Question about RCA WSP150 Main / Stereo Speaker
Wsp150 I've had these speakers for a about a year. They are both skipping in and out at a regular rate. The green light stays on but the sound skips on and off every couple of seconds. Any ideas?
  • Anonymous Jul 20, 2008
    cImpossibleannot find anyone to service the speakersvery good when working
    Impossible to get circuit of speakers
    No information available
Turn up your computor volume all the way up and adjust the volume at the speaker,..Ted
Posted on Jun 22, 2008
I have the speakers and power adapter but i can not find the transmitter....can i purchase the transmitter only..??
any transmitter will work by RCA..... The one for the WHP141 works just fine and that headphone set w/transmiter is about 19$ on Ebay as well as other places, be aware that the transmitter will not transmit UNTIL the sound source is hooked up and the sound is high enough to trigger the transmitter into working..... do not expect the green light to come on simply because it is plugged in, because it wont.....also if the sound is not high enough from the source the sound will cut in and out......notice also that the transmitter power supply is the 19 Volt one, and the tip is - and the out side ring is the + reversed of what many after market power supplys are.........the cool thing is the gain of a set of decent head phones as well as being able to use the many people fail to even READ the instructions and think that the units are defective because the green light does not stay on when pluged in......pays to read.....
Dec 19, 2011 | RCA WSP150 Main / Stereo Speaker
I need a transmitter for a set of rca wsp150 WIRELESS SPEAKERS. CAN I SUBSTITUTE? Where can I buy one?
head phone set WHP141 will work with that set of speakers, look on Ebay
I have a set of the same speakers.... make sure that your transmitter is actually bad, it does not power up with the GREENLIGHT staying ON UNTIL the sound source is hooked up and has enough INCOMING volume to trigger the transmitter on.........
Oct 27, 2011 | RCA WSP150 Main / Stereo Speaker
Skipping stiches in zig zag
This could be caused by several things:
Blunt needle: Have you changed the needle firstly, skipping stitches is a sure sympton of a blunt needle.
Wrong type needle: are you using a regular needle on a stretch fabric, this will cause skipping too, change to a ball point needle.
Timing out: this is the more serious fault, if its skipping after you've changed the needle and sews okay on straight stitch, then it is likely your needle to rotary hook timing is slightly out. Something for a technician to deal with but there is simple diagrams here if you want to take a look at what is involved.
Oct 24, 2011 | Sewing Machines
Where can I get a replacement RCA WSP 150 transmitter? I think mine is bad.
The transmitter does not turn on unitl there is enough incoming volume from the sound does NOT turn on the green light simply because it is plugged in........the volume is critical.....
Mar 05, 2011 | RCA WSP150 Main / Stereo Speaker
When I plug in the power supply to the transmitter the green light goes on only for a split second and goes out. If I wiggle it back and forth and it and out I can't get it to ever find a spot where it...
the sound source MUST be hooked up and running INCOMING SOUND to trgger the transmitter to work.the green light DOES NOT STAY on simply powering up the transmitter......
Jan 15, 2011 | RCA WSP150 Main / Stereo Speaker
No power light on transmitter. Measured correct voltage at power-in.
the light does NOT stay on .....because it was not designed to.....takes INCOMING SOUNDwith the transmitter plugged into the sound source to make the light stay on......
Oct 02, 2010 | RCA WSP150 Main / Stereo Speaker
Wont work! light on transmitter goes off after 5 minutes
takes VOLUME from a sound source to turn the light on, it DOES NOT STAY on simply because it is plugged in.....
Mar 06, 2010 | RCA WSP150 Main / Stereo Speaker
WSP150 speakers don't work on new computer
I don't want to be mister obvious. But have you tried to put up the master volume on the computer. Also make sure your putting the green wire in the right hole sometimes i mess that up :(.
Jan 22, 2008 | RCA WSP150 Main / Stereo Speaker
RCA WSP150 Main / Stereo Speaker Logo
278 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
