be the name of your wireless network. Click Next.
Step 8 - If you wish to use encryption for your 802.11g network, the DI-524 is capable of two levels of wireless encryption - 64-bit and 128-bit. By default the encryption is disabled. You can change the encryption settings for more secure wireless communication. If you choose to use encryption, you will need to write down the encryption key so that you can connect your laptop or pc via wireless connection. Click Next
Setup Step 9 - Your is complete. Click Restart to save and reboot your router.
Setup Step 10 - Click Close to complete your setup.
Setup Step 11 - You will be returned to the Home tab. Close this window and wait for the Router to finish rebooting. Then relaunch your Web browser (i.e., Internet Explorer or Netscape Navigator), to link to your favorite Web site to test your Internet connection.
Here is the link to download all the necessary info to configure your router - http://www.dlink.com/products/?pid=DI-524&tab=1
Jun 21, 2009 | D-Link AirPlus DI-524 Wireless Router
Configuring D-Link DI-524 router with airtel beetel 110bx1
Make sure you can go online directly to the airtel broadband. If internet works fine, connect the D-Link router to the Beetle. That should be going to the Internet port or WAN port of the D-link. Then your PC to port 1. Try to power cycle both devices now. Unplug the power to the router first then to the modem. Wait for 30 seconds. Power on modem first, wait for the lights to go solid, then power on the router. Check if the internet works fine hardwired. If it is, wireless should work as well. Just connect to the signal coming from the D-link.
Oct 31, 2008 | D-Link DI-524/DWL-G630 (di524dwlg630kit)...
Connecting with internet
Yes, that is possible since you have a wireless router. Router can share internet connection. Go to this link this will help you setup the wireless connection (secure it if you want)
http://www.portforward.com/english/routers/wireless/Dlink/DI-524/wireless.htm then on the very bottom there is an option how to Configure Windows XP to connect to your wireless network.
I suggest this because it would be better if there is encryption on the network so people wont be able to access your internet for free (unless you give them the security key)
Sep 15, 2008 | D-Link AirPlus DI-524 Wireless Router
Installing a DI-524 router
Hi askar,
I'm assuming if you've been given a username/password you've either got DSL (a PPPoE connection) or it's for your email address. If you don't have a disc for your new router, you can configure it through a wired connection to the router (using an ethernet cable). That's a bit of work but if you need to do it that way we can help. Otherwise run the CD that came with the router (again, you'll need a computer plugged into it) and the step-by-step should get you through it.
For starters, unplug the modem and then plug the cable running from the old router into the same port space in the new router (should say either WLAN or Uplink). Turn on the modem, wait 30 seconds, then power on the router. After that run the disc and you should be good.
If not, let me know!
Ben
Sep 06, 2008 | D-Link AirPlus DI-524 Wireless Router
Configuration
I have same problem. Can not connect Di 524 to Surf 5100 Cable modem
Jul 23, 2008 | D-Link AirPlus DI-524 Wireless Router
Cannot connect to internet through DI-524
After you've rebooted your wireless router...make sure you reboot the cable-company (or DSL) modem while the router is connected to it and on. The modem seems to recognize the router properly only in this way.
Simply unplug the power to the cable-modem and plug it in again.
If the cable-modem has a battery back-up you'll want to remove that as well.
Feb 24, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 Configuration as "Client"
hi
just had same prob if you go to dlink site in phillipines there you will find the latest firmware for dlink 524 . i couldnt belive i had to do this as all links to uk site had no pages diplayed .i went first to .singapore site then to australia but the most uptodate firmware i found was on phillipines site
ver2.06b02
Sep 20, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
83 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
