Question about LG CED 8120B CD-RW Burner
Nero cr-rw burner install
Hi, trying to install a lite 52x32x52 nero burner on my xp,, have connected it as the master and cd rom as slave hard drive seprate as in leaflet, install sofewera etc from disc which come with it, all works fine ontill click the burn button then crashes and a blue screen come up to check sofewear etc,, have to restart xp, / any ideas , do i need a audio cable at back of nero cdrw?, gazz
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 50 Answers
Is your hard drive the master on the primary cable? You shouldn't need a digital audio cable unless you want digital audio. Are you using Nero software witht he drive? may have to re-install the software, or better, uninstall it, clear the registry with CCleaner (free download on the web) and then try a fresh install.
Posted on Aug 22, 2009
How do i format a disc?
You can only format re-writable disks, and it is usually done with the software that is used for burning the disk. Programs like Nero Burning Rom allow you to completely wipe a disk.
Feb 04, 2012 | Lite On Lite-On 52x32x52 CDRW & 16x...
Nero Express cannot detect my external imation (52x32x52) recorder. Only image recorder (CD-R/RW) detected.
completely remove nero first.then try reinstall it after restart.
but not correcting by dat,remove nero and install newer version.
Nov 14, 2010 | Imation Burn-R CD-RW Burner
I installed a LiteOn SOHR-5239v cd-rw drive. It doesn't show up on my computer and i looked on the website and couldn't find the driver.
Ok thats probably your problem. J
You will have to remove the DVD drive once it is removed look at the back it will look like this,
I have indicated where the jumpers are located. The jumpers tell the computer how to read the drive (every IDE drive hard drive, cd/dvd rom, floppy drive has them) the options are Master (meaning it is the main drive), Slave (secondary drive), and Cable Select (the cable decides how the drive will be read).
There are two ways to connect the drive to the motherboard one is to split the IDE Cable with the hard drive the other is the drive has its own IDE Cable and plugs in next to the hard drive.
If you are sharing the cable with the hard drive configure the jumper as Cable Select,
If your drive connects with its own cable select Master.
To do this pull out the jumper and insert it in the location you want.
Jan 19, 2010 | Lite On (SOHR-5239V) CD-RW Burner
External cd-rw with no instructions may be missing a cord?
You need the USB cable to use it. Go to a computer store, show them the drive and tell them you need the cable
Nov 05, 2009 | Lite On Lite-On: Lite-On 52X32X52 External...
Nero problem
You should reinstall your nero software and DVD/ Writer should be on master and CD rom shoul be slave. Then it will work at all.
Thank You
Jul 30, 2009 | Sony Optiarc AD-7170S Burner
No detected Dvd ROM in PC
Greetings my friend, regarding on your problem try to check first the connection of your CD/DVD ROM. Make it sure that the connection is isntalled/Plug correctly then also try to see the jumper and change it to slave if you are using 1 IDE cable connector for your hard disk and your CD/DVD ROM. No need to installed drivers for this device folow the steps i write then after you done all the steps i have written then restart your computer
Jun 16, 2009 | Lite On LITE-ON SOHC-5236V COMBO BK OEM...
G4 350 mhz agp powermac
Can you try installing the new burner as a slave and the zip as the master?
Had a pc once that refused to boot at all with a new DVD burner in it, alongside a DVD-ROM. The burner was replacing a CDRW drive, swapped the drives master and slave settings over and it worked.
Oct 15, 2008 | Apple Power Mac G5 Desktop
Sony CRX300E CD-RW/DVD-ROM Combo - DVD doesn't read
do you have software/program that supports DVD.
Try a different DVD/Movie/Disk or alternative.
Also install a program, such as Nero which will give you physical characteristics of the drive.
Finally go to device manager, and remove or uninstall the device, reboot the computer and setup again. This can sometimes remedy the problem.
ensure that the drive is set as Master/Slave. if on the same Bus/IDE channel as a hard-drive. set as master/slave opposite to what the hard-drive is setup as.
Hope this helps.
Mike @ Compurepair.
Feb 24, 2008 | Sony (crx300e) CD-RW/DVD-ROM (Combo)...
CD ROM DETECTION PROBLEM
LEAVE YOU hard drive on primary master port on your main board set as master or single drive ( IF YOU HAVE A STATA HARD DRIVE THEN DONT WORRY ABOUT THAT PART)
SET YOUR FIRST DRIVE AS MASTER
SET THE SECOND AS SECONDARY
use the jumber in the back of the drive to set them the propper setting is labeled on the drive it self
Connect them to the secondary port on your motherboard
so you should have
HARD DRIVE - MASTER OR SINGLE *jumper settiing* connected to the primary port on your main board
DRIVE 1 = MASTER *jumper settiing*
DRIVE 2 = SLAVE *jumpersetting*
connected to the secondary port on your mother board
IF YOU HAVE A SATA HARD DRIVE FORGET THE PARTS ABOUT HARD DRIVES ABOVE
i assumed you had a IDE hard drive
JUST USE THE SETTINGS FOR THE DRIVES and it should work :)
Dec 25, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Computer can't find it
hi ...
try to change jumper position to slave or to master and start up you xp pro
good luck
Oct 22, 2007 | Samsung SW 240B CD-RW Burner
LG CED 8120B CD-RW Burner Logo
59 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
