Click on the start menu (orb), go to the Control Panel and select Programs & Features. From the list of installed software locate IE8 and uninstall it.
Restart your computer and download IE7 from here (its say's it's for XP, just ignore that it will work on Vista)
http://www.soft32.com/download_997.html
May i also recommend Mozilla Firefox. This much easier and faster than any version of Internet Explorer. Get it here >>>>>
http://www.mozilla-europe.org/en/?utm_source=google&utm_medium=ppc&utm_campaign=firefox35&gclid=COPn16ve-5wCFd0B4woduRwAcA
Regards.
It depends on which version of Internet explorer came with your machine. If you have downloaded a new version you should find it in the program files and you should be able to uninstall it just like any other program. Then your machine should revert back to the old default version that came with the machine. As with all Microsoft products expect bugs and things to not work as they should afterwards.
If that fails you cant find it in your program files. As I don't have Vista and only XP I can only tell you where to find it on XP and you will have to make adjustments for Vista:
go to Control Panel>Program Files>Uninstall Windoze components and put a tick in the I.E box and just click next and it should set I.E back to the old version you had before.
Personally I would do myself a favour and get another browser that quite frankly is as shoddy as you can get. The best ones are Opera or Firefox. I.E is trash and the only reason I have it on my machine is to test my webpages in. The more you work with the web the more you realize what a shoddy piece of trash Internet Explorer actually is.
I'm assuming this is an update from IE7 to IE8. First, go to 'Control Panel', then left-click on the 'Uninstall Programs' link or the 'Programs and Features' icon. On the 'Tasks' pane left-click on the 'View Installed Updates' link. Find 'Windows Internet Explorer 8' in the listing and left-click on it to highlight it. Now left-click on the 'Uninstall' button. Left-click on 'Yes' when asked if you're sure you want to uninstall this update.
If you can't find a listing for the IE8 update, then you may have to run spuninst.exe: Find the C:\Windows\ie8\spuninst\ folder. Find and run spuninst.exe. You'll have to reboot your PC after it's done un-installing the update.
Internet explorer 8 is the most stable browser version microsoft has released. Anyways if you wish to downgrade to IE7, better do this -
Download Internet Explorer 7, and uninstall IE8 which you are already previously using. When you install IE7 it will prompt you to upgrade to the latest version, but hit to ignore the message and choose the option to not alerting again.
Hi
You can degrade the Internet Browser using the following steps:
1) Go to Control Panel
2) Click on Programs Add/Remove
3) Select the Internet Explorer from the list
4) Right click and press uninstall.
5) Follow the step to remove it
6) Restart the computer if it asks.
7) Once all done it will come back to IE7.
8) If you want to setup again please download the IE7 from the following URL and run it.
http://www.microsoft.com/windows/internet-explorer/ie7/
9) Follow the steps in wizard.
See if the
information below helps to resolve the issue/s you are having with
Internet Explorer:
http://support.microsoft.com/default.aspx/kb/936213/?p=1
"How to
optimize Internet Explorer"
Configuration settings in Windows Internet
Explorer 7 and Windows Internet Explorer 8 may cause one or more of the
following issues:
· You experience performance
problems in Internet Explorer.
· You receive an error message in
Internet Explorer. For example, you receive an "Internet Explorer cannot
display the Web page" error message.
· Internet
Explorer stops responding.
The
above article describes how to optimize or reset Internet Explorer in
Windows Vista to resolve these issues.
http://support.microsoft.com/kb/936215
"How to
troubleshoot Internet Explorer issues in Windows Vista and in Windows
XP"
This article discusses how to troubleshoot possible issues
that you may experience when you use Windows Internet Explorer 7 or
Windows Internet Explorer 8 on a computer that is running Windows Vista.
http://support.microsoft.com/kb/936214/
"How to
troubleshoot compatibility problems that affect Internet Explorer 7 in
Windows Vista"
This article describes how to troubleshoot
software compatibility problems that affect Windows Internet Explorer 7.
To help determine which program may be causing the problem, you can
take the following steps:
1. Use safe
mode with networking
2. Perform a
clean boot
3. Use a different user account
4. Scan your
computer for viruses and spyware
5. Run Internet
Explorer 7 in "No Add-Ons" mode
Hope the above helps.
Cheers.
