Whirlpool LGR5636L Gas Dryer
Problem for Whirlpool LGR5636L Gas Dryer
Not getting hot
By socalsubman on Sep 18, 2009
wondering if there is pilot light for drier
Best Solution
posted on Sep 18, 2009
Very Helpful)
localwonder
Rank: Guru  Whirlpool Washers & Dryers  Expert
Rating: 92%, 2817 votes
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Whirlpool LGR5636L Gas Dryer
Questions and Unsolved Problems for Whirlpool LGR5636L Gas Dryer
Do you recommend Whirlpool LGR5636L Gas Dryer?
Answer
Answer
whirlpool dryer lgr 5636 starts runs 10 seconds then shuts off. smell like something is burning.
Answer
hot air shuts off after 15 min. and tumbler still continues
Answer
My Whirlpool Gas Dryer was running but generated no heat. Please advise!
Answer
When turning on the dryer (Either Automatic Dry or Timed Drying) I can see the ignitor (I'm guessing... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Whirlpool LGR5636L Gas Dryer:
Top Dryer Experts
Rank: Guru Guru
Solutions: 14902
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Dryer Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
