Cars & Trucks Logo
Posted on Sep 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Change back Brake pads on renualt megane 2 - 2006 Renault Le Car
Anonymous
Level 3:
  • Master 548 Answers
  • Posted on Sep 18, 2009
Anonymous
Master
Level 3:
Answers
548
Questions
0
Helped
267463
Points
1998
1. Hand Brake ON , loosen wheel bolts to hand tight, jack up front wheel , chock back wheels , put axle stands/blocks in place (just in case) .
2. Remove wheel. Disconnect pad wear wire , it pulls out of the connector.
3. Remove lower caliper bolt (at the back of caliper at the bottom) , need a 13mm ring spanner for head of bolt and 17mm to stop it spinning
4. Use a screw driver between the back of the outer pad and the caliper to prise the caliper back away from the back of outer pad. Pivot caliper upwards to rest on top of wheel disc (good idea to tie it up with some wire) .
5. Remove and discard old pads , clean out with wire brush and soft brush , don't breath in to much of the dust its nasty.
6. Fit new pads (remember pad wear sensor on inside pad), make sure that the pads are in contact with the disc , and the top of them sitting flush with the rim of the disc, don't force them into this position they should naturally sit there.
7. Lower caliper down into position, you may need to push back the piston further in order to make room for the new pads , do this with you hands or a small piece of timber. Keep an eye on the brake fluid resivoir , your pushing fluid back in so if its over full it may spill over. Refit lower caliper bolt (Renault say to replace this each time), and tigthen. Reconect pad wear sensor.
8. Pump brake pedal until normal brake pressure returns.
9. Remove axle stand/blocks , refit wheel and bolts , lower jack and tighten up wheel bolts.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 27, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3064
Points
I have problem witch megane 2002 backs brake
I need a picture from brakes please
1helpful
Renualt Megane it was service and the engine wasched i drove 10k and it went into limp mode saying check ingection
How to fix Electronic Fault on Renault Megane - YouTube
? 5:15
www.youtube.com/watch?v=JCMWEK-e99k
Apr 19, 2014 - Uploaded by Paul Higgins a guide on how to repair "electronic fault" on your renault megane, this fault ... just a feo hours after the installation , now we have el?ctric fault on .... My next hurdle - (and why it failed it's NCT) the fog lights / boot don't work / wont open? ... Free power from a recycled washing machine, generating enough to
My Renualt Megane Coup Cabriolet 1.9 will not fire, running fine yesterday
get the OBD checked by a suitable mechanic save time and hassle
Starting renault megane 2003 1.4
do u mean u put it in gear and it wont move?
Where is fuel pump conector located in renualt megane 2005
lift the back seat ,and their is an inspection plat under this plate is the fuel pump and connection block is on top of the sender unit
I need to drain my fuel tank in my renualt megane 225 sport
there should be a bolt to drain it, it might be on the side or close to the bottom
2answers
Renualt megane (Auto) 2001 model wont start
Have you tried cleaning or replacing the flywheel rotation sensor ????
Toxic Fume Filter System Warning Light Reg 54 Renualt Megane
was my clarification request any use,if was plese rate,many thanks
2answers
Door locking problems on Renualt Megane 1.6 Dyna 2003
renault ,what else do you expect ......dealer only ,encrypted software
Top Renault Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Renault Expert? Answer questions, earn points and help others
