Question about Fargo Pro L ID Thermal Printer
Fargo pro-l using too much ribbon
I am using MS word to print id cards and I am using the ymckok ribbon and the correct setting in the driver for this ribbon. But when I print the printer will pause and it will advance the ribbon several feet and use a single panel and them advance more. The end result is that it takes a while to print cards and I am getting about 50 cards out of a 250 card ribbon.
Any suggestions?
  • 3 Answers
It sounds like you may need to calibrate the ribbon sensor.
Go to the driver icon in your printers folder.
Right click on the Pro-L driver's icon, and select "Printing Preferences".
Click on the "Advanced" button in the lower right corner. A new window will open.
Scroll to the bottom and you will see "Calibrate...". Click on that and a button appears next to it that says "Properties...". Click the "Properites" button and another window appears.
On this screen, you'll see a button on the right side that says "Sensors...". Click on it, and yet another window opens. Almost there.
Here, you'll see two sections. The top section is for calibrating the ribbon sensor, the bottom is for the lamination sensor. Remove the ribbon and close the lid. Click on the "Send" button in the top section to calibrate the ribbon sensor. Your printer should beep twice.
After that, hit cancel on the previous windows to close out everything.
Normally this fixes this kind of problem, but if it doesn't, then there is something broke in the printer, possibly the sensor itself.
Posted on Mar 27, 2008
I have Fargo DTC550 ID printer printing double image can someone help
Hi Arthur -
If by "double-image" you mean that you see multiple identical images printed, but each is slightly offset and appear in yellow, magenta, or cyan ink colors, then it seems like the card is slipping within the printer as it prints. These printers print 1 color at a time, with a total of 5 passes to complete 1 card image - 1 pass each for the yellow, magenta, cyan, black & clear overlay panels of a standard YMCKO ribbon. If the card doesn't get positioned properly for each new panel on the ribbon, then the subsequent image will have a slight offset to it.
The fix could be as simple as a thorough cleaning - with supplies from a Fargo dealer (like us!) that are appropriate for that model. It could also be that the printer requires a ribbon-sensor calibration. To do this, you could need to download the Fargo Workbench Utility program from the HID Global website here: (Drivers Downloads) . There is a "Printer Information" view in this utility, and then a "Test" you can run called "Ribbon Calibration" - do it regardless of the cleaning.
If still not resolved, contact us or your Fargo dealer for further support.
Safe-Card ID Services
Charlotte, NC USA
https://www.safecardid.com/
Nov 17, 2017 | Fargo Office Equipment & Supplies
Why my Fargo ProL Printer is not printing my Card Back Clear?
Hi, Its not clear what you are saying.
First, what kind of ribbon are you using for printing, and what kind of lamination ribbon are you using?
what are you trying to print on the front and back?
Feb 17, 2015 | Fargo Pro L ID Thermal Printer
Printing...
a) You have a YMCKOK ribbon instead of the YMCKO that you should have due to driver settings(check)
b) You set your driver for K ribbon and you have a YMCKOK or YMCKO ribbon
Nov 13, 2013 | Datacard SP35 Printer
I have ribbon and am using photoshop,how do i print uv with hdp5000?
To print with UV on a Fargo HDP5000 printer you first need to get a UV color ribbon: YMCFK. The part number is 84061.
After you have your UV ribbon installed you will have to load your cards and tell the printer where you want that special UV logo/design to go. The easiest way to do this is by using Asure ID Solo 7 software. This design software is made by Fargo and has a check mark box on the top where you can either turn the UV design on or turn it off depending on how you plan to create your card. Asure ID Solo 7 costs about $150 but it's very easy to use and makes the print process easier.
There is a second option which involves not using Asure ID and instead creating your UV design through Fargo's "Work Becnch". This process of creating UV designs through work bench is slow and not the most efficient but it is free.
Sep 28, 2011 | Fargo HDP5000 Thermal Printer
Have tried to tape, wind, etc. as shown in the instruction manual but it repeatedly breaks. Interestingly enough when it does break it is always on the yellow panel which is entirely imprinted on the...
Ribbon breaks on those older models are usually traced back to only a couple of things.
1. The ribbon-type may be set incorrectly in the printer driver. The C30 and C30e color ribbon type if doing single- or dual-side printing in full-color is #044200 - YMCKO; the ribbon type if doing dual-side printing with full-color front and black-only back is #044210 - YMCKOK. Open the driver, then "Printing Preferences", select the "Device Options" tab and verify that the ribbon type setting matches what you're using. Note that you can only make a change to the setting if you have sufficient (Admin) Windows privileges.
2. There is a mechanical issue with the printer, where an o-ring is broken, or the head-lift motor has gone out. Either is very bad, as the printer has long been out of production and parts are no longer available. (But you can contact us for a replacement - new or refurbished!)
Nov 18, 2017 | Fargo Persona C30 Thermal Card Printer
My DTC 400 bladge printer jams a lot.
The DTC400 has an o ring that drives the card feed rollers. Fargo has had a problem on older DTC400 printers with the o ring stretched or broke. This causes irregular feed roller issues, ribbon breakage or misalignment of print registration.
It is recommended to do a ribbon sensor calibration. This can be done through your print driver using the directions in this link.
Your DTC400 came with a two year manufacturer warranty. Contact Fargo Technical Support at 800-459-5636.
For more information about id card printer systems, visit our website at www.safecardid.com
Nov 13, 2008 | Fargo Office Equipment & Supplies
Problem while printing black on the black side
check the printer driver and see if YMCKK is selected in the driver.
Aug 07, 2008 | Fargo Pro L ID Thermal Printer
Fargo DTC550
My printer is Fargo DTC550 and I'm using HID 1326 card for printing. I cannot get this equipment to function correctly. I had no
problems installing the software and hooking up the printer to make the ID
cards, but all attempts to print an ID card have failed. Every card I have
tried to make has been unsatisfactory, with colours not printing, very poor
image quality, and the lamination device consistently jamming for every
single card I have tried to make.
Sir, please help me.
Showkat
Nov 26, 2007 | Fargo DTC550 Thermal Card Printer
Breaking Ribbon
Ribbon breaking continuously is caused by 2 common problems. 1. The printhead is going down before OR after the card has passed through. You would know this when you open your cover, and unlock you printhead, is the break before or after the card? Try printing the test page from the driver. That doesn't print "Edge to Edge" so if this is the problem, it should not break. 2. The print head heat settings are too high. If this is so, you can change this on the printers menu panel. I can explain more information, once I know your problem.
Jan 15, 2007 | Fargo DTC525 ID Card Printer
Fargo Pro L ID Thermal Printer Logo
284 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
