Since you rolled back to factory default then all of your configuration should be gone. You should still be able to connect to it using the DHCP address assigned to it though. Do the following to try to connect to it again:
o the following:
1. Try to ping the device using a PC connected to the same network.
2. If you are using DHCP, your device may just have been assigned a different IP. Try to ping all devices in your network or use a network scanner (e.g. SoftPerfect) to find out the IP address given to it.
3. Once you get the IP address, assign a static IP address to your device that is beyond the DHCP scope. This will ensure that your IP does not change and you will not have a conflict with DHCP assigned IP's.
