Back to:
Tags:
Printers
Generic problem for all Printers
Black lines (by 5 users)
posted by carlaq on Dec 13, 2007
only when scanning, getting black lines in scanned document. Have tried all the fixes on HP support site, still can't get rid of it.
Comment by carlaq, posted on Dec 14, 2007
Thanks for the fast reply-cleaning the glass is probably the one thing i never thought to do. Sometimes the most simple thing works. Will try tonight.
Comment by carlaq, posted on Dec 17, 2007
definately not dirty glass on the scanner. It's clean. I assume there is drum for the scanner, and it's bad. Funny thing is, on the hp home page, they show an example of exactly what i am experiencing, and the fix they show just doesnt fix it.
Must be time to take it in for repair.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by Guest, posted on May 22, 2008
only when scanning & copying, getting black lines in scanned document.tried cleaning it but it does not help. please advise.
Comment by Guest, posted on Feb 16, 2008
On the AL-1655cs, a line appearing down the page when scanned, but not when printed, is not a result of dirty glass. The paper being scanned does not pass over the glass.
Comment by Tstac, posted on Feb 11, 2008
Having a problem with black lines when I scan a document. Definitely NOT dirty glass. Varies in intensity from document to document.... Any ideas??
Comment by marrtivivra, posted on Dec 19, 2007
when i scan a photo black lines appear in the middle of thepage how do i clean that
Best Solution
Helpful (85)
EPIJAB
Rank:Guru Guru
Rating: 86%, 66 votes
Not sure what you have tried but if there are no lines when printing but there when scanning there is something on the scanner. Could be something as small a single dot of dirt and it will put a line down the whole page. Try cleaning the glass.
Rating Locked! (?) carlaq has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on black lines:
I don't want to Accept this solution
Solution #2
posted on Feb 10, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Hi I have a similar problem but worse yet, my HP C4280 cannot print anything black. The black ink was working perfectly when we did the test print but it somehow would not print anything black when we print or copy documents. Any ideas?
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Can you Help with these Printers problems?
Samsung CLX-3160FN All-In-One Printer
Just bought this machine. Cannot get the scanner unlocked....
Printers
I have a Lexmark X4650 and have it connected wirelessly to...
Printers
Bought new computer & need to install lexmark...
Printers
Paper will not feed after initial start. Gives jammed...
Printers
i dont have the installation cd for my printer
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
