Question about Mitsubishi WT-46805 46" Rear Projection Television
RE: Vertical Hold Not Working, Skippy101 where are you?
Skippy101,
You gave me some good advice on fixing my problem but I'm needing some help locating the ic you were wanting me to replace the caps on???
Are these boards plug and play type? I moved my TV and all of a sudden I had this problem, I thought maybe it just needs to be reseated?
I have a repair manual (part #'s & pics) for the TV but the pics are not that good of all the ic's.
Any help anyone can give me would be much appreciated and also one step closer to watching some good football games coming up in the next few weeks.
Thanks in advance.
    Problem Solver:
  • 11 Answers
If this problem appeared after you moved your set it more than likely is a cold solder joint somewhere.
Posted on Dec 13, 2007
I have vertical lines on the entire right side of the screen on my Olevia 242-S11. I've replaced the t-conn board three times, the first and third gave me a black screen, the second gave me less...
most of the stuff from jimmy's its second hand ( not good working or working maybe) first and the last i suppose you got a problem with the power supply on the T con on the second i suppose you have a problem with the big chip in the middle the scalier :D
Jun 02, 2011 | Syntax Olevia 527-S11 Television
Hi, I have a Tedelex EC29187 Television it have only a horizontal line in the middle of the screen, I opened it and looked for physical damage around the vertical defflection IC, but it show nothing so...
Ur tv it is taken aparts wright now?Yes.Plug in ur tv to see the problems and take the hard end handle of the screw driver and taps around the vertical deflection ic for cold soldering joints,will require resoldering the ic,if the vertical hold flickers or bounced back to normal.No bounce back vertical hold check all the sorrouding capacitors transistors resistors for dead components parts to be replaced,if all the sorrouding parts are good,than that vertical deflection ic it self it is dead and require replacing.
May 09, 2011 | Televison & Video
Continuous vertical roll on tv
Wow 5 months without a solution. NOT GOOD.. Well I hope I can help...
This sounds like a vertical hold problem, and is normally easy to fix.... There should be a couple of nob's on the lower back of the TV. One for vertical and one for Horizontal hold. You need to find the vertical hold nob and adjust it, until the rolling stops and stabilizes. If however these nob's are not visible you will have to take TV to an engineer to fix it.
Hope this helps..
Nov 11, 2010 | Zenith B27A11Z 27" TV
An error message that says carriage jam keeps coming on how do I fix this problem?
Hello there
It could be some thing jamming it so try this first.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 17, 2010 | HP Photosmart 2710 All-In-One InkJet...
We continue to get a "Paper Jam" error message every time we print. I merely press "OK" and it returns to good working order but I'd rather eliminate the error message. Any advice?
Hello there you may not see any thing jammed put worth a go.
this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
Feb 14, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Vertical hold adjustment
Loss of vertical sync or any other problem with your Mits is
likely caused by bad power supply capacitors....they are made by Rubicon and are notorious "leakers"......very tedious and
expensive to fix...................good set back in the day.......T.
Mar 10, 2008 | Televison & Video
Black vertical line
I'm sorry you have not been given a clear ansewer on how to repair your TV. I know how to fix the problem you are having (1.5 inch Black vertical lines that come and go) If you still need help fixing your Plasma TV please feel free to message me @ pleasefixitdave@yahoo.com or just give me a call @ 1-503-432-9904 and I'll help you fix your TV buddy! Ask for Dave!
Talk to you later buddy!
Dave
Dec 30, 2007 | Televison & Video
Vertical hold not working
on mitsubishi just replace the caps that are near the vertical ic this will fix the problem good luck
Nov 02, 2007 | Mitsubishi WT-46805 46" Rear Projection...
Quasar 32" TV VERTICAL HOLD
well most of the modern tv today doesnt have vertical hold anymore. this symptom is caused by a trouble in the IC integrated circuit or the vertical oscillator circuit. let the service guy do the job if u dont know anything about this. good luck!
Feb 02, 2007 | Quasar SP-3235 32" TV
Mitsubishi WT-46805 46" Rear Projection Television Logo
26 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
