Question about Sony PlayStation 2 Slimline Console
PS2 When the disk is put into the system, it does not spin. I tried blowing off the laser/lens, but it did not help.
  • Mic2 May 28, 2008
    the thing that spins the disc only spins for a short time and when it does spin for a short time the screen says reading disc and then says no data. I tried spinning the thing that spins the game disc.
  • 49 Answers
You might need to have the post replaced... the solution you provided may only work for a little while
Posted on May 27, 2008
    Genius:
  • 1,175 Answers
There is a plastic post in the "hood" ( top door)of the drive . Normally it comes down and pushes a lever that moves the disc brake out of the way so the disc can spin.
If the post is broken the disc won't spin.
If its broken, you'll find an area on the underside of the hood that looks like there was something ...there.
Below, in the drive area at the back of the disc area, there's a hole where that "post" went.
I made a new post from a plastic pen clip ( the part that clips onto a pocket), cut a section off a pen clip, make it about 1/4 inch long , very flat on one end, make sure it will fit thru that little hole towards the back of the drive area.
Superglue the thing in and Voila'
Posted on Feb 02, 2008
    President:
  • 4,402 Answers
Http://www.g4tv.com/xplay/features/45797/PlayStation_2_Disc_Read_Error_Fix.html
Posted on Jan 04, 2008
3 Suggested Answers
  • 13 Answers
SOURCE: Disks wont spin on new laser
Did you remove the anti static solder blob (point) on your new laser with a soldering iron and solder wick prior to installing it? The symptons your explaining indicate that point is still intact, If so you will need to carefully remove it first then reinstall the laser and try again.
Posted on Sep 20, 2007
Cerfer39
  • 709 Answers
SOURCE: Disk wont spin
First of all the new laser lens will not allow your Slim to read NTSC UC games if you have a PAL european Console.
There is no reason the New laser should have not read the disc unless it Came to you damaged. It sounds like you know how to replace a laser.
Posted on Oct 18, 2007
Doesnt do anything
Try blowing on the little disk reader first, then try wiping the disk reader with a clean cotton shirt. Put the disk in, and listen if the disk spins, if it doesn't it can be one of 2 things.
-if disk doesn't spin
1) the sensor that sensors whether the latch is open(check youtube for bypass)
2)the spin motor is broke (throw out the ps2, and get a new 1)
Sep 28, 2009 | Sony PlayStation 2 Slimline Console
Ps2 wont read disks it just goes to the browser ad configure screen how do i fix this?
Have you trided blowing at the back it might be dusty or ya spit on the dics, get a tissue and clean it.
Jul 29, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 wont read discs and we tried a disk cleaner
try a cleaning disc, if that does not work, the dvd mech is defective, try using some canned air to blow out debris from the worm gear assembly
Jul 27, 2009 | Sony PlayStation 2 (PS2) Console
Game not working ps2 slim
did you try cleaning the laser lens? q-tip + small amount of rubbing alcohol, then use other end of q-tip to dry it. or you could use a laser lens cleaner for video game systems. hope this helps :D
Mar 06, 2009 | Sony PlayStation 2 (PS2) Console
PS2 Slim New Lens, Not Spinning
Hi guys,
Well, there is 2 switch. one at  the back left of the cd tray and one one the reset /power switch. both sitch have to be close in order for the disk to spin.
If you try this dont forget to put a disk on the spindle as you will start the laser. this is for your safety. then, if the disk does not spin, then you can try replacing the laser. or at least verify the ribbon cable that is hook to it. if the ribbon cable is not well inside the plug the laser might move but again the disk won t spin.
it is related to each other, the PS2 seem to verify the laser prior to start the spindle so what ever happend to the laser affect the spindle.
and then, if you buy a new laser lens, don't forget to remove the soldering bridge. it is a small ball that is use to avoid static while shiping the lens.
most of the seller will include a small peace of paper with procedure and also there is web site with picture of this soldering bridge.
I replace some of them, and I have to say that the small plastic lock for the ribbon  cable to the lens has been an issue and the soldering bridge another one.
but I got most of the PS2 back and running by replacing the laser.
I hope this will help you.
Feb 26, 2008 | Sony PlayStation 2 Slimline Console
Disc won't spin... laser doesn't come on...
ok...well all of you people are just **** him! the actual problem is that you probably dropped the ps2 and the case lid got a bit lose...... what you have to do (if you dont want to buy a whole ps2 case again) is tap the ps2 on the top of the lid when it goes into the cd browser screen and it will work perfectly fine just make sure you dont tap i too hard or else we will have another problem...lol!
Nov 17, 2007 | Sony PlayStation 2 Slimline Console
Sep 13, 2007 | Sony PlayStation 2 Slimline Console
Disk wont spin
Disk not spinning but laser is lit
i had this same problem countless times, the problem is the laser what you have to do is open it up get a bud and some ethanol(becareful some ethanols are made oily to prevent child consumption avid these one) then gently wipe the lens and clean out the rest of the console with a hairdryer and VOILA
Apr 18, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 Slimline Console Logo
56 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
