Question about Acer Aspire 5003WLMi Notebook
Wireless connection Recently we have purchased a new router in order to have wireless. I am curious as to where you turn on the wireless enabled function? My understanding is that the computer is wireless ready? Thanks - Amy
1. Determine if your your laptop really has a wireless device? Control Panel -> Network Connections. At least two device should be listed and one of them clearly marked as Wireless.
2. The laptop will have a switch to turn the wireless interface card (WNIC) on and off. Maybe a keyboard control something line Fn+F2, Do you have any icons that look like an antenna?
3. Is wireless turned on by default at the router? Do other devices connect to your wireless router
Posted on Dec 13, 2007
How can I enable radio function on my N300 wifi adapter
TO turn on the radio, go to Advanced menu and click Wireless Settings. The Enable Wireless Router Radio box must be checked to enable wireless function on the router. If you have a newer router and it has a Genie UI, click on the ADVANCED tab > Advanced Setup > Wireless Settings. Hope it helps.
Oct 26, 2014 | Computers & Internet
How do I connect a Phillips t v to the internet
Either with an Ethernet cable from your home internet router to the TV, or wirelessly. The 4200 series require an optional wireless dongle (PTA127) to enable wireless functionality.
You can use a 3rd party wireless or Ethernet over Power devices (Homeplugs) to bring an internet connection to the TV that can then be connected to the TV's Ethernet port.
Sep 09, 2014 | Televison & Video
Want to set up WEP encryption, but the router doesn't seem to accept it.
You have to use a static IP or PPPoE IP Address in order to enable this WEP function. Use the ASCII settings to enter text. Look at the restrictions noted.
Oct 23, 2012 | D-Link Vonage-enabled Wireless Router...
THE MIDDLE DISPLAY LIGHT AN "A" FLASHES WHEN i TRY TO START IT AND IT WONT TURN ON
Turns on when the numeric keypad is enabled.
Turns on when wireless devices are enabled.
Turns on when the uppercase letter function is enabled.
Turns on when Mini PCI functionality and Bluetooth® wireless technology are enabled. To enable or disable Mini PCI functionality and Bluetooth wireless technology, press <Fn><F2>.
NOTE: Bluetooth wireless technology is an optional feature on your computer, so the about31.jpg icon turns on only if you ordered Bluetooth wireless technology with your computer.
For more information, see the documentation that came with your Bluetooth wireless technology.
Turns on when the scroll lock function is enabled.
Here is the answer! memory problem! go to this site. http://www.laptop-junction.com/toast/content/dell-caps-lock-light-flashing-blinking
May 30, 2010 | Dell Latitude D610 Notebook
I have a 2wire wireless router but i've had it hooked up to my airport express as the wireless router. How do i get the 2wire to function as the wireless router? only the DSL light lights up, not the...
Since the Wireless light is off, lets assume that the access point is just switched off.
That function is switched on and off from the router's control panel accessible via web browser. And you can follow these steps to get to the Wireless configuration control panel.
Open this URL from your browser
http://gateway.2wire.net.
If you have a system password enabled (and it's asking for it) but you didn't set it, or you forgot what it is you can click the
can’t remember the password
link if the password hint does not help you. In order to reset the password, you'll be asked to enter a 10 digit code which you can find on the bottom of the router itself.
Once you're able to gain access to the control panel, you'll want to
  1. click the 'Home Network' tab
  2. click the 'Wireless Settings' link
From this panel you can make changes to how the wireless access point portion of the router is configured. By default your router's wireless should be on, but since it's not I'm going to assume at one point in time someone turned it off so it wouldn't get confused with your airport express. If you just want your wireless settings back to the default settings
  1. click the 'RESTORE DEFAULTS' button
Then the wifi settings will be set to how they were when the router was purchased. By default the access point is secured by WEP encryption, and the key is located on the bottom of the router by the Serial Number.
Apr 22, 2010 | 2wire (2701HG-B) Wireless Router
IS MY PC WIRELESS ENABLED? I JUST BOUGHT A PACKARD BELL UTOW-SAN, HOW DO I FIND OUT IF ITS WIRELESS ENABLED AS MY ROUTER IS WIRELESS. IF NOT WHAT DO I NEED TO MAKE IT WIRELESS ENABLED?
You can check your pc if its wireless enabled if you have a wireless adapter installed on your system with the necessary drivers, if you dont have the device, then you have to purchase a wireless adapter from the computer shop and install its device driver in order for it to work. If you have a hardware and have the driver installed, you go to control panel and network connections if you have windows xp, you should configure it to get ip from your router in order for you to get connected to your wireless router, and also you make sure that wireless is enabled on your router when you configure it.
Jan 10, 2010 | Packard Bell iMedia SL 9553 (P660401806)...
My router is suddenly not working. The internet, modem, router and the wired lights are on, but the wireless and security lights aren't on and I can't connect from my laptop wirelessly.
check the wireless settings of the router.
Open the set up page of the router and make sure that the wireless SSID broadcast is enabled.
If enabled then try to change the wireless channel of the router.
if that doesn't work then try to upgrade the firmware of the router.
Click Here for more info about routers
Dec 19, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Need to connect directv from hard line to vonage.
I had vonage with dish network and was able to buy a phonex system for wireless connection. Worked great.
Mar 22, 2009 | D-Link Vonage-enabled Wireless Router...
Acer Aspire 5003WLMi Notebook Logo
178 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
