Are u using " A PIRATED" Edition, Becoz I was having da same Problem when i was using a Copied One From my Friend!!! Now I had got an OrginaL and its Running Fine!!!
Are you sure your friend doesnt have any connection problems at home? Or try and change your account from sub-account to master account to invite friends to play online on ps3.
I'm not sure about 3659 but these are the ports I have forwarded
TCP:
80
443
5223
UDP:
3478
3479
3658 should also be opened for voice chat.
Also DMZ would be perfectly fine as long as long as you set a static IP on your PS3
What DMZ allows is that any ports communicating to a specific IP access, so if this IP is alway connected to your PS3 no harm to other computers or devices can be done!
Freezing playing offline two players or even one player. First I thought the problem was related to the fifa09 DVD, and therefore I got a new one. That didn’t help. Then I got at new PSP3, and it didn’t make a difference. However, I found the solution: Unfortunately I did two things at the same, so it’s not possible to say, what made the difference. 1. Dot not choose your local language (in my case Danish), but chose English (the next time you start fifa09 it can run with your local language) 2. Delete your saved data concerning fifa09
the eye on your ps3 might not be able to register any videogames because of the different code that the dvd but calling sony customer service can help. you might be able to get the optical eye replaced for little money and you can be playing in no time!
