Question about Nintendo DS Lite Console
Connecting to external amp/speakers
Have read that DS can be hooked up to Marshall's MS2 or MS4 micro-amp/speakers. Using which socket and cables between the two though?
    Problem Solver:
  • 8 Answers
I'm almost positive it is where the headphones go.
Posted on Jan 04, 2008
How do you connect a peavey 6505+ amp to a marshall 1960a cabinet?
On the back of your 6505 there are two jacks that are labeled speaker outputs. For mono function, use either one of those outputs and run a SPEAKER cable from your amp to one of the input jacks of your 1960a cabinet. I assume it is a 4X12 cabinet. Either input will work. Make sure you match the ohm selector on your 6505 (right next to the output jack, 4/8/or 16 ohms) to the ohm rating on your 1960 cabinet. It is likely labeled on the plate that houses the input jacks. You should be good to go. NOTE: Never turn your amp on unless it is hooked up to a speaker cabinet and never use instrument cable to hook your amp to your speaker cabinet. Bad for a nice tube amp like yours.
Rock on and hope it helps.
Dec 02, 2013 | Peavey Music
Marshall Mg30DFX guitar amp volume level cuts in and out! Anyone know how to fix this or what the problem is?
I have just fixed one of the amplifiers with this fault. It was a poor solder joint on the headphone socket. The ground of the speaker is switched through the headphone socket, so if there isn't a good connection, the speaker volume drops, but the headphone output is still OK.
Nov 03, 2012 | Marshall Music
How to hook up external speakers
There is no direct port to hook up external speakers. you have to use an amplifer to get connected in between TV and amp, using an AV cable.
Sep 29, 2012 | Magnavox 47MF439B 47 LCD TV
External Speaker hookup problem. I hooked up 2 external speakers (8 ohm, 160 watt) into my Marshall AVT 50 amp (tag on back says 4 ohm minimum). Everything worked fine, then I shut it down and now (next...
If you are competent with electronics, open it up and check the fuse(s). Especially if no lights come on. If you get voltage, then check the jacks you plugged into- they may have dirty interrupt contacts. When you plug the jack in- it opens those contacts that otherwise are closed making the circuit to the cabinet's built in speaker. Contact cleaner should clean them up if that is the issue.
While it is possible there is a power supply issue, you can see that quick with a voltmeter, it is not likely you did much more than blow a fuse.- very possible if you unplugged speakers with the amp operating..
If you think you killed it- you usually still get distorted noise.
Mar 29, 2012 | Marshall Amplification Music
My Marshall MS2 amplifier is not working. I can plug it into the adapter and it will work but then i unplug it it will not work. Even with a new 9-volt battery it still wont work. Please tell me what to...
Likely the switch contact that connects the battery when you remove the adapter is not making contact. This is a common problem. The problem is right at the input power connector. Sometimes you can bend the contact to restore operation... else you have to replace the input power connector.
May 30, 2011 | Marshall Amplification Marshall MS2 Micro...
Wiring diagram pignose 7-100 guitar amp which wire goes where?
There are a couple thumbnail sketches of the diagram at:
http://music-electronics-forum.com/t8790/
They are down about 3 an 6 of the blogs.
Nov 29, 2010 | Marshall Amplification Marshall Mini Stack...
By mistake i plugged the speaker jacks from another amp into the speaker jack on my mg 50. i was trying to test the other anp with the speaker on the marshall but i did it wrong. i didnt turn the marshal...
If you connected an external speaker plug from one into the same type plug on another amp, you have driven signals backward into the amp that was off... NOT into the speaker in that unit.
The usual result is blown parts in the amp that is off.
Some amps have their own speaker cable that you can unplug to connect to another amp and that is fairly safe. NEVER run an amp without a speaker load on it.
Feb 20, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Connecting the head to the cabinet
the guitar lead goes to the input or channel one on the amp head .. then look at the back there should be a socket for speaker or output a short bridge cable normal guitar cable will do to the input at the back of the cabinet speaker
Aug 05, 2009 | Audio Players & Recorders
Marshall 50w dsl
Put a patch cable from send to return on the effects loop in the back of the amp and see if it goes away. I would check your speaker, connections and speaker cable also. Is this a head or a combo?
Sep 04, 2008 | Marshall 82 WTS LITHIUM BATTERY, 3 LED...
Magnavox projection tv hookup to external speakers
The external (audio out) connectors are intended for use with an external amp, not direct speaker connection.
Sep 02, 2017 | Televison & Video
Nintendo DS Lite Console Logo
79 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
