Question about Motorola Mobility RAZR V3
Glass broken on razor phone
Can you replace the ft glass on the razor phone?
  • paul1950 Dec 27, 2007
    how do i fix the broken caller id glass on a v3 razr
I was shopping for a used cell phone for my wife today. The place I found also was able to replace the glass on my phone. Cost was 37 dollars.
Posted on Sep 07, 2008
Go on ebay! The sell the replacements about $6.00 including shipping!
Posted on Dec 15, 2007
Guy a new one
Posted on Dec 14, 2007
Removal of inner glass door.. how.??
Open door to about 15~20 degree angle, pull up on door and totally remove from stove. Lay face down on flat surface. Now can access all screws to separate the inner and outer panels and to replace the glass. To return to stove, use locking pliers to pull the door hinge stubs out to their 15 degree open position, slide door on and close.
If glass not broken, just can't see through, no need to remove door or glass. Use glass cooktop cleaner, apply and let soak 3 minutes, then use new single edge razor in holder to shave off the baked on grease. May have to repeat 3x then switch to glass cleaner and clean again 3x, should be quite clean and clear unless seal has failed on the double pane thermal glass and internally obscured in which case the only cure is to replace the glass... return to paragraph 1.
Sep 20, 2015 | Ovens
Car charger broke off in side charging port. Cant retrieve info until it comes out. How can I take it out or take it apart?
Taking the phone apart wont help you, so don't do it. if it's a round power plug, a drywall screw will get it out if you twist it into the broken plug. For micro usb plugs, Wear safety glasses, and lever it out with the corner of a razor blade. Use gentle pressure, and go slow.
May 06, 2011 | Cell Phones
Where to get new doors?
your best bet is to call them
customer service:
Monday-Friday, 8am - 5pm Eastern
Phone: 1.800.227.7437 or 1.800.CARRIER
maybe they sell direct or tell you where you can go thru a distributor (local closest to you) and order by phone
hope this was helpful
if you just need glass try local glass replacement store nearby Just a suggestion)
Mar 07, 2010 | Carrier 10.8 cu. ft. Commercial Freezer...
How do i remove a broken screen to replace with another from another phone. inside screen. just glass broken
Is just the glass broken? The LCD screen underneath the glass also could be broken. But if it is just the glass in front of that, go on ebay and search for the inside glass lens. Also, you can find directions to change anything at all just search it on google.
Nov 27, 2009 | Casio G''zOne Type S Cellular Phone
Broken razor
you have a rom boot up problem but you will need to replace the main-board on the phone or replae the phone itself.
Jun 27, 2008 | Motorola Mobility RAZR V3
Cell Phone
this happened to my phone also
Jun 26, 2008 | Motorola Mobility RAZR V3
Motorazr V8
Dear Sir,
I had a motorazr V8, the glass of upper screen has broken, so I want the solution. can this screen has changed, please revert back to me.
Vijay Tyagi
9871094350
vkt_31montage@yahoo.co.im
Mar 07, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
Razr2 broken cracked screen
ya, be careful. i read online use a razor blade, jewelers screwdriver, etc to pry up on it, then take a piece of paper and work it back and forth till the screen is completely removed.
remove any bits of glass, then carefully clean off the old adheasive with a cloth or your finger. this is just what i read online. i am going to try this myself when i get the new glass screen in.
Feb 25, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
146 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
