Question about Kenmore 53552 / 53554 / 53559
Ge gss25jmdww does not cool well. i was told it does not go into defrost mode. ice forms in the freezed by the light. i was told it could be the heater, defrost thermostat or the control module. how can i tell which.
  • 126 Answers
Take back off freezer from the in side check for continuntity on your heater and therm make sure your therm. is cold
Posted on Dec 13, 2007
The refrigerator has frozen on the back side of freezer and has stopped freezing. The other side is not cooling. Ice maker stopped.What is going on?
The frozen on the back side of the freezer is due to your unit haveing a defrost issue where either the defrost thermostat which is the most popular to show a fault in this type of situation, or the defrost heater, or the defrost timer or adaptive control has a fault . If you have a multimeter you can perform and ohms test on the thermostat which should read around .50 or higher and the defrost heater which usually is around 26-28 ohms. If you had a 0 reading then this would tell you which piece has a fault. I will await your reply as to your finds.
Thank you
p.s these parts are located behind that inside rear wall panel which is removeable if you were to see any ice up condition on the evaporator coil this would confirm your defrost issue and you would first use a hair dryer to defrost the evaporator coil of all ice.
Nov 19, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Need to replace defrost timer for Hotpoint refrigerator model CSX 20 EASA WH need to know how it look
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
This will help.Thanks.Helpmech/.
Oct 19, 2011 | Refrigerators
Fridge works for about 3 weeks then freezer freezes up and fridge stops working i unplug it for 24 hours and it works for another 3 weeks same story??? what do i dooo? it is a ge side by side newer...
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts check if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Apr 05, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH22KGMB side by side refrigerator freezes up and doesn't make ice and forms ice on the back wall of freezer and veggie drawer freezes.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Aug 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Frezer keeps frezzing
If the freezer is icing up your defrost timer or the heating element may be bad. If the fridge doesnt go into defrost mode you will get frost on the back of th freezer and ice will freeze up on the coils eventually it will not cool the fridge side very well at all. If there is an ice block let me know also is the fan in the freezer running?
Aug 15, 2010 | GE Refrigerators
Ice form at bottom of refrigerator ZIR36NMRH GE
There are a few reasons why the refrigerator part will not are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
Jun 02, 2010 | GE Monogram ZIR36NMRH Refrigerator
Freezer is not keeping cold and forming icicles along wall
It may just be a defrost timer. Search online for information. There is plenty to be had. Check with the website of GE for a parts breakdown or your manual if you still have it for the location of the defrost timer. You can turn it manually so it goes into defrost. Does the unit seem to be running all the time and never shuts off? If so that timer could be stuck in the cool mode and the evaporator is freezing up solid so air wont flow over it to properly cool. I've had two refrigerators I've had to repair that had defrost timer problems. One stuck in the defrost cycle and wouldn't turn on to cool, the other did what you are describing. It stuck in the cool cycle and wouldn't defrost you may need to manually bypass the cooling cycle several times to allow it to completely defrost. Usually it cycles in cool from 6,8 or ten hours and only stays in defrost for over twenty minutes. That should defrost it and allow it to start cooling again. If you notice that frost has disappeared inside on the wall replace the timer.
May 22, 2009 | GE Monogram Side by Side Refrigerator
GE Side by Side (3 yrs Old): Freezer iced up, refrig not cooling
Most GE defrost problems are bad defrost thermostat and defrost heater.
It requies removing the back wall panel on the inside of the freezer to access the parts.
Mar 17, 2009 | GE GSL22JFPBS Side by Side Refrigerator
GE Refrigerator forms and Ice dam which stops the evaporator fan from turning.
is it defrosting theres a glass tube which is the defroster bar,there known to have these fail
Jul 07, 2008 | GE GDS20SBS Stainless Steel Bottom Freezer...
Kenmore 53552 / 53554 / 53559 Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
