Question about Dell 1710n Laser Printer
Dell 1700 image drum
Is there anyway I can fool the printer to believe I have changed the image drum on my dell 1700 printer?
  • Jean Rony Oct 18, 2008
    After I refilled my dell 1700 toner, the printouts have a gray shade.
    - I verified that the drum is always covered with a toner. Then I used soft napkins to clean the drum.
    - Still getting the same gray background. I think the problem was in the waste hopper located in the drum unit.
    - I disassembled the drum unit and removed all the waste toner and cleaned tha blade.
    -Reinstall toner and drum: same problem.
    - I am told that I have to reset the "drum chip". I tried the proposed solution "door open + cancel button + flashing lights, not good"
    -Does someone has another proposition?
    Thanks
After you replace the imaging drum, you should reset the imaging drum's counter. To reset the counter, YOU MUST LEAVE THE DOOR OPEN AND THEN press and hold the Cancel button until all lights flash in sequence.
Posted on Oct 02, 2008
After you replace the imaging drum, you should reset the imaging drum's counter. To reset the counter, press and hold the Cancel button until all lights flash in sequence.
Posted on Dec 19, 2007
Close door or replace cartridge message won't go away
Dell growing very fast in computer market because Dell provide best and affordable products to users but one thing is confronting by many users is that "Close door or replace cartridge message won't go away" that's why Dell experts provide a toll-free Dell Support Phone Number through which number every Dell user can easily connect with Dell experts and solve issue within a couple of minutes. Don't late to call because Dell experts provide first come first serve service so call anytime without any hesitation 24x7.
Jan 08, 2016 | Dell 5210n Laser Printer
I have a Dell 1700 printer - it was showing an error and when i pressed the green button it printed a help guide. This said that i needed to replace the imaging drum and it would no longer print until this...
May 03, 2011 | Dell 1700 Laser Printer
Photoconductor kit? Dell 1700 printer
The photoconductor kit is another word for the drum or imaging drum. All three words refer to the same part.
Here is a link from the Dell site for this model.
http://accessories.us.dell.com/sna/PopupProductDetail.aspx?c=us&l=en&cs=dhs&sku=310-5404
Once you replace the drum, the printer has to be manually reset. If this is not done, the printer will continue to give this print out. By resetting it, the counter is set back to zero. The drum is good for around 30k prints.
From the Online Manual for the 1700, to reset the counter:
http://support.dell.com/support/edocs/systems/1700n/en/index.htm#online_documentation
NOTICE: Resetting the imaging drum's counter without replacing the imaging drum may damage your printer and void your warranty.
Jun 18, 2010 | Dell 1700n Laser Printer
Flashing error and toner on Dell 1700 and will not print even after replacing drum and toner this happened before and I found on line sequence of pushing the buttons on printer to clear...but i can no
After replacing fysicalythe photoconductor/imagaging drum, leave the door open. Press and hold Cancel untl all lights flash in sequence to reset the printer. Close front cover.
May 28, 2009 | Dell 1700 Laser Printer
How do I get our Imaging Drum light to go off?
Follow the four simple steps below to reset the internal drum counter.
1.)    Open the front door.
2.)    Press and hold the “Cancel” button; until all of the lights flash.
3.)    Release the “cancel” button.
4.)    Shut the front door.
P.S.
Here is a Link to the Dell 1720/1720DN online users guide.
http://support.dell.com/support/edocs/systems/prn1720/en/index.htm
And here is a direct link to Replacing the photoconductor.
http://support.dell.com/support/edocs/systems/prn1720/en/1720_en/en/d0e4183.html#replacing-the-imaging-drum
-Hope this helps
Apr 07, 2009 | Dell 1700 Laser Printer
Dell 1700 laser printer
Call Dell. the 1700 has special reset instructions for resetting the drum count.
Feb 24, 2009 | Dell Office Equipment & Supplies
Dell 1700 laser. refilled toner, getting gray background
Check toner darkness settings using the setup utility.
Oct 18, 2008 | Dell 1700 Laser Printer
1700 Drum Error
hold cancel button down with door open, this should rest it
Mar 27, 2008 | Dell 1700n Laser Printer
Flashing lights
you can try calling Dell support at Technical Support 1-800-624-9896 to verify if the problem is electrical. We had a customer have the same problem after he replaced the imaging drum we found out that the unit still had the problem. He finally figured out that the unit has been exposed to an electrical surge and it caused a problem with the board inside the unit. I would try using a new imaging drum but if the unit is still covered by Dell I would have them replace it.
May 18, 2007 | Dell 1700 Laser Printer
Dell 1710n Laser Printer Logo
4,674 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
