Question about Pioneer ECS P4VMM2 V3.2A P4(478)/FSB 533/VIA/SDRM+DDR/A&V&L/MATX Motherboard (MBEP4VMM22)
Im updating my RAM could i use DDR2?
ECS P4VMM2 V3.2A P4 motherboard
Currently im using SDRAM PC-133 DIMM - PQI 256MB but right now is too expensive to buy new 256MB SDRAM. That why i planning to use a DDR2!
Can I use this following RAM:
DDR2-533 / 667
  • 43 Answers
Re: Im updating my RAM could i use DDR2? - Pioneer ECS P4VMM2 V3.2A P4(478)/FSB 533/VIA/SDRM+DDR/A&V&L/MATX Motherboard...
Posted on Dec 13, 2007
0 characters
3 Points
What is the max size of ddr400 memory you can fit into ddr1 & ddr2 dimm slots on a p4vm8 mother board
1) Total maximum amount for motherboard is 2GB.
2) There are 2 Ram Memory slots.
3) Maximum amount for EACH ram memory slot is 1GB.
Either DDR Sdram at 266MegaHertz, or 333MHz, or 400MHz.
PC2100, PC2700, and PC3200, respectively.
There is no DDR1 and DDR2 slots, in a manner of speaking.
May be marked on your motherboard that way, but stating it that way on a computer product support website = No.
You're going to make someone think, you don't know what you are talking about.
They may think you are referring to DDR Sdram, and DDR2 Sdram, and they know the motherboard only uses DDR Sdram ram memory.
Suggest state Slot 1 and Slot 2; or DIMM 1 and DIMM 2.
For additional questions please post in a Comment.
Mar 18, 2013 | VIA ASRock P4VM8 P4(S478)/...
I want to upgrade my system ram size to system memory configuration as follows mother board: intel102ggc2 system bus speed :800mhz processor (p4):3.0ghz ram slots available:2 and presently i'm...
The below is the contents of Intel published for your board
Intel Desktop Board D102GGC2 Technical Product Specification
System Memory The board has two 240-pin DIMM sockets and supports the following memory features: • 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMS with x16 organization are not supported. • 2 GB maximum total system memory. • Minimum total system memory: 128 MB • Non-ECC DIMMs • Serial Presence Detect • DDR2 533 or DDR2 400 MHz SDRAM DIMM
hope it helps, if so rate the solution
Nov 16, 2010 | Intel D102GGC2 Motherboard
PC does not recognized all memory installed on an upgrade of RAM
The operating system perhaps does not support anymore ram then this.
Or the motherboard may need a firmware update.
You can get the latest firmware from the manufactures website
Oct 13, 2009 | EliteGroup P4VMM2 Motherboard
Asus p5 vdc-x motherboard not recognizing ddr2
Ok i am just guessing here
maybe your motherboard does not support
ddr2 rams and hence it wont boot up as it does not detect any ram in the slots......
try to boot with one old and one new ram (ddr and ddr2) and post the result
are you sure whether the ddr2 ram is supported?
Jun 30, 2009 | ASUS P5VDC-X Motherboard
Can i install 1GB ddr2 on P4VMM2 Motherboard? i want to upgrade my pc; board is: can i P4VMM2 Motherboard; cani i use 1GB ddr2 on this and a 512 MB if vid.card?
Unfortunetly you cannot use ddr2 memory on this motherboard. The motherboard supports only PC2100/PC1600 DDR memory if you have version 8.1 of the motherboard. If you have v5.0 of the motherboard than you can only use sdram or ddr 266Mhz RAM. The same goes for the video card. The p4vmm2 motherboard is a rather old motherboard so I don't think it will payoff to upgrade the computer. It will be probably the best if you buy another computer.
best regards
Mar 23, 2009 | EliteGroup P4VMM2 Motherboard
Ecs p4vmm2 v1 motherboard windows xp pro sp 2 can`t get sound
you din't install sound card...go google find vinyl deck..n download luck
Mar 02, 2009 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
PC Motherboard Memory upgrade
From Asus tech: Memory 3 184-pin DIMM slots for PC1600/PC2100 DDR SDRAM
Supports up to 2GB memory
No ECC supportThis is only compatible RAM so make sure your new chip is PC1600 or PC2100. If you mis the 2 it the faster RAM will run at the slower chip speed. Hope this helps.
Feb 20, 2009 | ASUS P4B266 Motherboard
Memory Upgrade - from 256DDR1 to 1GB DDR1
EliteGroup makes two mother boards, P4VMM2, (No Revisions) & (P4VMM2 revision 8.1). Since your question states your memory is 184 pin DIMM your board must be, v 8.1. What does not make sense is the motherboard has two memory slots total.
(If you have 4 memory slots on the MB than the MB can not be the P4VMM2). Below is the link for the P4VMM2 (v8.1).
The P4VMM2 v 8.1 can only use, two Double Data Rate (DDR) SDRAM memory modules. These sockets support up to 1GB system memory using 184-pin unbuffered non-ECC PC2100 or PC1600 DDR DIMMs. The two DIMMS you are using must run at the same speed.
Example PC2100 266MHz. OR PC1600 266MHz.
Continuous beeping means the memory is not seated correctly.
When using only one DIMM it should be inserted in the slot closest to the CPU. Re-check your memory. Remove & reseat. Make sure the latches snap closed on each stick of memory while inserting. Below is all of ECS P4VMM motherboards;
Good luck sysa007!
More question, post here.
Thank you for using fixya.
If you find this helpful, please vote.
Jan 31, 2009 | EliteGroup P4VMM2 Motherboard
Pioneer ECS P4VMM2 V3.2A P4(478)/FSB 533/VIA/SDRM+DDR/A&V&L/MATX Motherboard (MBEP4VMM22) Logo
193 people viewed this question
Top Pioneer Motherboards Experts
Sudeep Chatterjee
Sudeep Chatterjee
Mark Taylor
Mark Taylor
Are you a Pioneer Motherboard Expert? Answer questions, earn points and help others
